UMW
R
AO4435
30V P-Channel Enhancement Mode MOSFET
Description
The AO4435 uses advanced trench technology
to provide excellent RDS(ON), low gate charge and
operation with gate voltages as low as 2.5V. This
device is suitable for use as a
Battery protection or in other Switching application.
General Features
VDS = - 30V I D = -12A
RDS(ON) < 20mΩ @ VGS=10V
Application
Battery protection
Load switch
Uninterruptible power supply
Absolute Maximum Ratings (Tc=25℃ unless otherwise noted )
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
- 30
V
VGS
Gate-Source Voltage
+ 20
V
ID@TA=25℃
Drain Current3, VGS @ 10V
-12
A
ID@TA=70℃
-10
A
IDM
Pulsed Drain Current1
-50
A
PD@TA=25℃
Total Power Dissipation
2.5
W
Linear Derating Factor
0.02
W/℃
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Rthj-a
Maximum Thermal Resistance, Junction-ambient3
50
℃/W
TSTG
www.umw-ic.com
1
友台半导体有限公司
UMW
R
AO4435
Electrical Characteristics@Tj=25oC(unless otherwise specified)
Symbol
BVDSS
RDS(ON)
Parameter
Drain-Source Breakdown Voltage
Static Drain-Source On-Resistance2
Test Conditions
Min.
Typ.
Max.
Units
-30
V
VGS=-10V, ID=-7A
15
mΩ
VGS=-4.5V, ID=-5A
25
32
mΩ
-0.9
-1.5
V
VGS=0V, ID=-250uA
VGS(th)
Gate Threshold Voltage
VDS=VGS, ID=-250uA
gfs
Forward Transconductance
VDS=-10V, ID=-7A
16
S
IDSS
Drain-Source Leakage Current
VDS=-24V, VGS=0V
-30
uA
IGSS
Gate-Source Leakage
VGS=+20V, VDS=0V
+100
nA
Qg
Total Gate Charge
ID=-7A
18
29
nC
Qgs
Gate-Source Charge
VDS=-24V
3
nC
Qgd
Gate-Drain ("Miller") Charge
VGS=-4.5V
10
nC
td(on)
Turn-on Delay Time
VDS=-15V
8
ns
tr
Rise Time
ID=-1A
6.6
ns
td(off)
Turn-off Delay Time
RG=3.3Ω
44
ns
tf
Fall Time
VGS=-10V
34
ns
Ciss
Input Capacitance
1175
1690
pF
Coss
Output Capacitance
195
pF
Crss
Reverse Transfer Capacitance
VGS=0V
VDS=25V .
f=1.0MHz
190
pF
VSD
Forward On Voltage2
IS=-2.1A, VGS=0V
-1.2
V
trr
Reverse Recovery Time
IS=-7A, VGS=0V, dI/dt=100A/µs
28
ns
Qrr
Reverse Recovery Charge
18
nC
-0.6
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 copper pad of FR4 board, t
很抱歉,暂时无法提供与“AO4435A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.76418
- 100+0.59717
- 600+0.45095
- 1200+0.44419
- 3000+0.40085
