WFCM4532L-510
WFCM4532L-510
    TNK(讯康)
    共模电感 1812 51μH -30%~+50% 2.8KΩ 200mA
WFCM4532L-510 数据手册
Products Specification For Approval Customer Name: Product Description: Cmmon Mode Chokes Customer Part Name: TNK Part Name: WFCM4532L-510 Specification No.: PS- WFCM4532L-510-TNK-A0 Issue Date: 2023-09-07 Customer's Approval This specification is received (Signature) Approved by Checked by Created by Zou Bin Zhou Jun Li Luo Hui 2023/09/07 2023/09/07 2023/09/07 www.tnk.net.cn Note: Please sign back to supplier with customer’s signature on it within 30 days after receiving it, or we will take it as approved by customer automatically. Any revision to the document shall be confirmed by both parties, otherwise it is invalid. When products delivery, please comply with the specification standard. www.tnk.net.cn Page 1 / 10 Change history Issue Revisions Version Prepared Approved Date 1 First issue A0 Li Luo Hui Zhou Jun 2023-09-07 www.tnk.net.cn Page 2 / 10 1. Scope & Outline RoHs compliance product. 2. Safety Specification Cmmon Mode Chokes 3. Appearance 3-1. Dimensions(Unit: mm) 2 3 1 4 1.0 1.2 3.2±0.2 · 3.0MAX. 4.5±0.2 3-3.Recommended Land Patterns(Unit: mm) 4.8 2.5 N2 3 2 1 3.8 4 0.7 3-2.Pin Connection N1 4. Electrical Specifications (at 25°C) Item Specification Measuring condition Inductance 51uH+50%-30% 100kHz/0.1V Impedance 1000Ω Min.(2800Ω Typ.) 10MHz D.C.R 1000mΩ Max. At 25°C Temperature Rise Current※1 200mA Max. Rated Voltage※2 50Vdc Max. Insulation Resistance※3 10MΩ Min. ※1 Temperature Rise Current: The DC current at which temperature rise is △T=40°C (Ta=25°C). PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not excelled 125°C under worst case operating conditions verified in the end application. ※ Rated current:Isat and Irms whichever is lower. Note: The rated current is subject to change depending on the cooling. www.tnk.net.cn Page 3 / 10 5. Impedance plot www.tnk.net.cn Page 4 / 10 6.Package Specification: 6-1. Taping Specification: 6-1-1. Reel Dimensions (Unit: mm) T LABEL D B C A COVER TAPE EMBOSSED CARRIER G *"D" INDICATES CARRIER TAPE WIDTH Reel size t QTY A D0 P2 B C D G T mm mm 12.0 ±0.5 12.4±2.0 Po (pcs/reel) mm mm mm mm 500 178±2 57±2 12.5±0.5 12.0±0.5 W Bo 13" 330 330 330 330 330 330 330 330 6-1-2.Taping Dimensions (Unit: mm) PAD IN BLACK Ao P Ko www.tnk.net.cn A0 B0 W K0 PO mm mm mm mm mm 4.50±0.5 5.50±0.5 12.0±0.3 4.0±0.5 4.0±0.1 Page 5 / 10 6-1-3. Packaging style of box. 6-1-3-1. Packing box is composed of the inner box and outer box. 6-1-3-2. One inner box consisting of 2 reels is packed in an outer box, thus 1000 products put in an outer box. 6-1-3-3. Paper cushions are placed on the top and bottom side of the outer box. T LABEL D B COVER TAPE EMBOSSED CARRIER G *"D" INDICATES CARRIER TAPE WIDTH 500 pcs in 1 reel (500pcs/reel) ,2 reels in an inner box (1000pcs/inner box) t 330 W Bo Po P2 D0 330 330 Ao Ko 330 330 330 330 330 www.tnk.net.cn PAD IN BLACK P 8 5 inner box in an outer box (5000pcs/Carton) 6-1-4.Label: 6-1-4-1. Use TNK standard label when the customer has no specified label. 6-1-4-2. When the customer has a designated label, use the customer specific label. 6-1-5.Notes: 6-1-5-1. This specification defines the standard packaging style and is subject to change depending on quantity or fractions. 6-1-5-2. Inside of cases shall be filled with cushions to keep the products stable. 6-1-5-3. Inspection Certificate:Attach size data and the electric characteristic result for each shipping lot as "Inspection Certificate". www.tnk.net.cn Page 6 / 10 7. Reliability Test Item Specified Value 1. Operating temperature range -40℃~+125℃ 2. Storage temperature range -40℃~+125℃ 3. External appearance The coil has no external defects Test Method and Remarks Including self-generated heat. On visual inspection. Inductance coefficient is 4. Temperature characteristics (0~2000ppm/℃) under Measurement of inductance shall be taken at room temperature and Max. Min. operating temperature. -40~+125℃ Terminal (electrode) Strength (For SMD) The test samples shall be soldered to the test board by the reflow. Applied force: 10N to X and Y directions. Duration: 5s. X 5. Terminal strength test No mechanical damage such as pin pull out, come off PCB board. Y Terminal Strength (For SMD) A static load 10.0N shall be applied to each terminal for 5S. no mechanical damage such as pin pull out, wire open, etc. The test samples shall be soldered to the test board by the reflow. Then it shall be submitted to below test conditions. 