FQD17P06-VB
FQD17P06-VB
    VBSEMI(微碧)
    TO-252(DPAK)
    1个P沟道 耐压:60V 电流:30A
FQD17P06-VB 数据手册
FQD17P06 www.VBsemi.com P-Channel 60-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) - 60 RDS(on) (Ω) ID (A) 0.061 at V GS = - 10 V - 30 0.072 at VGS = - 4.5 V - 25 • TrenchFET® Power MOSFET • 100 % UIS Tested Qg (Typ) APPLICATIONS 10 • Load Switch S TO-252 G G D S Top View D P-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted Parameter Gate-Source Voltage Continuous Drain Current (TJ = 175 °C) TC = 25 °C TC = 100 °C Symbol Limit Unit VGS ± 20 V - 30 ID - 25 IDM - 30 Continuing Source Current (Diode Conduction) IS - 20 Avalanche Current IAS - 20 Pulsed Drain Current Single Pulse Avalanche Energy Maximum Power Dissipation L = 0.1 mH TC = 25 °C TA = 25 °C EAS 7.2 mJ 34a PD W 4b TJ, Tstg Operating Junction and Storage Temperature Range A - 55 to 175 °C THERMAL RESISTANCE RATINGS Parameter Junction-to-Ambientb Junction-to-Case Symbol t ≤ 10 sec Steady State RthJA RthJC Typical Maximum 20 25 62 75 5 6 Unit °C/W Notes: a. See SOA curve for voltage derating. b. Surface Mounted on 1" x 1" FR-4 boad. 服务热线:400-655-8788 1 FQD17P06 www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min V(BR)DSS VGS = 0 V, ID = - 250 µA - 60 VGS(th) VDS = VGS, ID = - 250 µA - 1.0 IGSS VDS = 0 V, VGS = ± 20 V Typa Max - 2.0 - 3.0 Unit Static Drain-Source Breakdown Voltage Gate Threshold Voltage Gate-Body Leakage IDSS Zero Gate Voltage Drain Current On-State Drain Currentb Drain-Source On-State Resistance b Forward Transconductance Dynamic rDS(on) Input Capacitance Ciss Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Rg Timec td(on) Turn-Off Delay Timec td(off) Turn-On Delay Fall Timec - 50 VDS = - 60 V, VGS = 0 V, TJ = 175 °C - 150 VDS = - 5 V, VGS = - 10 V tr - 10 nA µA A VGS = - 10 V, ID = - 5 A 0.061 VGS = - 10 V, ID = - 5 A, TJ = 125 °C 0.100 VGS = - 10 V, ID = - 5 A, TJ = 175 °C 0.150 VGS = - 4.5 V, ID = - 2 A 0.072 VDS = - 15 V, ID = - 5 A 8 gfs Output Capacitance Rise Timec -1 VDS = - 60 V, VGS = 0 V, TJ = 125 °C ID(on) b ± 100 VDS = - 60 V, VGS = 0 V V Ω S 1000 VDS = - 25 V, VGS = 0 V, f = 1 MHz pF 120 100 10 VDS = - 30 V, VGS = - 10 V, ID = - 8.4 A 2.1 f = 1 MHz 8.0 nC 3.2 Ω 6 VDD = - 30 V, RL = 3.57 Ω ID ≅ - 8.4 A, VGEN = - 10 V, RG = 2.5 Ω tf 15 ns 16 8 b Source-Drain Diode Ratings and Characteristics (TC = 25 °C) Pulsed Current ISM Forward Voltageb VSD Reverse Recovery Time trr Reverse Recovery Time Qrr IF = - 2 A, VGS = 0 V IF = - 8 A, di/dt = 100 A/µs - 0.9 - 30 A - 1.3 V 50 ns 80 nC Notes: a. Guaranteed by design, not subject to production testing. b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 FQD17P06 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C unless noted 20 30 TC = - 55 °C VGS = 10 thru 5 V 25 °C 16 ID - Drain Current (A) I D - Drain Current (A) 24 4V 18 12 3V 12 125 °C 8 4 6 2V 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 0 2 4 6 8 10 -VGS - Gate-to-Source Voltage (V) -VDS - Drain-to-Source Voltage (V) Output Characteristics Transfer Characteristics 