SB1060L
SB1060L
    TWGMC(迪嘉)
    TO-277
    电压:60V 电流:10A
SB1060L 数据手册
SB1045L THRU SB10150L Reverse Voltage - 45 to 150 Volts Forward Current -10.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features  Schottky Barrier Chip  High Thermal Reliability  Patented Super Barrier Rectifier Technology  High Forward Surge Capability  Ultra Fow Power Loss,High Efficiency TO-277 2 3 1  Excellent High temperature Stability  Plastic material-UL flammability 94V-0 Mechanical Data  Case : JEDEC TO-277 Molded plastic body  Terminals :Plated Leads Solderable per MIL-STD-202,Method 208  Polarity : Polarity symbol marking on body  Mounting Position : Any  Weight : 0.003 ounce, 0.092 grams Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SB1045L SB1050L SB1060L SB1080L SB10100L SB10150L SB1045L SB1050L SB1060L SB1080L SB10100L SB10150L 45 50 60 80 100 150 V 32 35 42 56 70 105 10 V A 150 A UNIT SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum working peak reverse voltage Maximum DC blocking voltage RMS Reverse voltage Average Rectified Output Current Non-Repetitive Peak Forward Surge8.3ms Single Half Sine-Wave Superimposed on rated load(JEDEC Method) Forward Voltage Drop at 10.0A TA=25℃ VRRM VRWM VDC VRMS I(O) IFSM VF 0.5 0.55 0.75 0.3 15 Peak reverse curent TA=25℃ IR TA=125℃ at rated DC blocking voltage Typical thermal resistance RθJA RθJL Junctionto Ambient Operating junction and storage temperature range TJ,TSTG 80 15 -55 to +150 Note:1.Valid Provided that are kept at ambient temperature at a distance of 9.5mm from the case. 2.Fr-4pcb.2oz.Copper,minimum recommend pad layout .18.8mm×14.4.Anode pad dimensions 5.6mm×14.4m m. www.tw-gmc.com 1 0.78 V mA ℃/W ℃ SB1045L THRU SB10150L Reverse Voltage - 45 to 150 Volts Forward Current -10.0 Ampere Typical Characteristics Fig2 : Instantaneous Forward Voltage 100 IF(A) Average Forward Current,I F ( AV ) (A) Fig.1 - Forward Current Derating Curve 12 Based on Lead Temp(T L ) SB1045L-SB1050L 8 SB1060L 10 4 SB1080L-SB10100L 1.0 0 25 5 50 75 125 100 0 150 175 Ambient Temperature,T A ( O C) TA =25 ℃ SB10150L 0.1 0 0.2 0.6 0.8 1.0 VF(V) Fig4: Typical Reverse Characteristics IRRM(mA) Fig3: Surge Forward Current Capadility IFSM(A) 0.4 300 250 100 10 ℃ TA =100 200 150 1.0 100 0.1 50 TA =25 0 1 2 10 20 100 Number of Cycles 0.01 0 20 40 60 80 100 VRM(%) www.tw-gmc.com 2 SB1045L THRU SB10150L Reverse Voltage - 45 to 150 Volts Forward Current -10.0 Ampere Package Dimension TO-277 Units: mm D D2 A b2 L W1 E W E1 E2 L1 e b1 W2 A2 b1 NO Dimensions NO Dimensions A 1.10±0.10 e 1.8Typ A2 0.30±0.10 E1 5.40±0.10 b1 0.9±0.10 E2 3.6±0.20 b2 1.8±0.10 L/L1 0.6±0.10 D 4.00±0.10 W 1.2±0.2 D2 3.15Typ W1 0.50±0.20 E 6.50±0.10 W2 1.3±0.2 All Dimensions in mm www.tw-gmc.com 3
SB1060L 价格&库存
很抱歉,暂时无法提供与“SB1060L”相匹配的价格&库存,您可以联系我们找货
SB1060L
    • 1+1.32000
    • 100+1.01530
    • 1250+0.84700
    • 2500+0.76890
    • 5000+0.71390
    库存:4970
    SB1060L
    • 5+1.49429
    • 50+1.23304
    • 150+1.12104
    • 500+0.98129
    • 2500+0.81022
    • 5000+0.77285
    库存:9563
