HS96L03W2C03
HS96L03W2C03
    HS(汉昇)
    外形:27.3*27.8;IIC/3SPI/4SPI串口通讯,4PIN黑底白光。
HS96L03W2C03 数据手册
 深圳市汉昇实业有限公司 深圳市汉昇实业有限公司 SHENZHEN HANSHENG INDUSTRAIL CO.LTD., HS96L03 规格书 DATASHEET 制作 审核 汉昇 HS 版本:VER 1.0 深圳市汉昇实业有限公司 地址:深圳市南山区西丽镇牛成村 208 栋亿莱工业大厦 5 楼 电话:0755-86114312/86114313/86114313 传真:0755-86114314 网址:www.hslcm.com 批准 Revised History Part Number ,^ϵϲ>Ϭϯ Revision A Revision Content New Revised on 2018-03-29 2 TABLE OF Contents Part Name: OLED Display Module................................................................................................................1 1. Basic Specifications......................................................................................................................................5 2. 3. 1.1 Display Specifications.................................................................................................................. 5 1.2 Mechanical Specifications........................................................................................................... 5 1.3 Active Area / Memory Mapping & Pixel Construction................................................................5 1.4 Mechanical Drawing....................................................................................................................6 1.5 Pin Definition...............................................................................................................................7 1.6 product picture............................................................................................................................7 1.7 Schematic Diagram.................................................................................................................8 Absolute Maximum Ratings........................................................................................................................ 9 Optics & Electrical Characteristics.............................................................................................................10 3.1 Optics Characteristics................................................................................................................10 3.2 DC Characteristics......................................................................................................................10 3.3 AC Characteristics......................................................................................................................11 3.3.1 4. 5. 6. 7. I2C Interface Timing Characteristics:............................................................................... 11 Functional Specification............................................................................................................................ 12 4.1 Commands.................................................................................................................................12 4.2 VCC Generated by Internal DC/DC Circuit.................................................................................13 Reliability................................................................................................................................................... 18 5.1 Contents of Reliability Tests......................................................................................................18 5.2 Failure Check Standard..............................................................................................................18 Outgoing Quality Control Specifications................................................................................................... 18 6.1 Environment Required.............................................................................................................. 18 6.2 Sampling Plan............................................................................................................................ 19 6.3 Criteria & Acceptable Quality Level.......................................................................................... 19 6.3.1 Cosmetic Check (Display Off) in Non-Active Area............................................................. 19 6.3.2 Cosmetic Check (Display Off) in Active Area..................................................................... 19 6.3.3 Pattern Check (Display On) in Active Area........................................................................ 21 Precautions When Using These OEL Display Modules............................................................................. 22 7.1 Handling Precautions................................................................................................................ 22 3 7.2 Storage Precautions.................................................................................................................. 