ESD4186
ESD4186
    ELECSUPER(静芯微)
    TO-252(DPAK)
    1个N沟道 耐压:45V 电流:36A
ESD4186 数据手册
ESD4186 Rev-1.1 www.elecsuper.com SuperMOS –TO-252 45V BVDSS 16mΩ RDS(on) 36A ID, N-channel MOSFET 1. Description The ESD4186 is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product ESD4186 is Pb-free. 2. Features ⚫ 45V, RDS(ON)=16mΩ(Typ), VGS=10V ⚫ Material: Halogen free RDS(ON)=21mΩ(Typ), VGS=4.5V ⚫ Reliable and rugged ⚫ Use trench MOSFET technology ⚫ Avalanche Rated ⚫ High density cell design for low RDS(on) ⚫ Low leakage current 3. Applications ⚫ PWM applications ⚫ Load switch ⚫ Power management in portable/desktop PCs ⚫ DC/DC conversion 100% UIS TESTED 4. Ordering Information Part Number Package Marking Material Packing Quantity per reel Flammability Rating ESD4186 TO-252 ESD4186/lot Halogen free Tape & Reel 2,500 PCS UL 94V-0 Table-1 Reel Size 13 inches Ordering information 5. Pin Configuration and Functions Pin Function Outline 1 Gate 2 2 Drain 3 Source ESD4186 lot 1 3 Table-2 Copyright© ElecSuper Incorporated Circuit Diagram Pin configuration Contact Us 1 / 7 ESD4186 Rev-1.1 www.elecsuper.com 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Symbol Limit Unit Drain-Source Voltage BVDSS 45 V Gate-Source Voltage VGS ±20 V Parameter Continuous Drain Current Maximum Power Dissipation TC=25°C TC=75°C TC=25°C TC=75°C 36 ID A 28 42 PD W 25 Pulsed Drain Current a IDM 144 A Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Thermal resistance ratings Single Operation Parameter Junction-to-Case Thermal Resistance a t ≤ 10 s Symbol Typical Maximum Unit RθJC 2.5 3 °C/W Note: a: Surface mounted on FR4 Board using 1 square inch pad size, 1oz copper Copyright© ElecSuper Incorporated Contact Us 2 / 7 ESD4186 Rev-1.1 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS=0V, ID=250uA 45 V Zero Gate Voltage Drain Current IDSS VDS=45V, VGS=0V 1.0 uA Gate-to-source Leakage Current IGSS VDS=0V, VGS=±20V ±100 nA 1.4 1.8 V VGS=10V, ID=20A 16 21 VGS=4.5V, ID=15A 21 29 ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) Forward Trans conductance gFS VGS=VDS, ID=250uA 1.0 VDS=5.0V, ID=20A 80 mΩ S CHARGES, CAPACITANCES AND GATE RESISTANCE Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance CRSS Total Gate Charge 980 VGS=0V, f=1MHz, VDS =20V 130 80 QG(TOT) Gate-to-Source Charge QGS Gate-to-Drain Charge QGD pF 17 VGS=10V, VDS=20V, ID=20A 2.5 nC 4.5 SWITCHING CHARACTERISTICS Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time td(ON) tr td(OFF) 6.5 17.6 VGS=10V, VDS=20V, RL=1.5Ω, RGEN=3Ω ns 19.8 tf 16.6 BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, IS=1.0A Contact Us 0.45 1.2 V 3 / 7 ESD4186 7. Rev-1.1 www.elecsuper.com Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 4 / 7 ESD4186 Copyright© ElecSuper Incorporated Rev-1.1 Contact Us www.elecsuper.com 5 / 7 ESD4186 Rev-1.1 www.elecsuper.com 8. Dimension (TO-252) D1 L3 θ2 c E L Φ D3 h θ1 D2 e L2 L4 L1 θ b A1 A D MILLIMETER MILLIMETER SYMBOL SYMBOL MIN Typ. MAX MIN Typ. MAX A 2.200 2.300 2.400 h 0.000 0.100 0.200 A1 0.000 0.127 L 9.900 10.100 10.300 b 0.640 0.690 0.740 L1 C(电镀后) 0.460 0.520 0.580 L2 D 6.500 6.600 6.700 L3 2.888 REF 1.400 1.550 1.700 1.600 REF D1 5.334 REF L4 0.600 0.800 1.000 D2 4.826 REF Φ 1.100 1.200 1.300 D3 3.166 REF θ 0° E e 6.000 6.100 6.200 2.286 TYP Copyright© ElecSuper Incorporated Contact Us 8。 θ1 9°TYP θ2 9°TYP 6 / 7 ESD4186 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 7 / 7
ESD4186 价格&库存
很抱歉,暂时无法提供与“ESD4186”相匹配的价格&库存,您可以联系我们找货
