1N4148FL
1N4148FL
    AGERTECH(艾吉芯)
    SMF(SOD-123FL)
    100V 150MA
1N4148FL 数据手册
1N4148FL HIGH-SPEED SWITCHING DIODE Forward Current-150mA Reverse Voltage-100V FEATURES PINNING PIN  For surface mount applications  Glass passivated chip junction  Fast reverse recovery time  Ideal for automated placement  Lead free in comply with EU RoHS 2011/65/EU directives 1 Cathode 2 Anode 1 MECHANICAL DATA  Case: SOD-123FL molded plastic body  DESCRIPTION 2 Top View Terminals:Solderable per MIL-STD-750,Method 2026 Simplified outline SOD-123FL and symbol  Weight: Approximated 0.015 grams MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derating by 20 % PARAMETER SYMBOL 1N4148FL UNIT Maximum Repetitive Peak Reverse Voltage Maximum RMS Voltage VRRM VRMS 100 75 V V Reverse Breakdown Voltage at IR=1μA V(BR)R 75 V IF 150 mA IFSM 4 0.715 0.855 1.00 1.25 A Maximum Forward Current Peak Forward Surge Current (Note1) Maximum Forward Voltage at 1 mA 10mA 50mA 150mA VF Peak Reverse Current at VR=20V , TJ=25℃ V IR 0.025 1 30 50 uA CJ 5 pF RθJA 90 ℃/W Total Power Dissipation PD 400 mW Maximum Reverse Recovery Time Trr 8 nS VR=75V ,TJ=25℃ VR=25V ,TJ=150℃ VR=75V ,TJ=150℃ Typical Junction Capacitance (Note2) Typical Thermal Resistance (Note3) Operating and Storage Temperature Range TJ,TSTG -55 to +150 ℃ Notes: 1. Measured at 8.3 ms single half sine wave superimposed on rated load (JEDEC Method). 2. Measured at 1MHz and applied reverse voltage of 4 V D.C. 3. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 1/3 Dated: 03/2016 Rev:1.0 1N4148FL RATINGS AND CHARACTERISTIC CURVES AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 2/3 Dated: 03/2016 Rev:1.0 1N4148FL PACKAGE OUTLINE SOD-123FL 2.60 2.90 1.70 1.90 0.80 1.10 Top View 0.12 0.20 0.90 1.10 0.70 0.90 Bottom View 3.50 3.80 Dimensions in milimeters ORDERING INFORMATION Device Package Shipping 1N4148FL SOD-123FL 3,000/Tape & Reel (7 inches) AGERTECH MICROELECTRONICS Subsidiary of Sino-Talent International Holdings Ltd. 3/3 Dated: 03/2016 Rev:1.0
1N4148FL 价格&库存
很抱歉,暂时无法提供与“1N4148FL”相匹配的价格&库存,您可以联系我们找货
