MDT100N06
MDT100N06
    MINOS(迈诺斯)
    TO-252(DPAK)
    1个N沟道 耐压:60V 电流:100A
MDT100N06 数据手册
Green Product MPG100N06 60V N-Channel Power MOSFET DESCRIPTION KEY CHARACTERISTICS The MPG100N06 uses advanced trench technology to provide ● VDS = 60V,ID = 100A excellent RDS(ON), low gate charge. It can be used in a wide ● RDS(ON) < 7mΩ @ VGS=10V variety of applications. ● Special process technology for high ESDcapability ● High density cell design for lower Rdson Application ● Fully characterized avalanche voltage and current ●Power switching application ● Good stability and uniformity with high EAS ●Hard switched and High frequency circuits ● Excellent package for good heat dissipation ●Uninterruptible power supply 100% UIS TESTED! 100% DVDS TESTED! TO-220 Top View TO-252-2L Top View TO-263-2L Top View Schematic diagram Package Marking And Ordering Information Device Marking Ordering Codes Package Product Code Packing M100N06 MPG100N06 TO-220 MPG100N06 Tube M100N06 MDT100N06 TO-252-2L MDT100N06 Tape Reel M100N06 MPS100N06 TO-263-2L MPS100N06 Tape Reel Absolute Maximum Ratings (TA=25℃ Parameter unless otherwise noted) Symbol Limit Unit Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V Drain Current-Continuous ID 100 A Drain Current-Pulsed (Note 1) IDM 380 A Maximum Power Dissipation(Tc=25℃) PD 143 W Single pulse avalanche energy(Note 2) EAS 260 mJ TJ,TSTG -55 To 175 ℃ Thermal Resistance,Junction-to-Case RθJC 1.05 ℃/W Thermal Resistance,Junction-to-Ambient RθJA 62.5 ℃/W Operating Junction and Storage Temperature Range Thermal Characteristic Page1 Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 Electrical Characteristics (TA=25℃ unless otherwise noted) Parameter Symbol Condition Min Typ Max Unit Drain-Source Breakdown Voltage BVDSS VGS=0V ID=250μA 60 - - V Zero Gate Voltage Drain Current IDSS VDS=60V,VGS=0V - - 1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V - - ±100 nA Gate Threshold Voltage VGS(th) VDS=VGS,ID=250μA 2 2.8 4 V Drain-Source On-State Resistance(Note 3) RDS(ON) VGS=10V, ID=30A - 6.0 7.0 mΩ gFS VDS=5V,ID=15A - 15 - S - 3700 - pF - 345 - pF Off Characteristics On Characteristics Forward Transconductance Dynamic Characteristics Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss - 270 - pF Turn-on Delay Time td(on) - 19 - nS Turn-on Rise Time tr VDD=30V, ID=30A, - 36 - nS td(off) VGS=10V,RGEN=3Ω - 45 - nS 24 - nS - 80 - nC - 25 - nC - 22 - nC - - 1.2 V VDS=30V,VGS=0V, f=1.0MHz Switching Characteristics (Note 4) Turn-Off Delay Time Turn-Off Fall Time tf Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd VDS=48V,ID=30A VGS=10V Drain-Source Diode Characteristics Diode Forward Voltage VSD VGS=0V,IS=1A Notes: 1. 2. 3. 4. Repetitive Rating: Pulse width limited by maximum junction temperature. EAS condition :T j=25℃,L=0.5mH,VDD=50V,VG=10V, Rg=25Ω. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. Guaranteed by design, not subject to production. Page2 Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 Characteristics Curves Page3 Figure 1 Output Characteristics Figure 2 Transfer Characteristics Figure 3 On-Resistance vs. ID and VGS Figure 4 On-Resistance vs. Junction Temperature Figure 5 On-Resistance vs. VGS Figure 6 Body Diode Forward Voltage Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 Figure 7 Gate-Charge Characteristics Figure 9 Maximum Forward Biased Safe Operation Area Figure 8 Capacitance Characteristics Figure 10 Single Pulse Power Rating Junction-to-Ambient Figure 11 Normalized Maximum Transient Thermal Impedance Page4 Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 Package Description Values(mm) Items MIN MAX A 9.60 10.6 B 15.0 16.0 B1 8.90 9.50 C 4.30 4.80 C1 2.30 3.10 D 1.20 1.40 E 0.70 0.90 F 0.30 0.60 G 1.17 1.37 H 2.70 3.80 L 12.6 14.8 N 2.34 2.74 Q 2.40 3.00 3.50 3.90 TO-220 Page5 Package Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 Items Values(mm) MIN MAX A 6.30 6.90 A1 0 0.13 B 5.70 6.30 C 2.10 2.50 D 0.30 0.60 E1 0.60 0.90 E2 0.70 1.00 F 0.30 0.60 G 0.70 1.20 L1 9.60 10.50 L2 2.70 3.10 H 0.60 1.00 M 5.10 5.50 N 2.09 2.49 R 0 .3 T 1.40 1.60 Y 5.10 6.30 TO-252 Package Page6 Shenzhen Minos Technology Co., Ltd. V 1.0 Green Product MPG100N06 C A L1 B K D I L2 H G E F N B1 N Values(mm) Items MIN MAX A 9.80 10.40 B 8.90 9.50 B1 0 0.10 C 4.40 4.80 D 1.16 1.37 E 0.70 0.95 F 0.30 0.60 G 1.07 1.47 H 1.30 1.80 K 0.95 1.37 L1 14.50 L2 1.60 2.30 I 0 0.2 Q 0° 8° R N 16.50 0.4 2.39 2.69 TO-263 Package Page7 Shenzhen Minos Technology Co., Ltd. V 1.0
MDT100N06 价格&库存
很抱歉,暂时无法提供与“MDT100N06”相匹配的价格&库存,您可以联系我们找货