23 7.3 Designing Precautions...............................................................................................................23 7.4 Precautions when disposing of the OEL display modules.........................................................24 7.5 Other Precautions..................................................................................................................... 24 Notice:................................................................................................................................................................25 Notice: 4 1. Basic Specifications 1.1Display Specifications 1) 2) 3) Display Mode: Display Color: Drive Duty: Passive Matrix Monochrome (White) 1/64 Duty 1.2Mechanical Specifications 1) Outline Drawing: According to the annexed outline drawing 2) 3) 4) 5) 6) Number of Pixels: PCB Size: Active Area: Pixel Pitch: Pixel Size: 128  64 27.327.8 2.65 (mm) 21.744  10.864 (mm) 0.17  0.17 (mm) 0.154  0.154 (mm) 1.3Active Area / Memory Mapping & Pixel Construction 5 1.5Pin Definition PIN No. Symbol 1 GND 2 3 4 Description Power Supply for OLED Ground of Logic Circui This is a ground pin. It must be connected to Ground Power Supply for OLED This is a voltage supply pin. It must be connected to Source The serial clock input SCL The serial data input SDA VCC SCL SDA 1.6product picture Top view Bottom view 7 1.7 Schematic Diagram The I2C communication interface consists of slave address bit DC, I2C-bus data signal SDA (SDAOUT/D2 for output and SDAIN/D1 for input) and I2C-bus clock signal SCL (D0). Both the data and clock signals must be connected to pull-up resistors. a) Slave address bit (SA0) has to recognize the slave address before transmitting or receiving any information by the I2C-bus. The device will respond to the slave address following by the slave address bit (“SA0” bit) and the read/write select bit (“R/W#” bit) with the following byte format, b7 b6 0 1 b5 1 b4 1 b3 b2 b1 b0 1 0 SA0 R/W# b)“SA0” bit provides an extension bit for the slave address. Either “0111100” or “0111101”, can be selected as the slave address of OLED. D/C# pin acts as SA0 for slave address selection.“R/W#” bit is used to determine the operation mode of the I2C-bus interface. R/W#=1, it is in read mode. R/W#=0, it is in write mode 0x3C 0 1 1 1 1 00 0 (=0x78) DC=0 0x3D 0 1 1 1 1 01 0 (=0x7A) DC=1 8 The default The user needs to switch the resistance position to modify the IIC address 2. Absolute Maximum Ratings Parameter Symbol Min Max Unit Notes Supply Voltage for Display VCC 3 5 V 1, 2 Supply Voltage for Logic SCL/SDA 1.65 3.3 V Operating Temperature TOP -40 80 C Storage Temperature TSTG -40 85 C 3 Life Time (120 cd/m2) 10,000 - hour 4 Life Time (80 cd/m ) 30,000 - hour 4 Life Time (60 cd/m2) 50,000 - hour 4 2 Note 1: All the above voltages are on the basis of “GND = 0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage of the module may occur. Also, for normal operations, it is desirable to use this module under the conditions according to Section 3. “Optics & Electrical Characteristics”. If this module is used beyond these conditions, malfunctioning of the module can occur and the reliability of the module may deteriorate. Note 3: The defined temperature ranges do not include the polarizer. The maximum withstood temperature of the polarizer should be 80C. Note 4: VCC = 3.3 V, Ta = 25°C, 50% Checkerboard. Software configuration follows Section 4.4 Initialization. End of lifetime is specified as 50% of initial brightness reached. The average operating lifetime at room temperature is estimated by the accelerated operation at high temperature conditions. 9 3.Optics & Electrical Characteristics 3.1Optics Characteristics Characteristics Symbol Conditions Min Typ Max Unit Lbr Note 5 150 - - cd/m2 Lbr Note 6 150 180 - cd/m2 C.I.E. (x) (y) C.I.E. 1931 0.28 0.31 0.32 0.35 0.36 0.39 Dark Room Contrast CR - 2000:1 - - Free - Brightness (VCC Supplied Externally) Brightness (VCC Generated Internal DC/DC) Viewing Angle degree * Optical measurement taken at VDD = 2.8V, VCC = 7.25V. Software configuration follows Section 4.2 Initialization. 