P-Channel Enhancement Mode Power MOSFET
RC407
Description
The RC407 uses advanced trench technology and
design to provide excellent RDS(ON) with low gate charge .This
device is well suited for use as a load switch or in PWM
applications.
General Features
Schematic diagram
● VDS =-60V,ID =-18A
RDS(ON) Typ 60mΩ @ VGS=-10V
RDS(ON) Typ 70mΩ @ VGS=-4.5V
● High density cell design for ultra low Rdson
● Fully characterized avalanche voltage and current
● Excellent package for good heat dissipation
Application
Marking and pin assignment
● Load switch
● PWM application
100% UIS TESTED!
100% ∆Vds TESTED!
TO-252 -2Ltop view
Package Marking and Ordering Information
Device Marking
RC407
Device
Device Package
RC407
Reel Size
TO-252-2L
Tape width
Quantity
Absolute Maximum Ratings (TC=25℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
VDS
-60
V
Gate-Source Voltage
VGS
±20
V
Drain Current-Continuous
ID
-18
A
Pulsed Drain Current
IDM
-64
A
Maximum Power Dissipation
PD
32
W
0.21
W/℃
EAS
65
mJ
TJ,TSTG
-55 To 175
RθJC
4.68
℃/W
Derating factor
Single pulse avalanche energy
(Note 5)
Operating Junction and Storage Temperature Range
Thermal Characteristic
Thermal Resistance, Junction-to-Case(Note 2)
Page1
www.realchip.net
RC407
Electrical Characteristics (TC=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=-250μA
-60
V
Zero Gate Voltage Drain Current
IDSS
VDS=-60V,VGS=0V
-1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=-250μA
-1.0
-1.8
-2.0
V
Drain-Source On-State Resistance
RDS(ON)
VGS=-10V, ID=-8A
60
80
mΩ
VGS=-4.5V, ID=-6A
70
90
mΩ
VDS=-5V,ID=-8A
15
S
1108
PF
73.7
PF
58.2
PF
8
nS
Off Characteristics
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
gFS
(Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
VDS=-30V,VGS=0V,
F=1.0MHz
Crss
(Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=-30V, RL=3.75Ω,
4
nS
td(off)
VGS=-10V,RG=3Ω
32
nS
7
nS
23.4
nC
4.1
nC
4.8
nC
-1.2
V
-16
A
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=-30,ID=-8A,
VGS=-10V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
Diode Forward Current
(Note 2)
Reverse Recovery Time
Reverse Recovery Charge
VSD
VGS=0V,IS=-16A
IS
trr
Qrr
TJ = 25°C, IF =- 8A
(Note3)
di/dt = -100A/μs
25
nS
31
nC
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
Page2
www.realchip.net
RC407
Test Circuit
1) EAS Test Circuit
2) Gate Charge Test Circuit
3) Switch Time Test Circuit
Page3
www.realchip.net
RC407
-ID- Drain Current (A)
Normalized On-Resistance
Typical Electrical and Thermal Characteristics (Curves)
TJ-Junction Temperature(℃)
-Vds Drain-Source Voltage (V)
Figure 4 Rdson-Junction Temperature
-Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Rdson On-Resistance(mΩ)
-Is- Reverse Drain Current (A)
- ID- Drain Current (A)
-Vsd Source-Drain Voltage (V)
Figure 3 Rdson- Drain Current
Figure 6 Source- Drain Diode Forward
Page4
www.realchip.net
C Capacitance (pF)
RC407
Figure 7 Capacitance vs Vds
Figure 9 BVDSS vs Junction Temperature
Figure 8 Safe Operation Area
Figure 10 ID Current De-rating
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
Page5
www.realchip.net
RC407
TO-252 Package Information
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
2.200
2.400
0.087
0.094
A1
0.000
0.127
0.000
0.005
b
0.660
0.860
0.026
0.034
c
0.460
0.580
0.018
0.023
D
6.500
6.700
0.256
0.264
D1
5.100
5.460
0.201
0.215
D2
4.830 TYP.
0.190 TYP.
E
6.000
6.200
0.236
0.244
e
2.186
2.386
0.086
0.094
L
9.800
10.400
0.386
0.409
L1
L2
2.900 TYP.
1.400
L3
0.114 TYP.
1.700
0.055
1.600 TYP.
0.067
0.063 TYP.
L4
0.600
1.000
0.024
0.039
Φ
1.100
1.300
0.043
0.051
θ
0°
8°
0°
8°
h
0.000
0.300
0.000
0.012
V
5.350 TYP.
0.211 TYP.
Page6
www.realchip.net
很抱歉,暂时无法提供与“RC407”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.66450
- 50+1.39234
- 150+1.27570