12 0.12 TC = - 55 °C 0.10 25 °C rDS(on) - On-Resistance (Ω) g fs - Transconductance (S) 10 125 °C 8 6 4 2 VGS = 4.5 V 0.08 VGS = 10 V 0.07 0.05 0.03 0 0.01 0 2 4 6 8 10 0 4 8 -ID - Drain Current (A) 16 20 -ID - Drain Current (A) Transconductance On-Resistance vs. Drain Current 800 20 V GS - Gate-to-Source Voltage (V) 700 600 C - Capacitance (pF) 12 Ciss 500 400 300 200 Coss 100 Crss 0 0 VDS = 30 V ID = 8.4 A 16 12 8 4 0 10 20 30 40 50 -VDS - Drain-to-Source Voltage (V) Capacitance 60 0 5 10 15 20 25 Qg - Total Gate Charge (nC) Gate Charge 服务热线:400-655-8788 3 FQD17P06 www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C unless noted 2.3 2.0 10 VGS = 10 V ID = 50 A TJ = 150 °C I S - Source Current (A) rDS(on) - On-Resistance (Normalized) 1 1.7 1.4 1.1 0.1 TJ = 25 °C 0.01 0.8 0.5 - 50 0.001 - 25 0 25 50 75 100 125 150 175 0.0 0.2 TJ - Junction Temperature (°C) 0.4 0.6 0.8 1.0 -VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage THERMAL RATINGS 10 100 8 10 I D - Drain Current (A) I D - Drain Current (A) 10 µs 6 4 1 ms 1 10 ms 100 ms, DC 0.1 TC = 25 °C Single Pulse 0.01 2 0 100 µs *Limited by rDS(on) 0.001 0 25 50 75 100 125 150 TC - Case Temperature (°C) Drain Current vs. Case Temperature 175 0.1 *VGS 1 10 100 -VDS - Drain-to-Source Voltage (V) minimum VGS at which rDS(on) is specified Safe Operating Area 服务热线:400-655-8788 4 FQD17P06 www.VBsemi.com THERMAL RATINGS 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-−4 10- 3 10- 2 10- 1 1 10 100 600 100 600 Square Wave Pulse Duration (sec) Normalized Thermal Transient Impedance, Junction-to-Ambient 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-−4 10- 3 10- 2 10- 1 1 10 Square Wave Pulse Duration (sec) Normalized Thermal Transient Impedance, Junction-to-Case 服务热线:400-655-8788 5 FQD17P06 www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 C 0.46 0.61 0.018 0.024 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 - E 6.35 6.73 0.250 0.265 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC 0.090 BSC e1 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 服务热线:400-655-8788 6 FQD17P06 www.VBsemi.com RECOMMENDED MINIMUM PADS FOR DPAK (TO-252) 0.224 0.243 0.087 (2.202) 0.090 (2.286) 0.420 (10.668) (6.180) (5.690) 0.180 0.055 (4.572) (1.397) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 7 FQD17P06 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
FQD17P06-VB
物料型号为 FQD17P06,是一款 P-Channel 60-V (D-S) MOSFET。
器件简介包括 TrenchFET® Power MOSFET 和 100% UIS Tested。
其应用领域包括负载开关(Load Switch)。
引脚分配上,PDF 中展示了 TO-252 封装的顶视图,标注了 S(源极)、G(栅极)和 D(漏极)。
参数特性包括: - 绝对最大额定值:例如,栅源电压 VGS 为 ±20V,连续漏源电流 ID 在 TC=25°C 时为 -30A,在 TC=100°C 时为 -25A。
- 热阻:例如,结到环境 RthJA 在 ≤10 秒时为 20°C/W,稳态时为 62°C/W,结到外壳 RthJC 为 56°C/W。
- 静态和动态电气特性:例如,阈值电压 VGS(th) 在 VDS = VGS, ID = -250 µA 条件下,范围在 -1.0 到 -3.0V。
功能详解涉及: - 导通状态:例如,在 VGS = -10V, ID = -5A 时,漏源导通电阻 rDS(on) 典型值为 0.100Ω。
- 动态特性:例如,输入电容 Ciss 在 VDS = -25V, VGS = 0V, f = 1MHz 时为 1000pF。
应用信息包括使用场景,如作为负载开关。
封装信息提供了 TO-252AA 的尺寸细节,例如,引脚间距、外壳尺寸等。
请注意,这是根据提供的 PDF 文件内容进行的中文分析,实际应用和设计时需要详细查阅并理解数据手册中的所有规格和条件。
