3S26000361
3S26000361
    YL(惠伦晶体)
    SMD3225_4P
    26MHZ ±10PPM 9PF
3S26000361 数据手册
36 Donghuan Road,Jitigang Village,Huangjiang,Dongguan,Guangdong Province,P.R.China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER : PRODUCT TYPE : SMD X'TAL 3.2*2.5(4PAD) NOMINAL FREQ. : 26.000000 MHz FL P/N : 3S26000361 REVISION : S0 CUSTOMER P/N : CUSTOMER'S APPROVAL&DATE FL CORPORATION APPROVED CHECKED DESIGNED Jay Lee Jin Qi Chen XuanRu MSL1 RoHS Compliant 3S26000361 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: CONTENTS S0 PAGE ‧ SPECIFICATION REVISION RECORD SHEET 2 ‧ ELECTRICAL SPECIFICATIONS 3 ‧ DIMENSIONS & MARKING 4 ‧ STRUCTURE ILLUSTRATION 5 ‧ RELIABILITY TEST SPECIFICATIONS 6 7/8 ‧ PACKAGING REQUIREMENT ‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES 9 ATTACHMENT(optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO PAGE: 1/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 3S26000361 S0 PAGE: 2/9 SPECIFICATION REVISION RECORD SHEET Rev. Revise page S0 N/A Revise Contents Initial released Date Ref. No. Reviser 18-Nov-19 N/A Chen XuanRu TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: 3S26000361 S0 VER: PAGE: PRODUCT DESCRIPION Standard atmospheric conditions Unless otherwise specified. The standard range of atmospheric conditions for making measurement and tests are as follow: 25±2℃ Ambient temperature : 40%~70% Relative humidity If there is no doubt the results, measurement shall be made within the following limits: 25±2℃ Ambient temperature : 40%~70% Relative humidity : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode) ELECTRICAL SPECIFICATIONS No. Items 1 Nominal Frequency Electrical Spec. Symbol Min Typ Max Units Remarks FL 26.000000 MHz - - Fundamental - - CL 9.0 pF - 4 Frequency Tolerance - ±10 ppm at 25±2℃ 5 Frequency Stability - ±15 ppm at -40~+85℃ (reference 25℃) 6 Shunt Capacitance C0 2 Oscillation Mode 3 Load Capacitance - 7 Aging (/1 year) - 8 Operating Temperature - -40 9 Storage Temperature - - 3 ppm/year at 25±2℃ 85 ℃ - -40 85 ℃ - ESR - 30 ohms - 11 Insulation Resistance IR 500 - M-ohms at DC 100V 12 Drive Level DL 100 uW - 10 Equivalent series resistance ±3 pF - 3/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: DIMENSIONS unit:mm 3S26000361 S0 PAGE: CONNECTION DIAGRAM (TOP VIEW)  #3 #4 #3  #4 #1 #2 #2 #1 Pin #1 #2 #3 #4 Function Xtal terminal (Input) GND terminal Xtal terminal (Output) GND terminal LAND PATTERN unit:mm MARKING Frequency EX: 26.000MHz = 260 SUGGESTED REFLOW PROFILE Total time : 360 sec. Max. Temp. Solder melting point : 225 oC 10 sec. Max. 260 5 220 60 sec. Max. 180 150 120 sec. Max. Time 4/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 3S26000361 S0 PAGE: STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS QTY FINISH/SPECIFICATIONS 1 Cap(Lid) Kovar(Fe+Co+Ni) 1 Ni plating 2 Base(Package) Almina Ceramics (AI2O3) 1 3 Pad(Package) Ni + Au 4 Ni+Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 2 Silicone resin 6 Electrode Noble metal 2 - 5/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 3S26000361 S0 PAGE: 6/9 RELIABILITY SPECIFICATIONS 1. MECHANICAL ENDURANCE Test Item No. Drop Test 1 2 Shock Test 3 Mechanical Shock 4 Vibration Test Methods 150 cm height, fall freely onto stainless plate 3 times. 