SWD740D
SWD740D
    SAMWIN(芯派)
    TO-252(DPAK)
    耐压:400V 电流:10A
SWD740D 数据手册
SW740D N-channel Enhanced mode TO-220/TO-220F/TO-252 MOSFET Features ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ TO-220 High ruggedness Low RDS(ON) (Typ 0.4Ω)@VGS=10V Low Gate Charge (Typ 35nC) Improved dv/dt Capability 100% Avalanche Tested Application: LED, DC-DC TO-220F BVDSS : 400V TO-252 ID : 10A RDS(ON) : 0.4Ω 1 2 2 1 3 2 1 3 2 1 3 1. Gate 2. Drain 3. Source General Description 3 This power MOSFET is produced with advanced technology of SAMWIN. This technology enable the power MOSFET to have better characteristics, including fast switching time, low on resistance, low gate charge and especially excellent avalanche characteristics. Order Codes Item Sales Type Marking Package Packaging 1 SW P 740D SW740D TO-220 TUBE 2 SW F 740D SW740D TO-220F TUBE 3 SW D 740D SW740D TO-252 REEL Absolute maximum ratings Value Symbol Parameter Unit TO-220 VDSS ID TO-220F TO-252 Drain to source voltage 400 V Continuous drain current (@TC=25oC) 10* A Continuous drain current (@TC=100oC) 6.3* A 40 A ± 30 V IDM Drain current pulsed VGS Gate to source voltage EAS Single pulsed avalanche energy (note 2) 405 mJ EAR Repetitive avalanche energy (note 1) 40 mJ dv/dt Peak diode recovery dv/dt (note 3) 5 V/ns PD TSTG, TJ TL (note 1) Total power dissipation (@TC=25oC) Derating factor above 25oC 183.8 23.6 119 W 1.5 0.2 0.95 W/oC Operating junction temperature & storage temperature Maximum lead temperature for soldering purpose, 1/8 from case for 5 seconds. -55 ~ + 150 oC 300 oC *. Drain current is limited by junction temperature. Thermal characteristics Value Symbol Parameter Rthjc Thermal resistance, Junction to case Rthja Thermal resistance, Junction to ambient Copyright@ Semipower Technology Co., Ltd. All rights reserved. TO-220 TO-220F TO-252 0.68 5.3 1.05 58 50 May.2022. Rev. 4.0 Unit oC/W oC/W 1/7 SW740D Electrical characteristic ( TJ = 25oC unless otherwise specified ) Symbol Parameter Test conditions Min. Typ. Max. Unit Off characteristics BVDSS Drain to source breakdown voltage VGS=0V, ID=250uA 400 ΔBVDSS / ΔTJ Breakdown voltage temperature coefficient ID=250uA, referenced to 25oC IDSS Drain to source leakage current V V/oC 0.54 VDS=400V, VGS=0V 1 uA VDS=320V, TJ=125oC 50 uA Gate to source leakage current, forward VGS=30V, VDS=0V 100 nA Gate to source leakage current, reverse VGS=-30V, VDS=0V -100 nA 4.5 V 0.5 Ω IGSS On characteristics VGS(TH) Gate threshold voltage RDS(ON) Drain to source on state resistance Gfs Forward transconductance VDS=VGS, ID=250uA 2.5 VGS=10V, ID=5A, TJ=25oC 0.4 VGS=10V, ID=5A, TJ 0.9 Ω VDS=30V, ID=5A 8.5 S =125oC Dynamic characteristics Ciss Input capacitance Coss Output capacitance Crss Reverse transfer capacitance td(on) Turn on delay time tr td(off) tf Rising time Turn off delay time 1358 VGS=0V, VDS=25V, f=1MHz 161 pF 20 18 VDS=200V, ID=10A, RG=10Ω, VGS=10V (note 4,5) 44 ns 47 Fall time 31 Qg Total gate charge 35 Gate-drain charge VDS=320V, VGS=10V, ID=10A , IG=3mA (note 4,5) Qgs Gate-source charge Qgd Rg Gate resistance VDS=0V, Scan F mode 1.7 8 nC 15 Ω Source to drain diode ratings characteristics Symbol Parameter Test conditions IS Continuous source current ISM Pulsed source current Integral reverse p-n Junction diode in the MOSFET VSD Diode forward voltage drop. IS=10A, VGS=0V trr Reverse recovery time Qrr Reverse recovery charge IS=10A, VGS=0V, dIF/dt=100A/us Min. Typ. Max. Unit 10 A 40 A 1.4 V 355 ns 2.9 uC ※. Notes 1. Repeatitive rating : pulse width limited by junction temperature. 2. L =8.1mH, IAS =10A, VDD=50V, RG=25Ω, Starting TJ = 25oC 3. ISD ≤ 10A, di/dt = 100A/us, VDD ≤ BVDSS, Staring TJ =25oC 4. Pulse Test : Pulse Width ≤ 300us, duty cycle ≤ 2%. 5. Essentially independent of operating temperature. Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 2/7 SW740D Fig. 1. On-state characteristics Fig. 2. Transfer Characteristics Fig. 3. On-resistance variation vs. drain current and gate voltage Fig. 4. On-state current vs. diode forward voltage Fig 5. Breakdown voltage variation vs. junction temperature Fig. 6. On-resistance variation vs. junction temperature Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 3/7 SW740D Fig. 7. Gate charge characteristics Fig. 9. Maximum safe operating area(TO-220) Fig. 8. Capacitance Characteristics Fig. 10. Maximum safe operating area (TO-220F) Fig. 11. Maximum safe operating area (TO-252) Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 4/7 SW740D Fig. 12. Transient thermal response curve(TO-220) Fig. 13. Transient thermal response curve(TO-220F) Fig. 14. Transient thermal response curve(TO-252) Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 5/7 SW740D Fig. 15. Gate charge test circuit & waveform Fig. 16. Switching time test circuit & waveform VDS 90% RL RGS VDS VDD VIN 10VIN DUT 10% 10% td(on) tr td(off) tON tf tOFF Fig. 17. Unclamped Inductive switching test circuit & waveform Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 6/7 SW740D Fig. 18. Peak diode recovery dv/dt test circuit & waveform DUT + V DS 10V VGS (DRIVER) L IS di/dt IS (DUT) IRM VDS RG Diode reverse current VDD Diode recovery dv/dt Same type as DUT 10VGS VDS (DUT) *. dv/dt controlled by RG *. Is controlled by pulse period VDD VF Body diode forward voltage drop DISCLAIMER * All the data & curve in this document was tested in SEMIPOWER TESTING & APPLICATION CENTER. * This product has passed the PCT,TC,HTRB,HTGB,HAST,PC and Solderdunk reliability testing. * Qualification standards can also be found on the Web site (http://www.semipower.com.cn) * Suggestions for improvement are appreciated, Please send your suggestions to samwin@samwinsemi.com Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 4.0 7/7
SWD740D 价格&库存
很抱歉,暂时无法提供与“SWD740D”相匹配的价格&库存,您可以联系我们找货
