SWB046R08E8T
SWB046R08E8T
    SAMWIN(芯派)
    TO-263(D²Pak)
    N沟道 耐压:80V 电流:150A
SWB046R08E8T 数据手册
SW046R08E8T N-channel Enhanced mode TO-220/TO-263 MOSFET Features ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ TO-220 High ruggedness Low RDS(ON) (Typ 4.8mΩ)@VGS=10V Low Gate Charge (Typ 183nC) Improved dv/dt Capability 100% Avalanche Tested Application:Synchronous Rectification, Li Battery Protect Board, Inverter TO-263 BVDSS : 80V ID : 150A RDS(ON) : 4.8mΩ 2 1 2 1 3 2 3 1 1. Gate 2.Drain 3.Source General Description 3 This power MOSFET is produced with advanced technology of SAMWIN. This technology enable the power MOSFET to have better characteristics, including fast switching time, low on resistance, low gate charge and especially excellent avalanche characteristics. Order Codes Item Sales Type Marking Package Packaging 1 SW P 046R08E8T SW046R08E8T TO-220 TUBE 2 SW B 046R08E8T SW046R08E8T TO-263 TUBE Absolute maximum ratings Value Symbol Parameter Unit TO-220 VDSS Drain to source voltage Continuous drain current ID (@TC=25oC) Continuous drain current (@TC=100oC) 80 V 150* A 102* A 600 A ± 20 V IDM Drain current pulsed VGS Gate to source voltage EAS Single pulsed avalanche energy (note 2) 361 mJ EAR Repetitive avalanche energy (note 1) 30 mJ dv/dt Peak diode recovery dv/dt (note 3) 5 V/ns 227.3 W 1.8 W/oC -55 ~ + 150 oC 300 oC Total power dissipation PD TSTG, TJ TL (note 1) TO-263 (@TC=25oC) Derating factor above 25oC Operating junction temperature & storage temperature Maximum lead temperature for soldering purpose, 1/8 from case for 5 seconds. *. Drain current is limited by junction temperature. Thermal characteristics Value Symbol Parameter Unit TO-220 Rthjc Thermal resistance, Junction to case Rthja Thermal resistance, Junction to ambient Copyright@ Semipower Technology Co., Ltd. All rights reserved. TO-263 0.55 oC/W oC/W 50.5 May.2022. Rev. 0.6 1/6 SW046R08E8T Electrical characteristic ( TJ = 25oC unless otherwise specified ) Symbol Parameter Test conditions Min. Typ. Max. Unit Off characteristics Drain to source breakdown voltage VGS=0V, ID=250uA ΔBVDSS / ΔTJ BVDSS Breakdown voltage temperature coefficient ID=250uA, referenced to 25oC IDSS Drain to source leakage current 80 V V/oC 0.06 VDS=80V, VGS=0V 1 uA VDS=64V, TJ=125oC 50 uA Gate to source leakage current, forward VGS=20V, VDS=0V 100 nA Gate to source leakage current, reverse VGS=-20V, VDS=0V -100 nA 4 V 5.9 mΩ IGSS On characteristics VGS(TH) Gate threshold voltage RDS(ON) Drain to source on state resistance Gfs Forward transconductance VDS=VGS, ID=250uA 2 VGS=10V, ID=30A,TJ=25oC 4.8 VGS=10V, ID=30A,TJ=125oC 8.3 mΩ VDS=5V, ID=30A 60 S Dynamic characteristics Ciss Input capacitance Coss Output capacitance Crss Reverse transfer capacitance td(on) Turn on delay time tr td(off) tf Rising time Turn off delay time 8422 VGS=0V, VDS=40V, f=1MHz 660 pF 401 36 VDS=40V, ID=30A, RG=4.7Ω, VGS=10V (note 4,5) 85 ns 154 Fall time 63 Qg Total gate charge 183 Gate-drain charge VDS=64V, VGS=10V, ID=30A , IG=10mA (note 4,5) Qgs Gate-source charge Qgd Rg Gate resistance VDS=0V, Scan F mode 3.2 42 nC 67 Ω Source to drain diode ratings characteristics Symbol Parameter Test conditions IS Continuous source current ISM Pulsed source current Integral reverse p-n Junction diode in the MOSFET VSD Diode forward voltage drop. IS=45A, VGS=0V trr Reverse recovery time Qrr Reverse recovery charge IS=30A, VGS=0V, dIF/dt=100A/us Min. Typ. Max. Unit 150 A 600 A 1.4 V 46 ns 83 nC ※. Notes 1. Repeatitive rating : pulse width limited by junction temperature. 2. L =0.5mH, IAS =38A, VDD=50V, RG=25Ω, Starting TJ = 25oC 3. ISD ≤30A, di/dt = 100A/us, VDD ≤ BVDSS, Staring TJ =25oC 4. Pulse Test : Pulse Width ≤ 300us, duty cycle ≤ 2%. 5. Essentially independent of operating temperature. Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 2/6 SW046R08E8T Fig. 1. On-state characteristics Fig. 2. Transfer Characteristics Fig. 3. On-resistance variation vs. drain current and gate voltage Fig. 4. On-state current vs. diode forward voltage Fig 5. Breakdown voltage variation vs. junction temperature Fig. 6. On-resistance variation vs. junction temperature Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 3/6 SW046R08E8T Fig. 7. Gate charge characteristics Fig. 9. Maximum safe operating area Fig. 8. Capacitance Characteristics Fig. 10. Maximum drain current vs. case temperature Fig. 11. Transient thermal response curve Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 4/6 SW046R08E8T Fig. 12. Gate charge test circuit & waveform Fig. 13. Switching time test circuit & waveform VDS 90% RL RGS VDS VDD VIN 10VIN DUT 10% 10% td(on) tr tON td(off) tf tOFF Fig. 14. Unclamped Inductive switching test circuit & waveform Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 5/6 SW046R08E8T Fig. 15. Peak diode recovery dv/dt test circuit & waveform DUT + V DS 10V VGS (DRIVER) L IS di/dt IS (DUT) IRM VDS RG Diode reverse current VDD Diode recovery dv/dt Same type as DUT 10VGS VDS (DUT) *. dv/dt controlled by RG *. Is controlled by pulse period VDD VF Body diode forward voltage drop DISCLAIMER * All the data & curve in this document was tested in SEMIPOWER TESTING & APPLICATION CENTER. * This product has passed the PCT,TC,HTRB,HTGB,HAST,PC and Solderdunk reliability testing. * Qualification standards can also be found on the Web site (http://www.semipower.com.cn) * Suggestions for improvement are appreciated, Please send your suggestions to samwin@samwinsemi.com Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 6/6
SWB046R08E8T
物料型号: SW046R08E8T
器件简介: - 采用先进技术生产的功率MOSFET - 特点包括快速开关时间、低导通电阻、低栅极电荷和卓越的雪崩特性
引脚分配: - 1. Gate - 2. Drain - 3. Source
参数特性: - 断态电压(BVDSS): 80V - 导通电阻(RDS(ON)): 典型值4.8mΩ@VGS=10V - 栅极电荷(Qg): 典型值183nC - 封装类型: TO-220和TO-263
功能详解: - 适用于同步整流、锂电池保护板、逆变器等应用 - 100%雪崩测试 - 增强的dv/dt能力
应用信息: - 同步整流、锂电池保护板、逆变器等
封装信息: - TO-220和TO-263封装,提供两种销售类型,带有相应的标记和包装方式
SWB046R08E8T 价格&库存
很抱歉,暂时无法提供与“SWB046R08E8T”相匹配的价格&库存,您可以联系我们找货
