LMP25NF3P0R004
LMP25NF3P0R004
    PROSEMI(普罗森美)
    电流采样电阻 2512 4mΩ ±1% ±50ppm/℃ 3W
LMP25NF3P0R004 数据手册
Current Sensing Resistors LMP25 Series RoHS 2015/863/EC Description Proprietary processing technique produces extremely low resistance values Very low inductance Low thermal EMF Metallic Material Part Numbering System LMP 25 N F 3P0 R001 S Wide electrode Resistance Code R001 : 1mΩ R010 : 10mΩ Power Rating R500 : 500 mΩ Series Metal Alloy Size 25: 2512(6432) 2P0 : 2W 3P0 : 3W Material N:NiCu K:Kamar Resistance Tol. D:±0.5% F: ±1.0% G: ±2.0% J: ±5.0% Standard Parameter 1mΩ~100mΩ : 3W 1mΩ~500mΩ : 2W Power Rating 1~500mΩ Resistance Value Operating Temperature Range -55 to +170°C ± 50 ppm/°C Component Temperature Coefficient (TCR) Maximum Working Voltage (V) (P x R)1/2 Rating current (A) (P / R)1/2 P=Power Rating; R=Resistance Value Standard Electrical Specifications Type Rating Power at 70℃ 2W Resistance Range(mΩ) T.C.R. (ppm/℃) ±0.5%(D) ±1.0%(F) ±2.0%(G) ±5.0%(J) 50 101-500 R101-R500:Kamar 1-4 R001- R004: NiCu R001-R004:Wide 2-100 R002-R100: NiCu R002-R100:Narrow LMP25 2W&3W Electrode Operating Temperature(℃) R101-R500:Narrow -55~+170°C 50 Specifications are subject to change without notice. C PROSEMI Meterial Document No:P0R0220230308007L 1 of 6 www.prosemitech.com Current Sensing Resistors LMP25 Series Type Power LMP25 2W&3W L W C 6.4 ±0.2 3.2 ±0.2 Unit: Millimeters t 0.95±0.25 (Narrow) 2.1±0.25 (Wide) 0.9±0.2 Recommended land pattern Unit: Millimeters Resistance Range ( Ω ) a b L 0.001-0.004(Wide) 4.0±0.1 3.1±0.1 1.3±0.1 0.002~0.500(Narrow) 4.0±0.1 2.1±0.1 4.1±0.1 Product structure diagram Mark Over Coating Plating Sn Plating Ni Heat sink Alloy material Specifications are subject to change without notice. C PROSEMI Document No:P0R0220230308007L 2 of 6 Plating Cu www.prosemitech.com Current Sensing Resistors LMP25 Series Power Derating Curve Power Ratio (%) For resistors operated in ambient temperatures 70°C, power rating shall be derated inaccording with the curve below: 100 -55 70 170 Ambient Temperature (°C) Recommended Solder Curve Pb – Free assembly Reflow Condition Pre heat - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (Min to Max) (ts) Average ramp up rate (Liquidus Temp (TL) to peak TS(max) to TL - Ramp-up Rate Reflow - Temperature (TL) (Liquidus) - Time(tL) Peak Temperature (TP) Time within 5°C of actual peak Temperature (tp) Specifications are subject to change without notice. C PROSEMI Document No:P0R0220230308007L 3 of 6 60 – 120 secs 5°C/second max 5°C/second max 217°C 60 – 150 seconds 260°C 20 – 40 seconds Ramp-down Rate 5°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Wave Soldering 260°C, 10 seconds max. Hand Soldering 350°C, 5 seconds max. www.prosemitech.com Current Sensing Resistors LMP25 Series Product Characteristics Item Resistance Test condition/ Methods Limited Standard Refer to Spec IEC60115-1 4.5 Refer to Spec MIL-STD-202 Method 304 Apply overload for 5 seconds and measure the resistance change rate after standing for 24 hours. 