AOD536
AOD536
    ELECSUPER(静芯微)
    TO-252(DPAK)
    1个N沟道 耐压:30V 电流:46A
AOD536 数据手册
AOD536 Rev-1.1 www.elecsuper.com SuperMOS –TO-252 30V BVDSS 7mΩ RDS(on) 39A ID, N-channel MOSFET 1. Description The AOD536 is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product AOD536 is Pb-free. 2. Features 30V, RDS(ON)=7mΩ(Typ), VGS=10V  RDS(ON)=10.5mΩ(Typ), VGS=4.5V  Material: Halogen free  Reliable and rugged  Use trench MOSFET technology  Avalanche Rated  High density cell design for low RDS(on)  Low leakage current 3. Applications  PWM applications 100% UIS TESTED!  Load switch  Power management in portable/desktop PCs  DC/DC conversion 4. Ordering Information Part Number Package Marking Material Packing Quantity per reel Flammability Rating AOD536 TO-252 ES536/lot Halogen free Tape & Reel 2,500 PCS UL 94V-0 Reel Size 13 inches 5. Pin Configuration and Functions Pin Function 1 Gate 3 Source 2 Drain Copyright© ElecSuper Incorporated Outline Circuit Diagram 2 D ESD536 lot 1 G 3 Contact Us S 1 / 7 AOD536 Rev-1.1 www.elecsuper.com 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameter Symbol Limit Unit Drain-Source Voltage BVDSS 30 V Gate-Source Voltage VGS ±20 V TC=25°C Continuous Drain Current TC=75°C TC=25°C Maximum Power Dissipation TC=75°C 39 ID A 30 31 PD W 19 Pulsed Drain Current a IDM 150 A Avalanche Current, Single Pulsed b IAS 19 A Avalanche Energy, Single Pulsed b EAS 54.2 mJ Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Thermal resistance ratings Single Operation Parameter Junction-to-Ambient Thermal Resistance Junction-to-Case Thermal Resistance Symbol Typ Max t ≤ 10 s RθJA 15 20 Steady State RθJC 3.3 4 Unit °C/W Note: a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1% b: EAS condition:Tj=25℃,VDD=30V,VG=10V,L=0.3mH,Rg=25Ω Copyright© ElecSuper Incorporated Contact Us 2 / 7 AOD536 Rev-1.1 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS=0V, ID=250uA 30 V Zero Gate Voltage Drain Current IDSS VDS=30V, VGS=0V 1.0 uA Gate-to-source Leakage Current IGSS VDS=0V, VGS=±20V ±100 nA 1.4 1.8 V VGS=10V, ID=20A 7 12 VGS=4.5V, ID=20A 10.5 18 ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) Forward Trans conductance gFS VGS=VDS, ID=250uA 1.0 VDS=5.0V, ID=20A 100 mΩ S CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS 1150 VGS=0V, f=1MHz, VDS=15V Output Capacitance COSS Reverse Transfer Capacitance CRSS 45 QG(TOT) 15 Total Gate Charge Gate-to-Source Charge QGS Gate-to-Drain Charge QGD VGS=4.5V, VDS=15V, ID=20A 400 pF 3 nC 2.5 SWITCHING CHARACTERISTICS Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time td(ON) tr td(OFF) 7.6 VGS=10V, VDS=20V, RL=0.75Ω, RG=6Ω tf 13.5 ns 18 4.6 BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, IS=1.9A Contact Us 0.7 1.5 V 3 / 7 AOD536 Rev-1.1 www.elecsuper.com 7. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 4 / 7 AOD536 Copyright© ElecSuper Incorporated Rev-1.1 Contact Us www.elecsuper.com 5 / 7 AOD536 Rev-1.1 www.elecsuper.com 8. Dimension (TO-252) D1 L3 θ2 c E L Φ D3 h θ1 D2 e L2 L4 L1 θ b A1 A D SYMBOL MILLIMETER MIN Typ. MAX A 2.200 2.300 2.400 A1 0.000 b 0.640 C(电镀后) D SYMBOL MILLIMETER MIN Typ. MAX h 0.000 0.100 0.200 0.127 L 9.900 10.100 10.300 0.690 0.740 L1 0.460 0.520 0.580 L2 6.500 6.600 6.700 L3 2.888 REF 1.400 1.550 1.700 1.600 REF D1 5.334 REF L4 0.600 0.800 1.000 D2 4.826 REF Φ 1.100 1.200 1.300 D3 3.166 REF θ 0° E e 6.000 6.100 6.200 2.286 TYP Copyright© ElecSuper Incorporated Contact Us 8。 θ1 9°TYP θ2 9°TYP 6 / 7 AOD536 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
AOD536
物料型号:AOD536
器件简介: - AOD536是一款N-Channel增强型MOS场效应晶体管,采用先进的沟槽技术和设计,具有出色的RDS(ON)和低栅极电荷。 - 适用于DC-DC转换、电源开关和充电电路。 - 标准产品AOD536无铅。
引脚分配: - 1号引脚:栅极(Gate) - 2号引脚:漏极(Drain) - 3号引脚:源极(Source)
参数特性: - 漏源电压(BVpss):30V - 栅源电压(VGs):+20V - 连续漏电流(ID):在25°C时为39A,75°C时为30A - 最大功耗(Po):在25°C时为31W,75°C时为19W - 脉冲漏电流(loM):150A - 雪崩电流(IAs):19A - 雪崩能量(EAS):54.2mJ - 工作结温(TJ):150°C - 引脚温度(TL):260°C - 存储温度范围(Tstg):-55至150°C
功能详解: - 器件具有高密度单元设计,以降低RDS(on)。 - 使用沟槽MOSFET技术。 - 适用于PWM应用、负载开关、便携式/桌面PC的电源管理。
应用信息: - PWM应用 - 负载开关 - 便携式/桌面PC的电源管理 - DC/DC转换
封装信息: - 封装类型:TO-252 - 标记:ES536/lot - 材料:无卤素 - 包装:胶带和卷轴,每卷2500件 - 阻燃等级:UL 94V-0 - 卷轴尺寸:13英寸
AOD536 价格&库存
很抱歉,暂时无法提供与“AOD536”相匹配的价格&库存,您可以联系我们找货