150g/150cm Height,3times in the direction of ±x, ±y, ±z on concrete floor JIS C6701 IEC-68-02-27 Device are shocked to half sine wave ( 1000 G ) threemutually MIL-STD-202F pendicular axes each 3 times. 1.0m sec. duration time Frequency range 10 ~ 55 Hz Amplitude 1.52 mm MIL-STD-883E Pendicular axes each test time 2 hours(x,y,z Axis) Total test time 6 hours 5 Gross Leak 6 Fine Leak 7 Solderability 8 Resistance To Soldering Heat Standard Sample For Automatic Gross Leak Detector Test Pressure 2kg/cm2 Helium Bombing 4.5kgf/cm2 for 2 hr MIL-STD-883E MIL-STD-883E o o Temperature Immersing depth Immersion time Flux 245 C +/- 5 C 0.5 mm minimum 10 +/- 0.5 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) Pre-heat temperature Pre-heat time Test temperature Test time 125 oC 60 ~ 120 sec. 260 +/- 5 oC 5 +/- 1 sec. MIL-STD-883E MIL-STD-202F 2. ENVIRONMENTAL ENDURANCE Test Item No. 9 High Temp. Storage 10 Low Temp. Storage Test Methods + 125 C +/- 3 C for 500 +/- 12 hours - 40 oC +/- 3 oC for 500 +/- 12 hours Total 100 cycles of the following temperature cycle o o MIL-STD-883E 1 cycle 125+/- 3 oC 11 Thermal Shock 25 oC -55+/- 3 oC MIL-STD-883E 30 min. 30 min. 10 min. max. 12 High Temp&Homidity 85℃±3℃, RH 85%,500Hrs JIS C5023 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 3S26000361 S0 PAGE: PACKING : (EIA-481-2) SMD X'TAL 3.2*2.5(4PAD) 26 3S26000xxx A0 Dimension PKG Type 3225(8mm) Standard Reel Quantity is A0 B0 K0 Unit : mm T W E F 2.70±0.1 3.40±0.1 1.4±0.1 0.25±0.5 8±0.3 1.75±0.2 3.50±0.1 P1 P2 D1 D0 P0 4±0.1 2±0.1 1±0.05 1.55±0.05 4±0.1 3,000 pcs per reel. THE INSPECTION FOR TAPE TENSION REMARK : NA 7/9 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 3S26000361 S0 PAGE: 8/9 SMD PRODUCT PACKING STANDARD Out-going packing instruction Reel Packing name:reel standard: diameter 18cm material: plastics Inner Packing name:inner box standard: L19.0xW19.0xH2.5cm material:B corrugated paper Carton name:carton standard: L34.0xW22.0xH22.0cm material:AB corrugated paper(10 boxes enter) L1 L1 L1 The label instruction Label Drawing Mark Name of Article Spec. L1 条码标签 1.Date Code Bar Code 2.Lot No. Label 3.Part No. (Chintz Paper) 4.Freq 5.Q'ty Size Printing 75x35mm White Remark Specifications on the label is for the use of templates with different product specifications may vary. If customer specified requirements for labels packaging. please provide the operation procedure. TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 FL P/N: VER: 3S26000361 S0 PAGE: 9/9 Range Products Packing Material Banned Substances Maximum concentration ppm(mg/kg) Maximum concentration ppm(mg/kg) 1.镉及镉化合物 Cadmium and cadmium compounds 100 100 2.铅及铅化合物 Lead and lead compounds 1000 100 3.汞及汞化合物 Mercury and mercury compounds 1000 100 4.六价铬化合物 Hexavalent-Chromium VI (Cr+6) 1000 100 5. 聚 溴 联 苯 PBB Polybrominated biphenyls 1000 N/A 6. 聚 溴 二 苯 醚 PBDE Polybrominated diphenyl ethers 1000 N/A 7.邻苯二甲酸二(2-乙基己基)酯 DEHP Di (2-ethylhexyl) phthalate 1000 N/A 8.邻苯二甲酸丁苄酯 BBP Butyl Benzyl Phthalate 1000 N/A 9.邻苯二甲酸二丁酯 DBP Dibutyl Phthalate 1000 N/A 10 邻苯二甲酸二异丁酯 DIBP Diisobutyl Phthalate 1000 N/A 900、900、900、900 注:Br+Cl<1000 N/A 12.包装材料中重金属(汞、镉、六价铬、 铅、PBB、PBDE)之总量 Heavy metals (mercury, cadmium, lead, Cr+6,PBB and PBDE) in packing materials N/A 100 铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬 (Cr+6)
3S26000361 价格&库存
很抱歉,暂时无法提供与“3S26000361”相匹配的价格&库存,您可以联系我们找货
