BK13C06-40DP/2-0.35V(868) 数据手册
COUNT
DESCRIPTION OF REVISIONS
RE-6-1422
8
APPLICABLE STANDARD
1
OPERATING
TEMPERATURE RANGE
BY
CHKD
DATE
JSH
JHW
19.05.31
STORAGE
TEMPERATURE RANGE
APPLICABLE
CONNECTOR
-55℃ TO +85℃(note1)
30 V AC/DC
RATING VOLTAGE
COUNT
BY
CHKD
DATE
-10℃ TO +60℃
BK13C06-40DS2-0.35V(**)
SIGNAL CONTACT 0.3A
POWER CONTACT 5.0A
CURRENT
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT AT
CONSTRUCTION
GENERAL EXAMINATION
CONFIRMED VISUALLY AND BY MEASURING
INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
X
X
X
X
X
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE
SIGNAL CONTACT : 50mΩ MAX
POWER CONTACT : 15mΩ MAX
20mV AC OR LESS 1kHz, 1mA
1
1
INSULATION RESISTANCE
100V DC
50MΩ MIN
X
VOLTAGE PROOF
100V AC FOR 1min.
NO FLASHOVER OR BREAKDOWN
X
X
X
X
X
X
X
X
MECHANICAL CHARACTERISTICS
INSERTION AND
WITHDRAWAL FORCE
1
MEASURED BY APPLICABLE CONNECTOR.
30TIMES INSERTION AND WITHDRAWAL.
TEST SPEED 10mm/min
① INSERTION FORCE : 40N MAX
(INITIAL AND AFTER TEST)
② WITHDRAWAL FORCE
INITIAL : 10N MIN (0.25N * PIN)
AFTERT TEST : 8N MIN (0.2N * PIN)
MECHANICAL
OPERATION
VIBRATION
SHOCK
30 TIMES INSERTIONS AND EXTRACTIONS.
① CONTACT RESISTANCE:
1
SIGNAL CONTACT : 70mΩ MAX
POWER CONTACT : 30mΩ MAX
② NO DAMAGE, CRACK OR LOOSENESS
OF PATRS.
① NO ELECTRICAL DISCONTINUITY OF 1μs.
OF PARTS.
OF PARTS.
1
FREQUENCY 10 TO 55 TO 10 Hz, APPROX 5min
SINGLE AMPLITUDE 0.75mm, 10CYCLES,
FOR 3 DIRECTIONS.
490 m/s² DURATION OF PULSE 11ms AT 3 TIMES
FOR 3 DIRECTIONS.
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
DAMP HEAT
(STEADY STATE)
SULPHUR DIOXIDE
TEMPERATURE -55 → +85℃
TIME
30 → 30 min
UNDER 5 CYCLES.
(RELOCATION TIME TO CHAMBER: WITHIN2~3 MIN)
SIGNAL CONTACT : 70mΩ MAX 1
② INSULATION RESISTANCE:
50MΩ MIN
③ NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
1
EXPOSED AT 40±2℃, 90 TO 95%, 96h.
25MΩ MIN
OF PARTS.
1
OF PARTS.
EXPOSED IN 25 PPM FOR 96h, 25℃, 75±5%RH.
(Test standard : JIS C 60068)
REMARKS
Note 1 : INCLUDE THE TEMPERATURE RISING BY CURRENT.
DRAWN
DESIGNED
CHECKED
APPROVED
S.H.JUNG
S.H.JUNG
H.W.JO
H.W.JO
RELEASED
ENG
19.05.31
Unless otherwise specified, refer to JIS C 5402 and IEC 60512
Note
QT: QUALIFICATION TEST
AT: ASSURANCE TEST
HIROSE KOREA CO.,LTD.
CODE NO.(OLD)
19.02.25
19.02.25
19.02.25
19.02.25
DEPT
X: APPLICABLE TEST
SPECIFICATION SHEET
DRAWING NO.
SLC4-632759-68
PART NO.
1
CODE NO.
CL 6665-0009-0-868
1
BK13C06-40DP/2-0.35V(868) 价格&库存
很抱歉,暂时无法提供与“BK13C06-40DP/2-0.35V(868)”相匹配的价格&库存,您可以联系我们找货
