YFW120N10AD
100V N-CHANNEL
CHANNEL ENHANCEMENT MODE MOSFET
MAIN CHARACTERISTICS
ID
120A
VDSS
100V
RDSON-typ(@VGS=10V)
<6m
mΩ(Type:4.6 mΩ)
Application
Battery protection
Load switch
Uninterruptible power supply
TO-252
Product Specification Classification
Part Number
Package
Marking
Pack
YFW120N10AD
TO-252
YFW 120N10AD XXXXX
2500PCS/Tape
=25°C unless otherwise specified
Maximum Ratings at Tc=25°C
Characteristics
Symbols
Value
Units
Drain-Source Voltage
VDS
100
V
Gate - Source Voltage
VGS
±20
V
Continue Drain Current
ID
120
A
Pulsed Drain Current(Note1)
IDM
300
A
Power Dissipation
PD
8
148
W
Single Pulse Avalanche Energy (Note1)
EAS
130
mJ
TJ
150
°C
Storage Temperature Range
TSTG
-55
55 to +150
+1
°C
Thermal Resistance, Junction to case
RθJC
4
0.84
°C/W
Thermal Resistance, Junction to ambient
RθJA
62
°C/W
Operating Temperature Range
www.yfwdiode.com
1/5
GuangDong YFW Electronics Co, Ltd.
YFW120N10AD
Maximum Ratings at Tc=25°C unless otherwise specified
Characteristics
Test Condition
Symbols
Min
Typ
Max
Units
Drain-Source Breakdown Voltage
VGS=0V, ID=250uA
BVDSS
100
V
Drain-Source Leakage Current
VDS=100V , VGS=0V
IDSS
1
μA
Gate Leakage Current
VGS=±20V, VDS=0V
IGSS
±100
nA
Gate-Source Threshold Voltage
VDS= VGS, ID=250μA
VGS(th)
1
3
V
4.6
6
6.3
9
Ciss
3530
Coss
560.1
Crss
9
td(on)
22.5
Tr
8.6
td(OFF)
66.6
tf
42.1
Qg
65.7
Qgs
8.4
Qgd
12.2
IS
120
A
VSD
1.3
V
trr
67
ns
Qrr
160
nC
Irrm
3.9
A
Drain-Source on- State Resistance
note3
VGS=10V, ID=1A
VGS=4.5V, ID=1A
Input Capacitance
VDS=50V
VGS=0V
f=1MHz
Output Capacitance
Reverse Transfer Capacitance
Turn-on delay time(Note2)
VDS=50V
ID=10A
RG=2Ω
VGS=10V
Rise Time(Note2)
Turn-Off Delay Time
Fall Time(Note2)
Total Gate Charge(Note2)
VDS=50V
VGS=10V
ID=10A
Gate-to Source Charge(Note2)
Gate to Drain Charge(Note2)
Maximun Body-Diode Continuous
Current
Drain-Source Diode Forward Voltage
VGS=0V , IS=30A , TJ=25℃
Reverse Recovery Time(Note2)
Reverse Recovery Charge(Note2)
TJ = 25℃, IS=10A
di / dt = 1000 A/µs
Peak reverse recovery current
RDS(ON)
mΩ
PF
ns
nC
Note1:Pulse test: 300 µs pulse width, 2 % duty cycle
Note2:Pulse test: 300 µs pulse width, 2 % duty cycle
www.yfwdiode.com
2/5
YFW120N10AD
Ratings and Characteristic Curves
www.yfwdiode.com
3/5
YFW120N10AD
www.yfwdiode.com
4/5
YFW120N10AD
Package Outline Dimensions Millimeters
TO-252
Dim.
A
A2
B
B2
C
C2
D
D1
E
E1
G
H
L
L2
V1
V2
Min.
2.10
5.18
0.40
0.44
5.90
6.40
4.63
4.47
9.50
1.09
1.35
0°
Typ.
5.30REF
7°
Max.
2.50
0.10
0.86
5.48
0.60
0.58
6.30
6.80
4.67
10.70
1.21
1.65
6°
All Dimensions in millimeter
www.yfwdiode.com
5/5
很抱歉,暂时无法提供与“YFW120N10AD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.59880
- 10+5.29200
- 30+4.63320
- 100+3.98520
- 500+3.41280
- 1000+3.21840
