ES15N10G
ES15N10G
    ELECSUPER(静芯微)
    TO-252(DPAK)
    1个N沟道 耐压:100V 电流:12A
ES15N10G 数据手册
ES15N10G Rev-1.3 www.elecsuper.com SuperMOS – TO-252 100V BVDSS, 85mΩ RDS(ON), 12A ID N-channel MOSFET 1. Description The ES15N10G is N-Channel enhancement MOS Field Effect Transistor. Uses advanced trench technology and design to provide excellent RDS(ON) with low gate charge. Device is suitable for use in DC-DC conversion, power switch and charging circuit. Standard Product ES15N10G is Pb-free. 2. Features  100V, RDS(ON)=85mΩ(Tpy), VGS=10V  Material: Halogen free RDS(ON)=92mΩ(Tpy), VGS=4.5V  Reliable and rugged  Use trench MOSFET technology  Avalanche Rated  High density cell design for low RDS(on)  Low leakage current 3. Applications  PWM applications 100% UIS TESTED!  Load switch  Power management in portable/desktop PCs  DC/DC conversion 4. Ordering Information Part Number Package Marking Material Packing Quantity per reel Flammability Rating ES15N10G TO-252 ES15N10G /lot Halogen free Tape & Reel 2,500 PCS UL 94V-0 Reel Size 13 inches 5. Pin Configuration and Functions Pin Function 1 Gate 2 Drain 3 Source Copyright© ElecSuper Incorporated Outline Circuit Diagram 2 ES15N10G LOT 1 3 Contact Us 1 / 5 ES15N10G Rev-1.3 www.elecsuper.com 6. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameter Symbol Limit Unit Drain-Source Voltage BVDSS 100 V Gate-Source Voltage VGS ±20 V TC=25°C Continuous Drain Current TC=70°C Maximum Power Dissipation TC=25°C TC=70°C 12 ID A 9.5 35 PD W 22.5 Pulsed Drain Current a IDM 48 A Operating Junction Temperature TJ 150 °C Lead Temperature TL 260 °C Storage Temperature Range Tstg -55 to 150 °C Thermal resistance ratings Single Operation Parameter Junction-to-Ambient Thermal Resistance Junction-to-Case Thermal Resistance b Symbol Typical Maximum t ≤ 10 s RθJA 110 Steady State RθJC 3.6 Unit °C/W Note: a: Repetitive rating, pulse width limited by junction temperature, tp=10μs, Duty Cycle=1% b: Device mounted on FR-4 substrate PC board, 2oz copper, with 1inch square copper plate. Copyright© ElecSuper Incorporated Contact Us 2 / 5 ES15N10G Rev-1.3 www.elecsuper.com Electrical Characteristics At TA = 25℃ unless otherwise specified Parameter Symbol Test Conditions Min. Typ. Max. Unit OFF CHARACTERISTICS Drain-to-Source Breakdown Voltage BVDSS VGS=0V, ID=250uA 100 V Zero Gate Voltage Drain Current IDSS VDS=100V, VGS=0V 1 uA Gate-to-source Leakage Current IGSS VDS=0V, VGS=±20V ±100 nA 1.5 2.0 V VGS=10V, ID=8.0A 85 120 VGS=4.5V, ID=8.0A 92 135 ON CHARACTERISTICS Gate Threshold Voltage VGS(TH) Drain-to-source On-resistance RDS(on) Forward Trans conductance gFS VGS=VDS, ID=250uA 1.0 VDS=5.0V, ID=8.0A mΩ 40 S 2.0 V BODY DIODE CHARACTERISTICS Forward Voltage Copyright© ElecSuper Incorporated VSD VGS=0V, IS=8.0A Contact Us 1.5 3 / 5 ES15N10G Rev-1.3 www.elecsuper.com 7. Dimension (TO-252) D1 L3 θ2 c E L Φ D3 h θ1 D2 e L2 L4 L1 θ b A1 A D SYMBOL MILLIMETER MIN Typ. MAX A 2.200 2.300 2.400 A1 0.000 b 0.640 C(电镀后) D SYMBOL MILLIMETER MIN Typ. MAX h 0.000 0.100 0.200 0.127 L 9.900 10.100 10.300 0.690 0.740 L1 0.460 0.520 0.580 L2 6.500 6.600 6.700 L3 2.888 REF 1.400 1.550 1.700 1.600 REF D1 5.334 REF L4 0.600 0.800 1.000 D2 4.826 REF Φ 1.100 1.200 1.300 D3 3.166 REF θ 0° E e 6.000 6.100 6.200 2.286 TYP Copyright© ElecSuper Incorporated Contact Us 8。 θ1 9°TYP θ2 9°TYP 4 / 5 ES15N10G Rev-1.3 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 5 / 5
ES15N10G 价格&库存
很抱歉,暂时无法提供与“ES15N10G”相匹配的价格&库存,您可以联系我们找货
