CMD100N03/CMU100N03
30V N-Channel MOSFET
General Description
Product Summary
The 100N03 uses advanced trench
BVDSS
RDSON
ID
30V
3.5mΩ
100A
technology to provide excellent RDS(ON)
and low gate charge. This device is
Applications
suitable for use as a wide variety of
Uninterruptible Power Supply
applications.
DC Motor Control
Load Switch
TO-252/251 Pin Configuration
Features
Simple Drive Requirement
D
Fast Switching
G
Low On-Resistance
S
TO-252
(CMD100N03)
Absolute Maximum Ratings
G
D
S
TO-251
(CMU100N03)
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
V
ID@TC=25
VGS
Continuous Drain Current
100
A
ID@TC=100
70
A
300
A
IDM
Gate-Sou ce Voltage
Pulsed Drain Current
1
2
EAS
Single Pulse Avalanche Energy
400
mJ
PD
Total Power Dissipation
100
W
TSTG
Storage Temperature Range
-55 to 175
TJ
Operating Junction Temperature Range
175
Thermal Data
Symbol
R
CA01P1
JC
Parameter
Thermal Resistance Junction-case
www.cmosfet.com
Typ.
Max.
Unit
1.36
/W
Page 1 of 2
CMD100N03/CMU100N03
Electrical Characteristics (TJ=25℃ , unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
Conditions
Min.
Typ.
Max.
Unit
V
VGS=0V , ID=250uA
30
VGS=10V , ID=20A
3.5
VGS=5V , ID=20A
6.0
RDS(ON)
Static Drain-Source On-Resistance
VGS(th)
Gate Threshold Voltage
VGS=VDS , ID =250uA
1
1.6
3
V
IDSS
Drain-Source Leakage Current
VDS=24V , VGS=0V
1
uA
IGSS
Gate-Source Leakage Current
VGS
100
nA
gfs
Forward Transconductance
VDS=16V , ID=26A
45
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
Ω
Qg
Total Gate Charge
I D = 30A
70
Qgs
Gate-Source Charge
V DD = 15 V
10
Qgd
Gate-Drain Charge
VGS = 10V
18
Turn-On Delay Time
V DD = 1 5 V
Rise Time
ID = 3 0 A
58
Turn-Off Delay Time
R G =12Ω
V GS=10V
120
90
5500
950
260
Min.
Typ.
Max.
Unit
100
A
300
A
1.2
V
Td(on)
Tr
Td(off)
Tf
Fall Time
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
20V , VDS=0V
VDS=15V , VGS=0V , f=1MHz
mΩ
nC
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Continuous Source Current
ISM
Pulsed Source Current
VSD
Diode Forward Voltage
Conditions
VG=VD=0V , Force Current
VGS=0V , IS=1 A , TJ=25℃
Note :
1.Repetitive rating; pulse width limited by maximum junction temperature
2.The test condition is V DD=15V,L=0.5mH,ID=40A
This product has been designed and qualified for the counsumer market.
Cmos assumes no liability for customers' product design or applications.
Cmos reserver the right to improve product design ,functions and reliability wihtout notice.
CA01P1
www.cmosfet.com
Page 2 of 2
很抱歉,暂时无法提供与“CMD100N03”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.75806
- 10+1.38982
- 30+1.23202
- 100+1.03524
- 500+0.90370
- 1000+0.85107
