UMW
R
AOD4130
60V N-Channel MOSFET
General Description
D
The AOD4130 combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON). This device is ideal for boost
converters and synchronous rectifiers for consumer,
telecom, industrial power supplies and LED
backlighting.
G
General Features
VDS
S
ID (at VGS=10V)
60V
30A
RDS(ON) (at VGS=10V)
< 24mΩ
RDS(ON) (at VGS=4.5V)
< 30mΩ
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
VDS
Drain-Source Voltage
VGS
Gate-Source Voltage
TC=25°C
Continuous Drain
Current
TC=100°C
Pulsed Drain Current
Continuous Drain
Current
IAS, IAR
Avalanche energy L=0.1mH C
TC=25°C
EAS, EAR
Power Dissipation
TA=25°C
Power Dissipation A
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Case
www.umw-ic.com
Steady-State
Steady-State
A
mJ
W
25
2.5
W
1.6
TJ, TSTG
-55 to 175
Symbol
t ≤ 10s
27
36.5
52
PDSM
TA=70°C
A
5
PD
TC=100°C
A
74
Avalanche Current C
B
V
6.5
IDSM
TA=70°C
±20
IDM
TA=25°C
Units
V
30
ID
C
Maximum
60
Typ
12.4
34
2.4
RθJA
RθJC
1
°C
Max
2.9
Units
°C/W
°C/W
°C/W
UTD Semiconductor Co.,Limited
UMW
R
AOD4130
Electrical Characteristics (TJ=25°C unless otherwise noted)
Symbol
Parameter
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
Min
Conditions
ID=250µA, VGS=0V
1
IGSS
Gate-Body leakage current
VDS=0V, VGS= ±20V
VGS(th)
Gate Threshold Voltage
VDS=5V, ID=250µA
1.6
ID(ON)
On state drain current
VGS=10V, VDS=5V
74
RDS(ON)
Static Drain-Source On-Resistance
VGS=10V, ID=20A
TJ=55°C
5
Forward Transconductance
VDS=5V, ID=20A
Diode Forward Voltage
IS=1A,VGS=0V
IS
Maximum Body-Diode Continuous Current G
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VGS=0V, VDS=0V, f=1MHz
SWITCHING PARAMETERS
Qg(10V) Total Gate Charge
Qg(4.5V) Total Gate Charge
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
tD(on)
Turn-On DelayTime
tr
Turn-On Rise Time
100
nA
2.8
V
24
30
mΩ
1
V
46
A
55
VGS=0V, VDS=30V, f=1MHz
VGS=10V, VDS=30V, ID=20A
µA
A
0.76
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Output Capacitance
2.2
19.5
24
VGS=4.5V, ID=20A
gFS
Units
V
VDS=60V, VGS=0V
Zero Gate Voltage Drain Current
VSD
Max
60
IDSS
Coss
Typ
mΩ
S
1265
1582
1900
pF
70
100
130
pF
40
67
95
pF
1.8
3.6
5.4
Ω
23
28.3
34
nC
11
13.4
16
nC
3.6
4.5
5.4
nC
4.3
7.2
10
nC
VGS=10V, VDS=30V, RL=1.5Ω,
RGEN=3Ω
7.5
ns
6.5
ns
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Body Diode Reverse Recovery Time
IF=20A, dI/dt=500A/µs
15
22
30
Qrr
Body Diode Reverse Recovery Charge IF=20A, dI/dt=500A/µs
53
76
100
33
ns
7.5
ns
ns
nC
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
Power dissipation PDSM is based on R θJA and the maximum allowed junction temperature of 150°C. The value in any given application depends
on the user's specific board design, and the maximum temperature of 175°C may be used if the PCB allow s it.
B. The power dissipation PD is based on TJ(MAX)=175°C, using junction-to-case thermal resistance, and is more useful in setting the upper
dissipation limit for cases where additional heatsinking is used.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=175°C. Ratings are based on low frequency and duty cycles to keep
initial TJ =25°C.
D. The RθJA is the sum of the thermal impedance from junction to case RθJC and case to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AOD4130”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83603
- 50+0.66096
- 150+0.57338
- 500+0.50771
- 2500+0.44810
- 5000+0.42185