10~55Hz Frequency Range Total Amplitude 6. Vibration test The electrical parameters should meet the specification requirements. No significant abnormality in appearance. Sweeping Method 1.5mm(May not exceed 2 acceleration 196 m/s ) 10Hz to 5 Hz to 10Hz for 1 min. X Duration Y Z 7. Solderability www.tnk.net.cn At least a 90% continuous smooth new solder coating 1 hour in each of 3 mutually perpendicular directions (total 3hours). Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. The terminals shall be immersed in flux for about 5 sec then dipped in melting solder at 245±5℃ for 5±0.5sec. Page 7 / 10 Resistance to soldering heat(For SMD) The test samples shall be exposed to the solder reflow device as following fig(Peak temperature 260℃)for 2times with a cooldown in between. 8. Resistance to soldering heat The electrical parameters should meet the specification requirements. No significant abnormality in appearance. Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. See Figure 1 below Resistance to soldering heat(For SMD) Terminals shall be immersed in solder of 260±5℃ to the depth within 1.5mm of the coil body for 10±1 sec. Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. The test samples shall be stored in a thermostatic chamber set at specified temperature and humidity as shown in below table. 9. Humidity test 10. High temperature expose test 11. Low temperature expose test www.tnk.net.cn The electrical parameters should meet the specification requirements. No significant abnormality in appearance. The electrical parameters should meet the specification requirements. No significant abnormality in appearance. The electrical parameters should meet the specification requirements. No significant abnormality in appearance. Temperature 30±2℃ Humidity 90~95%RH Time 96±4hours Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. The test samples shall be stored in a thermostatic chamber set at specified temperature as shown in below table. Temperature 125±2℃ Time 96±4hours Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. The test samples shall be stored in a thermostatic chamber set at specified temperature and humidity as shown in below table. Temperature -40±2℃ Time 96±4hours Recovery: At least 2hrs of recovery under the standard condition after the test, after which measurement shall be made and compared with the initial values. Page 8 / 10 8.Recommended reflow curve: Figure 1 TL = 217℃ Tp = 260±5℃ ts=60-180s Ts max=200℃ Ts min=150℃ tL=60-150s tp=tp=20-40s T25℃ to peak=8min max Ramp up rate=3℃/s max Ramp down rate=6℃/s max *ROHS Compliant *Solder wire Sn 99/Ag0.3/Cu 0.7 www.tnk.net.cn Page 9 / 10 9. Others: 9-1. The contents of this document only assures the characteristics and quality of the sole components. Regarding its use, please evaluate and check that they work correctly when fixed to your equipment. 9-2. We will not take any responsibility for any troubles caused by usage beyond the range that this document specifies. 9-3. The products in this specification are targeted for use in general electrical equipment. Please do not apply on equipment that need. Especially high reliability and/or the defects caused by the product will have direct influence on a person's life or property. 9-4. Period of quality assurance shall be 1 year from the date of shipment. The products must be controlled normal conditions, thus in cases where the products are put under abnormally high temperature and humidity or contamination and damage by natural disasters or other reasons, the above quality assurance period will not be valid. 9-5. Both parties are under confidentiality obligation regarding the information contained in this document. www.tnk.net.cn This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. TNK Electronic Technology reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. TNK Electronic Technology also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: TNK Electronic Technology does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Please read the "Notice for TNK products" before using this catalog,If there is no record in this product catalogue, and if it is highly reliable, please contact the company's engineer in advance. www.tnk.net.cn Page 10 / 10
WFCM4532L-510 价格&库存
很抱歉,暂时无法提供与“WFCM4532L-510”相匹配的价格&库存,您可以联系我们找货