3.2DC Characteristics Characteristics Symbol Supply Voltage for Logic VDD Supply Voltage for Display (Supplied Externally) VCC Supply Voltage for DC/DC VBAT Supply Voltage for Display (Generated by Internal DC/DC) Min Typ Max Unit 1.65 2.8 3.3 V 11.5 12 12.5 V Internal DC/DC Enable 3.5 - 4.2 V VCC Note 6 (Internal DC/DC Enable) 7.0 - 7.5 V High Level Input VIH IOUT = 100μA, 3.3MHz 0.8xVDD - VDD V Low Level Input VIL IOUT = 100μA, 3.3MHz 0 - 0.2xVDD V High Level Output VOH IOUT = 100μA, 3.3MHz 0.9xVDD - VDD V Low Level Output VOL IOUT = 100μA, 3.3MHz 0 - 0.1xVDD V Operating Current for VDD IDD - 180 300 uA Operating Current for VCC (VCC Supplied Externally) Operating Current for VBAT (VCC Generated by Internal DC/DC) Conditions Note 5 (Internal DC/DC Disable) ICC Note 7 - 9 15 mA IBAT Note 8 - 25.6 32 mA Sleep Mode Current for VDD IDD,SLEEP - 1 5 uA Sleep Mode Current for VCC ICC,SLEEP - 2 10 uA 10 Note 5 & 6: Brightness (Lbr) and Supply Voltage for Display (VPP) are subject to the change of the panel characteristics and the customer’s request. Note 7: VDD = 2.8V, VCC = 12V, 100% Display Area Turn on. Note 8: VDD = 2.8V, VCC = 7.25V, 100% Display Area Turn on. * Software configuration follows Section 4.2 Initialization. 3.3AC Characteristics 3.3.1 I2C Interface Timing Characteristics: Symbol tcycle tHSTART tHD tSD tSSTART tSSTOP tR tF tIDLE Description Min Max Unit Clock Cycle Time 2.5 - μs Start Condition Hold Time 0.6 - μs - ns Data Hold Time (for “SDAOUT” Pin) 0 Data Hold Time (for “SDAIN” Pin) 300 Data Setup Time 100 - ns Start Condition Setup Time (Only relevant for a repeated Start condition) 0.6 - μs Stop Condition Setup Time 0.6 - μs Rise Time for Data and Clock Pin 300 ns Fall Time for Data and Clock Pin 300 ns - μs Idle Time before a New Transmission can Start 11 1.3 4. Functional Specification 4.1Commands D/C# Hex D7 D6 D5 D4 D3 0 81 1 0 0 0 0 0 A[7:0] A7 A6 A5 A4 A3 0 0 D2 D1 D0 Command Description 0 0 1 Set Contrast Control Double byte command to select 1 out of 256 A2 A1 A0 contrast steps. Contrast increases as the value increases. (RESET = 7Fh ) DB 1 1 0 1 1 0 1 1 A[7:0 0 A6 A5 A4 0 0 0 0 1 0 1 0 0 1 1 X0 Set Normal/Inverse A6h, X[0]=0b: Normal display (RESET) 0 in RAM: OFF in display panel 1 Display Set VCOMH Deselect Level ] 0 A6/A7 A[6:4] 000b 010b 011b Hex code 00h 20h 30h V COMH deselect level ~ 0.65 x VCC ~ 0.77 x VCC (RESET) ~ 0.83 x VCC in RAM: ON in display panel A7h, X[0]=1b: Inverse display 0 in RAM: ON in display panel 1 in RAM: OFF in display panel Set Display ON/OFF AEh, X[0]=0b:Display OFF (sleep mode) (RESET) AFh X[0]=1b:Display ON in normal mode 0 AE AF 1 0 1 0 1 1 1 X0 0 A0/A1 1 0 1 0 0 0 0 X0 Set Segment Re-map A0h, X[0]=0b: column address 0 is mapped to SEG0 (RESET) A1h, X[0]=1b: column address 127 is mapped to SEG0 0 C0/C8 1 1 0 0 X3 0 0 0 Set COM Output Scan Direction 12 C0h, X[3]=0b: normal mode (RESET) Scan from COM0 to COM[N –1] C8h, X[3]=1b: remapped mode. Scan from COM[N-1] to COM0 Where N is the Multiplex ratio. 4.2VCC Generated by Internal DC/DC Circuit If the noise is accidentally occurred at the displaying window during the operation, please reset the display in order to recover the display function. 13 Normal Operation Power Stabilized (100ms Delay Recommended) Set Display Off 0xAE Power down VBAT (50ms Delay Recommended) Set Charge Pump 0x8D, 0x10 Power down VDD VDD/VBAT off State Normal Operation Set Charge Pump 0x8D, 0x10 Set Display Off 0xAE Power down VBAT Sleep Mode Sleep Mode Set Charge Pump 0x8D, 0x14 Power Stabilized (100ms Delay Recommended) Power up VBAT (100ms Delay Recommended) Set Display On 0xAF Normal Operation 14 void OLED_Init(void) { //OLED 复位 OLED_RES_Clr();//RES 置 0 delay_ms(200);//延时 200ms OLED_RES_Set();//RES 置 1 //OLED 初始化 OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel OLED_WR_Byte(0x00,OLED_CMD);//---set low column address OLED_WR_Byte(0x10,OLED_CMD);//---set high column address OLED_WR_Byte(0x40,OLED_CMD);//--set start line address OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register OLED_WR_Byte(0xCF,OLED_CMD);// Set SEG Output Current Brightness OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping 0xa0 左 右 反 置 0xa1 正常 OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction 0xc0 上 下 反 置 0xc8 正常 OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64) OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset Shift Mapping RAM Counter (0x00~0x3F) OLED_WR_Byte(0x00,OLED_CMD);//-not offset OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration OLED_WR_Byte(0x12,OLED_CMD); OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh OLED_WR_Byte(0x30,OLED_CMD);//Set VCOM Deselect Level OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02) OLED_WR_Byte(0x02,OLED_CMD);// OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable OLED_Clear(); OLED_WR_Byte(0xAF,OLED_CMD); } 15 //延时 void IIC_delay(void) { u8 t=1; while(t--); } //起始信号 void I2C_Start(void) { OLED_SDA_Set(); OLED_SCL_Set(); IIC_delay(); OLED_SDA_Clr(); IIC_delay(); OLED_SCL_Clr(); IIC_delay(); } //结束信号 void I2C_Stop(void) { OLED_SDA_Clr(); OLED_SCL_Set(); IIC_delay(); OLED_SDA_Set(); } //等待信号响应 void I2C_WaitAck(void) //测数据信号的电平 { OLED_SDA_Set(); IIC_delay(); OLED_SCL_Set(); IIC_delay(); OLED_SCL_Clr(); IIC_delay(); } 16 //写入一个字节 void Send_Byte(u8 dat) { u8 i; for(i=0;i 0.1 L≤2 n≤1 L>2 n=0 Φ ≤ 0.1 Ignore 0.1 < Φ ≤ 0.25 n≤1 0.25 < Φ n=0 Φ ≤ 0.5  Ignore if no Influence on Display 0.5 < Φ n=0 Not Allowable * Protective film should not be tear off when cosmetic check. ** Definition of W & L & Φ (Unit: mm): Φ = (a + b) / 2 L b: Minor Axis W a: Major Axis 20 6.3.3 Pattern Check (Display On) in Active Area Check Item Classification No Display Major Missing Line Major Pixel Short Major Darker Pixel Major Wrong Display Major 21 Criteria Un-uniform Major 7. Precautions When Using These OEL Display Modules 7.1Handling Precautions 1) 2) 3) 4) 5) Since the display panel is being made of glass, do not apply mechanical impacts such us dropping from a high position. If the display panel is broken by some accident and the internal organic substance leaks out, be careful not to inhale nor lick the organic substance. If pressure is applied to the display surface or its neighborhood of the OEL display module, the cell structure may be damaged and be careful not to apply pressure to these sections. The polarizer covering the surface of the OEL display module is soft and easily scratched. Please be careful when handling the OEL display module. When the surface of the polarizer of the OEL display module has soil, clean the surface. It takes advantage of by using following adhesion tape. * Scotch Mending Tape No. 810 or an equivalent Never try to breathe upon the soiled surface nor wipe the surface using cloth containing solvent such as ethyl alcohol, since the surface of the polarizer will become cloudy. Also, pay attention that the following liquid and solvent may spoil the polarizer: 6) * Water * Ketone * Aromatic Solvents Hold OEL display module very carefully when placing OEL display module into the system housing. Do not apply excessive stress or pressure to OEL display module. And, do not over bend the film with electrode pattern layouts. These stresses will influence the display performance. Also, secure sufficient rigidity for the outer cases. 7) 8) Do not apply stress to the driver IC and the surrounding molded sections. Do not disassemble nor modify the OEL display module. 22 9) Do not apply input signals while the logic power is off. 10) Pay sufficient attention to the working environments when handing OEL display modules to prevent occurrence of element breakage accidents by static electricity. * Be sure to make human body grounding when handling OEL display modules. * Be sure to ground tools to use or assembly such as soldering irons. * To suppress generation of static electricity, avoid carrying out assembly work under dry environments. * Protective film is being applied to the surface of the display panel of the OEL display module. Be careful since static electricity may be generated when exfoliating the protective film. 11) Protection film is being applied to the surface of the display panel and removes the protection film before assembling it. At this time, if the OEL display module has been stored for a long period of time, residue adhesive material of the protection film may remain on the surface of the display panel after removed of the film. In such case, remove the residue material by the method introduced in the above Section 5). 12) If electric current is applied when the OEL display module is being dewed or when it is placed under high humidity environments, the electrodes may be corroded and be careful to avoid the above. 7.2Storage Precautions 1) When storing OEL display modules, put them in static electricity preventive bags avoiding exposure to direct sun light nor to lights of fluorescent lamps. and, also, avoiding high temperature and high humidity environment or low temperature (less than 0  C) environments. (We recommend you to store these modules in the packaged state when they were shipped from HanSheng Industrail Co.,Ltd.) At that time, be careful not to let water drops adhere to the packages or bags nor let dewing occur with them. 2) If electric current is applied when water drops are adhering to the surface of the OEL display module, when the OEL display module is being dewed or when it is placed under high humidity environments, the electrodes may be corroded and be careful about the above. 