5 times the rated power for 5 seconds ≤±0.5% MIL-R-26E 260℃± 5℃ time:10sec± 1sec ≤±0.5% -55℃ (30min)/+125℃(30min), 1000 cycles ≤±0.5% -55℃ for 1000hours, No power ≤±0.5% MIL-STD-26E 125℃ for 1000hours, No power ≤±1% IEC6011501-4.25 ≤±0.5% MIL-STD-202 Method103 ≤±0.5% JIS-C5201 At least 95% of surface area of electrode shall be covered with new solder IEC60115-1-4.17 JIS-C5201-4.17 Measuring resistance value at room temperature 25℃±5℃ TCR =(R-R0)/R0(T2-T1)X 106 T1 T2 R : resistance of room temperature Temperature coefficient 0 R: resistance of 125℃ of resistance T1: Room temperature T2: Temperature at 125℃ Short time Overload Resistance to Soldering Heat Temperature Cycling Low temperature Storage High Temperature Storage Bias Humidity Joint Strength of Solder +85℃,85% RH,10%bias, 1000hours MIL-STD-202 Method 210 MIL-STD-202 Method107G Soldered on the bending test plate, put on the bending testing machine, pressed under force in the center of the test plate, measure its resistance variance rate under load Solderability 245±5℃, 2±0.5sec Operational life 70℃± 2℃, 1000 hours, at rated power 1.5 hours “ON”, 0.5 hours “OFF” Specifications are subject to change without notice. C PROSEMI Document No:P0R0220230308007L 4 of 6 ≤±1% MIL-STD-202 Method 108 www.prosemitech.com Current Sensing Resistors LMP25 Series Tapping & Package Type A ±0.2 Pack B ±0.2 D0 +0.5-0 E ±0.1 F ±0.05 P0 ±0.1 P1 ±0.1 P2 ±0.1 W ±0.2 D1 ±0.05 T ±0.15 Reel Specification Type A 2512 2.00±0.5 B 13.50±0.5 C D M W 21.00±0.5 80.00±1.0 178.00±2.0 13.80±0.5 Packaging Quantity: 4, 000pcs 8mm wide tape on 178mm(7 inch) diameter reel -specification EIA Standard 481. Specifications are subject to change without notice. C PROSEMI Document No:P0R0220230308007L 5 of 6 www.prosemitech.com Current Sensing Resistors LMP25 Series Peel strength of upper belt Stripping speed: 300 mm / min; The peel force is between 0.1N and 0.7n. Storage conditions & shelf life It can be stored for 2 years under closed conditions with temperature of 5 ° C ~ 35 ° C and relative humidity of 40 ~ 75 Please avoid the following harsh environment during storage to avoid affecting the product performance and solder connectivity: the places with corrosive gases such as sea breeze, Cl2, H2S, NH3, SO2 and NO2 shall be stored without direct sunlight. Precautions for product use When measuring the resistance value before welding, a special resistance meter with high precision shall be used. When measuring, a 4-wire probe or fixture must be used. 4. When measuring parts with a wire measuring needle, the 4 measuring needles must indeed contact the parts. Avoid damaging the protective layer during manual welding or clamping with tweezers. When the PCB is divided or fixed on the support, be careful to avoid excessive bending causing mechanical stress to the resistor. It shall be used within the rated power range within the specification, especially when the power exceeds the rated value, which may affect the reliability of the product Specifications are subject to change without notice. C PROSEMI Document No:P0R0220230308007L 6 of 6 www.prosemitech.com
LMP25NF3P0R004 价格&库存
很抱歉,暂时无法提供与“LMP25NF3P0R004”相匹配的价格&库存,您可以联系我们找货
LMP25NF3P0R004
  • 5+0.51280
  • 50+0.41586
  • 150+0.36739
  • 500+0.33103
  • 2500+0.30194
  • 4000+0.28744
库存:3198
