iW3658-06F
iW3658-06F
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC-8
    单级SSL LED驱动器,集成高压MOSFET,适用于最高15W可调光 RETROFIT灯
iW3658-06F 数据手册
iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W 1 Description The iW3658 is a highly integrated, high-performance off-line power supply controller for phase-cut dimmable LED luminaires. It uses patented PrimAccurate™ primary-side sensing technology to regulate output current accurately without the need for a feedback circuit. The iW3658 operates at boundary conduction mode to achieve high efficiency and low EMI. With advanced dimming control technology, the iW3658 can operate with most wall dimmers including leading-edge dimmers (R-type or R-L type) and trailing-edge dimmers (R-C type). The iW3658 operates in buck-boost mode to regulate current to the output LEDs. Dialog’s innovative technology maximizes the iW3658 performance with an integrated high-voltage MOSFET in an SO-7 package, which provides an extra pin spacing between the high voltage MOSFET’s drain and low voltage pins. With Dialog’s proprietary VCC regulation circuit, the iW3658’s VCC level is well maintained regardless of the LED voltage and dimmer phase angle, which eliminates the possibility of low end flickering. 2 Features ● Isolated/non-isolated off-line 120VAC/230VAC LED driver up to 15W (Note 1) ● Wide line frequency range (45Hz – 66Hz) ● Closed-loop constant current regulation ● Built-in LED current derating at high temperature ● Built-in over-temperature shut-down ● Excellent dimmer compatibility ● LED open and short protection x Leading-edge dimmer ● Fast start-up (< 0.5s without dimmer) x Trailing-edge dimmer ● Low BOM cost ● Resonant control to achieve high efficiency (typical > 85%) ● Integrated high-voltage MOSFET ● Supports Buck-Boost topology ● Single-winding inductor ● Internal start-up without the need for high voltage circuit 3 Applications ● Dimmable LED retrofit lamps up to 15W (Note 1) x A-style, BR, GU and PAR ● Fits in E26/27 Socket for All-Glass Lamps Product Summary www.renesas.com Rev. 0.93 Preliminary 1 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W L VOUT - VOUT + N iW3658 5 VG 6 VCC 7 COMP 8 CFG HV 4 GND 2 ISENSE 1 Figure 3.1 : iW3658 Typical Application Circuit Note 1 : For output power above 12W designs, care should be taken to verify the thermal and reliability constraints on the IC. An IC temperature below 120°C is recommended for proper IC operation. Product Summary www.renesas.com Rev. 0.93 Preliminary 2 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W 4 Pinout Description iW3658 1 ISENSE CFG 8 2 GND COMP 7 VCC 6 4 HV VG 5 Figure 4.1 : 7-Lead SO Package Pin Number Pin Name Type 1 ISENSE Analog Current sense 2 GND Ground Ground reference 4 HV Analog Internal high voltage MOSFET drain 5 VG Analog Internal high voltage MOSFET gate 6 VCC Power Input 7 COMP Analog Constant current regulation loop compensation 8 CFG Analog OVP level configuration Product Summary www.renesas.com Pin Description Power supply to control logic and MOSFET drive Rev. 0.93 Preliminary 3 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. Parameter Symbol Value Units VCC -0.3 to 6.0 V VG (pin 5) -0.3 to 18.0 V COMP (pin 7) -0.3 to 6.0 V HV (pin 4) 500 or 650 V ISENSE (pin 1) -0.3 to 6.0 V CFG (pin 8) -0.3 to 6.0 V DC supply voltage range (pin 6) Maximum junction temperature TJMAX 150 °C Operating junction temperature TJOPT -40 to 150 °C Storage temperature TSTG -65 to 150 °C θJA 170 °C/W ESD rating per JEDEC JS-001-2017 ± 2000 V Latch-up test per JESD78E ± 100 mA Thermal resistance junction-to-ambient Product Summary www.renesas.com Rev. 0.93 Preliminary 4 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W 6 Physical Dimensions Product Summary www.renesas.com Rev. 0.93 Preliminary 5 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W 7 Ordering Information Part no. Options Package Description iW3658-00C1 iW3658-00D1 iW3658-00F 120VAC Input, 500V/3A MOSFET SO-7 Tape & Reel2 iW3658-06D1 iW3658-06F 120VAC Input, 500V/2A MOSFET SO-7 Tape & Reel2 iW3658-201 iW3658-20D1 iW3658-20F 120VAC Input, 500V/3A MOSFET, optimized for high power factor SO-7 Tape & Reel2 iW3658-211 iW3658-21D1 iW3658-21F 230VAC Input, 650V/2A MOSFET, optimized for high power factor SO-7 Tape & Reel2 iW3658-26D1 iW3658-26F 120VAC Input, 500V/2A MOSFET, optimized for high power factor SO-7 Tape & Reel2 iW3658-301 iW3658-30D1 iW3658-30F 120VAC Input, 500V/3A MOSFET, optimized for filament load SO-7 Tape & Reel2 iW3658-311 iW3658-31D1 iW3658-31F 230VAC Input, 650V/2A MOSFET, optimized for filament load SO-7 Tape & Reel2 iW3658-36D1 iW3658-36F 120VAC Input, 500V/2A MOSFET, optimized for filament load SO-7 Tape & Reel2 Note 1: Not recommended for new designs; use the -xxF version. Note 2: Tape and reel packing quantity is 2,500/reel. Minimum packing quantity is 2,500. Product Summary www.renesas.com Rev. 0.93 Preliminary 6 of 7 06-Feb-2022 © 2022 Renesas Electronics iW3658 Single-Stage SSL LED Driver with Integrated High Voltage MOSFET for Dimmable Retrofit Lamps up to 15W IMPORTANT NOTICE AND DISCLAIMER RENESAS ELECTRONICS CORPORATION AND ITS SUBSIDIARIES (“RENESAS”) PROVIDES TECHNICAL SPECIFICATIONS AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, WEB TOOLS, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for developers skilled in the art designing with Renesas products. You are solely responsible for (1) selecting the appropriate products for your application, (2) designing, validating, and testing your application, and (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. Renesas grants you permission to use these resources only for development of an application that uses Renesas products. Other reproduction or use of these resources is strictly prohibited. No license is granted to any other Renesas intellectual property or to any third party intellectual property. Renesas disclaims responsibility for, and you will fully indemnify Renesas and its representatives against, any claims, damages, costs, losses, or liabilities arising out of your use of these resources. Renesas’ products are provided only subject to Renesas’ Terms and Conditions of Sale or other applicable terms agreed to in writing. No use of any Renesas resources expands or otherwise alters any applicable warranties or warranty disclaimers for these products. © 2022 Renesas Electronics Corporation. All rights reserved. RoHS Compliance Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. (Rev.1.0 Mar 2020) Corporate Headquarters Contact Information TOYOSU FORESIA, 3-2-24 Toyosu Koto-ku, Tokyo 135-0061, Japan www.renesas.com For further information on a product, technology, the most up-to-date version of a document, or your nearest sales office, please visit: www.renesas.com/contact/ Trademarks Renesas and the Renesas logo are trademarks of Renesas Electronics Corporation. All trademarks and registered trademarks are the property of their respective owners. Product Summary www.renesas.com Rev. 0.93 Preliminary 7 of 7 06-Feb-2022 © 2022 Renesas Electronics
iW3658-06F 价格&库存
很抱歉,暂时无法提供与“iW3658-06F”相匹配的价格&库存,您可以联系我们找货
