SBR2M60S1F
SBR2M60S1F
    LEIDITECH(雷卯电子)
    SMF(SOD-123FL)
    60V 2A
SBR2M60S1F 数据手册
SBR2M60S1F Super Barrier Rectifier Features ● Ideal for automated placement ● Superior Reverse Avalanche Capability ● +175°C Operation Junction Temperature ● Low power loss, high efficiency, High Reliability ● High temperature soldering guaranteed: SOD-123FL 260°C/10 seconds ● Component in accordance to RoHS 2011/65/EU and WEEE 2002/96/EC Marking Mechanical Date ● Case:SOD-123FL The plastic package carries Underwriters Laboratory K26H xx Flammability Classification 94V-0 ● Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 K26=Product Type Marking Code H = High junction temperature ● Polarity: Polarity symbols marked on case XX = Date Code ● Mounting Position: Any Maximum Ratings & Thermal Characteristics (TA=25℃ unless otherwise noted) Symbol SBR2M60S1F Unit Maximum repetitive peak reverse voltage VRRM 60 V Maximum RMS voltage VRMS 42 V Maximum DC blocking voltage VDC 60 V Average forward rectified current IF(AV) 2.0 A Peak forward surge current 8.3 ms single half sine-wave superimposed on rated load IFSM 50.0 A Thermal resistance from junction to lead (1) RθJL 25.0 ℃/W RθJA 80.0 ℃/W TJ ,TSTG -65 to +175 ℃ Items Thermal resistance from junction to ambient (1) Operating junction and storage temperature range Note 1:Mounted on P.C.B. with 0.036 x 0.06” (0.9 x 1.5mm) copper pad areas. Electrical Characteristics (TA Items = 25 °C unless otherwise noted) Test conditions Symbol (2) Instantaneous forward voltage IF=1A ,TJ=25℃ Reverse current VR=VDC (2) IF=2A ,TJ=25℃ TJ=25℃ TJ=125℃ VF IR Min Typ Max - 0.65 - - - 0.74 - 0.1 0.7 - 60.0 - Unit V μA Note 2: Pulse test:300μs pulse width,1% duty cycle. Rev 2.0 : 04.20.2021 1/3 www.leiditech.com SBR2M60S1F Fig.1 Foward Current Derating Curve 2.5 60 Peak Forward Surge Current (A) Average Forward Rectified Current (A) Characteristics Curves 2 1.5 1 0.5 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 50 40 30 20 10 0 0 0 30 60 90 120 150 1 180 Lead Temperature(°C) Instantaneous Reverse Leakage(μA) Instantaneous Forward Current (A) 1 0.1 0.01 100 Fig.4 Typical Reverse Characteristics Fig.3 Typical Forward Current Characteristics 10 10 Number of Cycles at 60Hz 100 10 TJ = 125 °C 1 0.1 0.01 TJ = 25 °C 0.001 0.4 Rev 2.0 : 04.20.2021 0.5 0.6 0.7 0.8 0.9 1.0 Instantaneous Forward Voltage (V) 0 2/3 20 40 60 80 100 Percent of Rated Peak Reverse Voltage (%) www.leiditech.com SBR2M60S1F Package Outline SOD-123FL 2.5(0.098) 2.9(0.114) Mounting Pad Layout 1.3 (0.051) 1.4 (0.055) 1.55(0.061) 1.95(0.077) 0.8(0.031) 1.2(0.047) 0.6(0.024) 0.05(0 .002) 0.25( 0.010 ) 1.0(0.039) Cathode Band 1.3 (0.051) 1.6 (0.062) 3.9 (0.154) 0.5(0.020) 1.1(0.043) max0.1(0.004) 3.5(0.138) 3.9(0.154) Dimensions in millimeters and(inches) Ordering Information Outline Reel (PCS) Taping 3,000 Per Carton (PCS) Reel Diameters (mm) 178/7″ Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev 2.0 : 04.20.2021 3/3 www.leiditech.com
SBR2M60S1F 价格&库存
很抱歉,暂时无法提供与“SBR2M60S1F”相匹配的价格&库存,您可以联系我们找货
