SWD070R08E7T
SWD070R08E7T
    SAMWIN(芯派)
    TO-252(DPAK)
    耐压:80V 电流:95A
SWD070R08E7T 数据手册
SW070R08E7T N-channel Enhanced mode TO-252 MOSFET Features ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ TO-252 High ruggedness Low RDS(ON) (Typ 7.6mΩ)@VGS=10V Low Gate Charge (Typ 101nC) Improved dv/dt Capability 100% Avalanche Tested Application:Synchronous Rectification, Li Battery Protect Board, Inverter General Description BVDSS : 80V ID : 95A RDS(ON) : 7.6mΩ 2 1 2 3 1 1. Gate 2.Drain 3.Source 3 This power MOSFET is produced with advanced technology of SAMWIN. This technology enable the power MOSFET to have better characteristics, including fast switching time, low on resistance, low gate charge and especially excellent avalanche characteristics. Order Codes Item Sales Type Marking Package Packaging 1 SW D 070R08E7T SW070R08E7T TO-252 REEL Value Unit Drain to source voltage 80 V Continuous drain current (@TC=25oC) 95* A Continuous drain current (@TC=100oC) 63* A 380 A ± 20 V Absolute maximum ratings Symbol VDSS Parameter ID IDM Drain current pulsed (note 1) VGS Gate to source voltage EAS Single pulsed avalanche energy (note 2) 272 mJ EAR Repetitive avalanche energy (note 1) 20 mJ dv/dt Peak diode recovery dv/dt (note 3) 5 V/ns Total power dissipation (@TC=25oC) 130.2 W Derating factor above 25oC 1.04 W/oC -55 ~ + 150 oC Value Unit 0.96 oC/W PD TSTG, TJ Operating junction temperature & storage temperature *. Drain current is limited by junction temperature. Thermal characteristics Symbol Rthjc Parameter Thermal resistance, Junction to case Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 1/6 SW070R08E7T Electrical characteristic ( TJ = 25oC unless otherwise specified ) Symbol Parameter Test conditions Min. Typ. Max. Unit Off characteristics Drain to source breakdown voltage VGS=0V, ID=250uA ΔBVDSS / ΔTJ BVDSS Breakdown voltage temperature coefficient 80 ID=250uA, referenced to 25oC IDSS Drain to source leakage current V V/oC 0.07 VDS=80V, VGS=0V 1 uA VDS=64V, TJ=125oC 50 uA Gate to source leakage current, forward VGS=20V, VDS=0V 100 nA Gate to source leakage current, reverse VGS=-20V, VDS=0V -100 nA 4 V IGSS On characteristics VGS(TH) Gate threshold voltage VDS=VGS, ID=250uA 2 =25oC 7.6 9.0 mΩ =25oC 7.8 9.2 mΩ VGS=10V, ID=30A,TJ =125oC 12 mΩ VDS=5V, ID=30A 44 S VGS=10V, ID=30A,TJ RDS(ON) Gfs Drain to source on state resistance Forward transconductance VGS=10V, ID=50A,TJ Dynamic characteristics Ciss Input capacitance Coss Output capacitance Crss Reverse transfer capacitance td(on) Turn on delay time tr td(off) tf Rising time Turn off delay time 5291 VGS=0V, VDS=40V, f=1MHz 274 pF 255 29 VDS=40V, ID=30A, RG=4.7Ω, VGS=10V (note 4,5) 73 ns 93 Fall time 36 Qg Total gate charge Qgs Gate-source charge Qgd Gate-drain charge VDS=64V, VGS=10V, ID=30A , IG=3mA (note 4,5) Rg Gate resistance VDS=0V, Scan F mode 101 30 nC 36 Ω 4 Source to drain diode ratings characteristics Symbol Parameter IS Continuous source current ISM VSD Test conditions Min. Typ. Max. Unit 95 A Pulsed source current Integral reverse p-n Junction diode in the MOSFET 380 A Diode forward voltage drop. IS=50A, VGS=0V 1.4 V trr Reverse recovery time Qrr Reverse recovery charge IS=30A, VGS=0V, dIF/dt=100A/us 42 ns 68 nC ※. Notes 1. Repeatitive rating : pulse width limited by junction temperature. 2. L =0.5mH, IAS =33A, VDD=50V, RG=25Ω, Starting TJ = 25oC 3. ISD ≤30A, di/dt = 100A/us, VDD ≤ BVDSS, Staring TJ =25oC 4. Pulse Test : Pulse Width ≤ 300us, duty cycle ≤ 2%. 5. Essentially independent of operating temperature. Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 2/6 SW070R08E7T Fig. 1. On-state characteristics Fig. 2. Transfer Characteristics Fig. 3. On-resistance variation vs. drain current and gate voltage Fig. 4. On-state current vs. diode forward voltage Fig 5. Breakdown voltage variation vs. junction temperature Fig. 6. On-resistance variation vs. junction temperature Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 3/6 SW070R08E7T Fig. 7. Gate charge characteristics Fig. 9. Maximum safe operating area Fig. 8. Capacitance Characteristics Fig. 10. Maximum drain current vs. case temperature Fig. 11. Transient thermal response curve Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 4/6 SW070R08E7T Fig. 12. Gate charge test circuit & waveform Fig. 13. Switching time test circuit & waveform VDS 90% RL RGS VDS VDD VIN 10VIN DUT 10% 10% td(on) tr tON td(off) tf tOFF Fig. 14. Unclamped Inductive switching test circuit & waveform Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 5/6 SW070R08E7T Fig. 15. Peak diode recovery dv/dt test circuit & waveform DUT + V DS 10V VGS (DRIVER) L IS di/dt IS (DUT) IRRM VDS RG Diode reverse current VDD Diode recovery dv/dt Same type as DUT 10VGS VDS (DUT) *. dv/dt controlled by RG *. Is controlled by pulse period VDD VF Body diode forward voltage drop DISCLAIMER * All the data & curve in this document was tested in SEMIPOWER TESTING & APPLICATION CENTER. * This product has passed the PCT,TC,HTRB,HTGB,HAST,PC and Solderdunk reliability testing. * Qualification standards can also be found on the Web site (http://www.semipower.com.cn) * Suggestions for improvement are appreciated, Please send your suggestions to samwin@samwinsemi.com Copyright@ Semipower Technology Co., Ltd. All rights reserved. May.2022. Rev. 0.6 6/6
SWD070R08E7T 价格&库存
很抱歉,暂时无法提供与“SWD070R08E7T”相匹配的价格&库存,您可以联系我们找货
SWD070R08E7T
库存:5
