A7
A7
    PAKER(派克微)
    SMF(SOD-123FL)
A7 数据手册
A7 Surface Mount General Purpose Rectifier SOD-123FL Features Low reverse leakage Glass passivated junction High forward surge current capability High efficiency operation Mechanical Data SOD-123FL Small Outline Plastic Package Polarity: Color band denotes cathode end Epoxy UL: 94V-0 Mounting Position: Any Maximum Ratings & Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. ) SYMBOLS A7 MARKING A7 Maximum repetitive peak reverse voltage VRRM 1000 V Maximum RMS voltage VRMS 700 V Maximum DC blocking voltage VDC 1000 V Maximum average forward rectified current at TL =100 C I(AV) 1.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF 1.10 V Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C IR 5.0 500 uA Typical junction capacitance (Note1) CJ 18.0 pF RqJA 80.0 C/W TJ,TSTG -55 to +150 C Parameter UNITS Typical thermal resistance Operating junction and storage temperature range Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. Summary of Packing Options Package Packing Description Packing Quantity Industry Standard SOD-123FL Tape/Reel,7" reel 3000 EIA-481-1 Rev 1: Feb 2018 派克微电子(深圳)有限公司 www.pakermicro.com Page 1 of 2 A7 Surface Mount General Purpose Rectifier 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current Ratings and Characteristic Curves 0.7 0.6 0.5 0.4 0.3 30 25 20 15 f=60Hz 10 0.2 0 20 40 60 80 100 120 140 5 0 160 1 10 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG Instantaneous Reverse Leakage Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT TJ=25 Pulse Width=300us 1% Duty Cycle 0.01 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 Tj = 125°C 10 Micro Amperes 1 Amperes Instantneous Forward Current 10 0.1 100 Number of cycles Lead Temperature 1.0 Tj = 25°C 0.1 0.01 Volts Instantaneou Foward Voltage 0 20 40 60 80 100 120 140 Percent Of Rated Peak Reverse Voltage(%) FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS Package Outline Dimensions: SOD-123FL SOD-123FL B D A C H L Rev 1: Feb 2018 Inches Dimension F G MIN NOM Millimeters MAX MIN NOM MAX A 0.059 0.079 1.5 2 B 0.134 0.154 3.4 3.9 C 0.028 0.047 0.7 1.2 D 0.098 0.114 2.5 2.9 F 0.002 0.01 0.05 0.26 G H L 0.037 0.014 0.004 0.053 0.035 0.95 0.35 0.1 1.35 0.9 派克微电子(深圳)有限公司 www.pakermicro.com Page 2 of 2
很抱歉,暂时无法提供与“A7”相匹配的价格&库存,您可以联系我们找货
