HP4059D6-42Y
HP4059D6-42Y
    HYPWR(瀚昕微)
    TDFN-6L(1x1)
    300MA单节锂离子电池充电器,0.1MA终止电流,45NA电池漏电流
HP4059D6-42Y 数据手册
HP4059 300mA Single Cell Li-ion Battery Charger 0.1mA Termination, 45nA Battery Leakage Current GENERAL DESCRIPTION FEATURES The HP4059 series of devices are highly integrated Li-Ion Charging - 1% Charge Voltage Accuracy - 5% Charge Current Accuracy - Support Application for Very Low Charge Currents – 1mA to 300mA - Support minimum 0.1mA Charge Termination Current - 45nA Maximum Battery Output Leakage Current @ and Li-Pol linear chargers targeted at small capacity battery for portable applications. It is a complete constant-current/ constant voltage linear charger. No external sense resistor is needed, and no blocking diode is required due to the internal MOSFET architecture. It can deliver up to 300mA of charge current (using a good thermal PCB layout) with a final float voltage accuracy of ±1%. The charge voltage is fixed at 4.2V/4.35V/4.4V, and 0℃~85℃ the charge current can be programmed externally with - a single resistor. The charger function has high accuracy Others - Output Short-Circuit Protection - Soft-Start Limits Inrush Current - Charge Status Output Pin - Automatic Recharge current and voltage regulation loops and charge termination. The HP4059 automatically terminates the charge cycle when the charge current drops to 1/10 the programmed value after the final float voltage is reached. High Voltage Chemistry Support: up to 4.4V APPLICATIONS  Fitness Accessories When the input supply (wall adapter or USB supply) is  Smart Watches removed, the HP4059 will shut off, only 40nA leakage  Bluetooth Handsets current coming from battery at sleep mode when  Wireless Low-Power Handheld Devices ambient temperature is 85℃, so it can save energy and improve standby time. MARKING DESCRIPTION The HP4059 is available in a small package with TDFN1X1-6L. Standard product is Pb-Free and Halogen- VWA free. “V”: Product code, here use “V” stands for “HP4059-Y”. “W”: The week of manufacturing. “A” stands for week 1, “Z” stands for week 26, “a” stands for week 27, “z” stands for week 52. “A” : Voltage code, change according to voltage version. HP4059-Y Datasheet, 2020 Version 1.1 Hypower Microelectronics(Shanghai)Co., Ltd. Page 1 sales@hypwr.com HP4059 300mA Single Cell Li-ion Battery Charger 0.1mA Termination, 45nA Battery Leakage Current ORDER INFORMATION Part NO Package CV Voltage HP4059D6-42Y CC Current 4.2V HP4059D6-435Y TDFN1X1-6L HP4059D6-44Y Programmable 4.35V Max:300mA 4.4V PART NUMBER RULES Description 1 □ Package: D6: TDFN1X1-6L Voltage version: 2 □ Tape & Reel -40 ~ +85℃ 10000/REEL PIN ASSIGNMENT HP4059□ 1 -□ 2 Code Temperature 42: 4.2V 435: 4.35V 1 6 2 5 3 4 1:BAT 2:NC 3:CHGb 4:GND 5:PROG 6:VCC TOP VIEW 44: 4.4V TDFN1X1-6L PIN DESCRIPTION Function Pin Number Pin Name I/O 1 BAT O Charge Current Output. Provides charge current to the battery and regulates the final float voltage to 4.2V/4.35V/4.4V. 2 NC - Open-Drain Charge Status Output. When the battery is charging, the CHGb pin is pulled low. When the charge cycle is completed or VCC is removed, the CHGb is forced high impedance. 3 CHGb O 4 GND Ground 5 PROG O 6 VCC Power HP4059-Y Datasheet, 2020 Version 1.1 Hypower Microelectronics(Shanghai)Co., Ltd. Ground Charge current setting, charge current monitor. The charging current is given by IBAT= 100/RPROG(A). Please choose 1% precision resistor for RPROG. For fixed charge current part, this pin is no bonding wire. Power Supply Page 2 sales@hypwr.com HP4059 300mA Single Cell Li-ion Battery Charger 0.1mA Termination, 45nA Battery Leakage Current TYPICAL APPLICATION CIRCUIT Optional Optional VIO 10K System USB Port or Adapter BAT Cin D+ GPIO CHGb VCC VBUS VBAT HP4059 Host PACK+ GND D- CE TEMP Co PROG GND PACK- Rprog Note 1: Cin=1uF, Co=1uF are recommended, not mandatory. Good layout and pure supply voltage can omit these capacitors. Rprog is not needed for fixed cc current part. ABSOLUTE MAXIMUM RATINGS (Note 2) SYMBOL ITEMS VALUE UNIT VCC Input Voltage -0.3~7 V VPROG PROG Voltage -0.3~7 V VBAT BAT Voltage -0.3~7 V VCHGb CHGb Voltage -0.3~7 V IBAT Battery Charge Current 300 mA PDMAX Power Dissipation 0.5 W TJ Junction Temperature -40~125 ℃ TSTG Storage Temperature -55 to 150 ℃ TSOLDER Package Lead Soldering Temperature 260℃, 10s TDFN1X1-6L Note 2: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. RECOMMENDED OPERATING CONDITION MIN NOM MAX UNIT VCC Input operating voltage range 4.5 5 5.5 V IBAT Battery charge current range 1 50 250 mA TJ Junction temperature 0 125 ℃ RPROG CC mode charge current programming resistor 1 100 KΩ HP4059-Y Datasheet, 2020 Version 1.1 Hypower Microelectronics(Shanghai)Co., Ltd. 2 Page 3 sales@hypwr.com HP4059 300mA Single Cell Li-ion Battery Charger 0.1mA Termination, 45nA Battery Leakage Current SIMPLIFIED BLOCK DIAGRAM VCC 100X 1X 5uA - + BAT MA R1 + VA CA - R2 + - REF 1.2V 1V R3 R4 + C1 CHGb To BAT + 2.9V - 0.1V - R5 C2 PROG GND ELECTRICAL CHARACTERISTICS The following specifications apply for VCC=5V TA=25℃, unless specified otherwise. SYMBOL ISPLYCHRG IBATCHRG ITEMS CONDITIONS Charge Mode GND Current RPROG=1kΩ,VCC=5V Charge Mode Battery Current RPROG=2kΩ 47.5 50 52.5 RPROG=4kΩ 23.7 25 26.3 65 70 85 µA 2.4 3 µA Standby Mode Battery Current Charge Terminated ISPLYASD Shutdown Mode Supply Current IBATASD Shutdown Mode BAT Pin Current VFLOAT Float Voltage HP4059-Y Datasheet, 2020 Version 1.1 Hypower Microelectronics(Shanghai)Co., Ltd. µA 105 IBATSTBY Sleep Mode BAT Pin Current 89 UNIT 100 Charge Terminated IBATSLEEP2 MAX 95 Standby Mode Supply Current Sleep Mode BAT Pin Current TYP RPROG=1kΩ ISPLYSTBY IBATSLEEP1 MIN Vcc
HP4059D6-42Y 价格&库存
很抱歉,暂时无法提供与“HP4059D6-42Y”相匹配的价格&库存,您可以联系我们找货
