XXDBELNAOF-24.000000MHZ
    TAITIEN(泰艺)
    SMD3225_4P
    无源晶振 24MHz ±10ppm 12pF -40℃~+85℃
XXDBELNAOF-24.000000MHZ 数据手册
XX Type 3.2 x 2.5 mm SMD Crystal Actual Size FEATURE - Typical 3.2 x 2.5 x 0.7 mm ultra thin ceramic package. - 8mm width Tape & Reel package for automatic assembly. - Tight tolerance 10 ppm available. TYPICAL APPLICATION - Bluetooth, Mobile Phone, GPS - Wireless LAN, 4G/LTE - Hard Disk RoHS Compliant XX DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ T O P V IE W ] 0.70±0.20 [ S ID E V IE W ] [ B O T T O M V IE W ] #4 #3 #1 #2 1.2 1.1 2.50±0.20 GND GND 1.6 3.20±0.20 #2 and #4 are connected to the cover (please connect to ground) #4 0.90±0.10 #3 2.2 0.90±0.10 1.50±0.10 2.10±0.10 #1 #2 ELECTRICAL SPECIFICATION Parameter Min. Storage Temp. Range Standard Frequency Level of Drive Shunt Capacitance (Co) Insulation Resistance Aging Typical -55 500 MΩ@ DC100V Max. 16, 24, 26, 27, 32, 40 10 ±1.0 to ±3.0 Unit 125 200 3.0 - MHz µw pF ppm / year Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. EQUIVALENT SERIES RESISTANCE (E. S. R.) Frequency Range 12 MHz Fo 13 MHz < Fo 19.5 MHz < Fo 27 MHz < Fo 13 MHz 19.5 MHz 27 MHz 60 MHz FREQ. STABILITY vs. TEMP. RANGE Temp. ( o C) ppm ±5 ±10 ±15 MODE E.S.R A1 A1 A1 A1
XXDBELNAOF-24.000000MHZ 价格&库存
很抱歉,暂时无法提供与“XXDBELNAOF-24.000000MHZ”相匹配的价格&库存,您可以联系我们找货
    • 5+0.79186
    • 50+0.62597
    • 150+0.54303
    • 500+0.48082
    库存:2566
