2A7
2A7
    HUIXIN(慧芯)
    SMF(SOD-123FL)
    直流反向耐压(Vr):1kV;平均整流电流(Io):1.5A;正向压降(Vf):1.1V@1.5A;
2A7 数据手册
2A1~2A7 1.5Amp Standard Surface Mounted Rectifiers SOD123FL Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Idea for printed circuit board Glass passivated Junction chip Low reverse leakage High forward surge current capability High temperature soldering guaranteed 250 C/10 seconds at terminals Mechanical Data Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS 2A1 2A2 2A3 2A4 2A5 2A6 2A7 UNITS Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL =100 C I(AV) 1.5 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 40.0 A Maximum instantaneous forward voltage at 1.5A VF 1.10 V Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C IR 5.0 500 uA Typical junction capacitance (Note1) CJ 21.0 pF RqJA 85.0 C/W -55 to +150 C Typical thermal resistance Operating junction and storage temperature range TJ,TSTG Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.          6GMKUL  Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 70 Peak Forward Surage Current Amperes 2.4 2.1 1.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 1.5 1.2 0.9 0.6 0.3 0.0 0 20 40 60 80 100 120 140 60 50 40 30 f=60Hz 20 10 1Cycle 0 160 10 1 Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 0.1 TJ=25 Pulse Width=300us 1% Duty Cycle 0.01 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 Volts Instantaneou Foward Voltage        100 Micro Amperes Amperes 1 Instantaneous Reverse Leakage Current Lead Temperature 10 Instantneous Forward Current 100 Tj = 125°C 10 1.0 Tj = 25°C 0.1 0.01 0 20 40 60 80 100 120 140 Percent Of Rated Peak Reverse Voltage(%)   6GMKUL
很抱歉,暂时无法提供与“2A7”相匹配的价格&库存,您可以联系我们找货
2A7
  • 20+0.12831
  • 200+0.10037
  • 600+0.08487
  • 3000+0.07366
  • 9000+0.06558
  • 21000+0.06121
库存:2762