7.3Designing Precautions 1) 2) 3) 4) 5) 6) The absolute maximum ratings are the ratings which cannot be exceeded for OEL display module, and if these values are exceeded, panel damage may be happen. To prevent occurrence of malfunctioning by noise, pay attention to satisfy the VIL and VIH specifications and, at the same time, to make the signal line cable as short as possible. We recommend you to install excess current preventive unit (fuses, etc.) to the power circuit (VDD). (Recommend value: 0.5A) Pay sufficient attention to avoid occurrence of mutual noise interference with the neighboring devices. As for EMI, take necessary measures on the equipment side basically. When fastening the OEL display module, fasten the external plastic housing section. 23 7) If power supply to the OEL display module is forcibly shut down by such errors as taking out the main battery while the OEL display panel is in operation, we cannot guarantee the quality of this OEL display module. 8) The electric potential to be connected to the rear face of the IC chip should be as follows: SSD1306 * Connection (contact) to any other potential than the above may lead to rupture of the IC. 7.4Precautions when disposing of the OEL display modules 1) Request the qualified companies to handle industrial wastes when disposing of the OEL display modules. Or, when burning them, be sure to observe the environmental and hygienic laws and regulations. 7.5Other Precautions 1) When an OEL display module is operated for a long of time with fixed pattern may remain as an after image or slight contrast deviation may occur. Nonetheless, if the operation is interrupted and left unused for a while, normal state can be restored. Also, there will be no problem in the reliability of the module. 2) To protect OEL display modules from performance drops by static electricity rapture, etc., do not touch the following sections whenever possible while handling the OEL display modules. * Pins and electrodes * Pattern layouts such as the FPC 3) With this OEL display module, the OEL driver is being exposed. Generally speaking, semiconductor elements change their characteristics when light is radiated according to the principle of the solar battery. Consequently, if this OEL driver is exposed to light, malfunctioning may occur. * Design the product and installation method so that the OEL driver may be shielded from light in actual usage. * Design the product and installation method so that the OEL driver may be shielded from light during the inspection processes. 4) 5) Although this OEL display module stores the operation state data by the commands and the indication data, when excessive external noise, etc. enters into the module, the internal status may be changed. It therefore is necessary to take appropriate measures to suppress noise generation or to protect from influences of noise on the system design. We recommend you to construct its software to make periodical refreshment of the operation statuses (re-setting of the commands and re-transference of the display data) to cope with catastrophic noise. 24 Warranty: The warranty period shall last twelve (12) months from the date of delivery. Buyer shall be completed to assemble all the processes within the effective twelve (12) months. HanSheng industrail Co.,Ltd. shall be liable for replacing any products which contain defective material or process which do not conform to the product specification, applicable drawings and specifications during the warranty period. All products must be preserved, handled and appearance to permit efficient handling during warranty period. The warranty coverage would be exclusive while the returned goods are out of the terms above. Notice: No part of this material may be reproduces or duplicated in any form or by any means without the written permission of HanSheng Industrail Co.,Ltd.HanSheng Industrail Co.,Ltd. reserves the right to make changes to this material without notice.HanSheng Industrail Co.,Ltd. does not assume any liability of any kind arising out of any inaccuracies contained in this material or due to its application or use in any product or circuit and, further, there is no representation that this material is applicable to products requiring high level reliability, such as, medical products. Moreover, no license to any intellectual property rights is granted by implication or otherwise, and there is no representation or warranty that anything made in accordance with this material will be free from any patent or copyright infringement of a third party. This material or portions thereof may contain technology or the subject relating to strategic products under the control of Foreign Exchange and Foreign Trade Law of Taiwan and may require an export license from the Ministry of International Trade and Industry or other approval from another government agency. 25
HS96L03W2C03 价格&库存
很抱歉,暂时无法提供与“HS96L03W2C03”相匹配的价格&库存,您可以联系我们找货
HS96L03W2C03
  • 1+13.49362
  • 10+11.21747
  • 30+9.99776
  • 100+8.89330
库存:245
