CXC3X320000GHVRP5M
CXC3X320000GHVRP5M
    PARTRON(帕创)
    SMD3225_4P
    无源晶振 10ppm
CXC3X320000GHVRP5M 数据手册
APPROVAL SHEET PRODUCT NAME SMD CRYSTAL UNIT USER NAME USER PART NO. Provider PARTRON PARTRON MODEL CXC3X320000GHVRP5M Issued by Checked by Approved by Issued by Checked by Approved by In Charge L.J.Y. M.N.S. K.J.M. Division R & D Q C R & D CUSTOMER PARTRON MSL Halogen-Free LEAD FREE MSL LEVEL 1 Case Fab China/Yantai/Partron Assembly China/Yantai/Partron Final Test & Packing China/Yantai/Partron ※ Please return one copy with approval to PARTRON 2011. 08. 08 22-6, Seokwoo-dong, Hwaseong-si, Gyeonggi-do, Korea 445-170 TEL : 82-31-201-7750 A1-PTR A216 - 1 /15- Contents A1-PTR A216 1. Revision History - - - 3 2. Electrical characteristics - - - 4 3. Mechanical characteristics - - - 4. A Primary test result - - - 7 5. Reliability test - - - 8 6. Soldering Condition - - - 9 6 7. Construction - - - 10 8. Notices - - - 11 9. Packing - - - 12 - 2 /15- 1. Revision History Rev. Date Rev. page Revision Content and Reason V1.0 '11.08.08 All Page First-edition A1-PTR A216 Remark - 3 /15- 2. Electrical Characteristics No. Item Symbol 2.1 Frequency fo 2.2 Frequency Tolerance 2.3 Temperature range Content 32.0000 MHz Δf/fo ± 10 ppm Storage TSTG -40 to 85℃ Operating TOPR -20 to 70℃ ∆f/fo ±10ppm (-20~70 CTQ (@+25℃ ±2℃) ℃, REF @+25℃ ±2℃) 2.4 Frequency stability 2.5 Drive level DL 100 uW max. 2.6 Equivalent series resistance R1 60 Ω max. 2.7 Oscillation mode O/T Fundamental 2.8 Shunt capacitance CO 3 pF max. 2.9 Motional capacitance C1 10 fF max. 2.10 Load capacitance CL 11.5 pF 2.11 Aging fa ±3ppm/3year(@25 2.12 Insulation resistance IR 500 MΩ min @ 100VDC ℃) [REMARK] A1-PTR A216 - 4 /15- ] 2-1 Crystal Equivalent Circuit and Application Circuit [Crystal and equivalent circuit] [Application cicuit for oscillation] A1-PTR A216 - 5 /15- 3. Mechanical characteristics 3-1 Outline Dimensions and Pin connections 1.0±0.2 0.8±0.2 #4 #3 HOT D [Top View] #1 #2 HOT E #1 #2 HOT B #4 #3 C HOT A [Bottom View] 2- 0.8 Size in mm 2- 0.45 E 4- 1.15 D 1.20 0.70 ±0.10 ±0.10 #3 C 0.75 max. #2 B #4 A 3.20 2.50 ±0.10 ±0.10 4- 1.4 #1 HOT #2 GND #3 HOT #4 GND #1 Pin connections [Recommanded solder pattern (Top View)] 3-2 Marking and LOT No ITEM #4 #3 26 200M 00M 19 P 32 00M ① ② 24 00M xx YMD X ③ #1 ④ ① ② ③ MARKING P Partron logo 32 00M Frequency: 32.0000MHz xx CRYSTAL CL (2 digit) Y : the last 1 digit of year ⑤ ※Laser Marknig REMARK #2 ④ M : 1 digit of month (Jan to Sept; 1 to 9, Oct; A,Nov B, Dec;C) YMD D : 1 digit of day 1 to 9, A to V (A=10, V=31) EX) 769 = 2007.06.09, 8AS = 2008.10.28 ⑤ A1-PTR A216 X Internal Code - 6 /15- 4. A Primary test result Electrical Characteristics Testing Data Item Spec A1-PTR A216 Result FL (ppm) C0 (pF) R1 ( Ω) C1 (fF) L (mH) TS (ppm/pF) High 10.0 3.0 60.0 10.0 - - Low -10.0 - - - Max Pass 4.0 1.1 18.4 3.8 6.8 5.2 Min Average Pass -2.6 1.1 13.2 3.6 6.5 5.0 Pass 2.4 1.1 15.2 3.7 6.6 5.1 Stdev Pass 1.9 0.0 1.6 0.1 0.1 0.1 1 2 3 4 5 6 7 8 9 10 Pass 2.0 1.1 17.0 3.7 6.6 5.1 Pass 2.9 1.1 15.8 3.8 6.5 5.2 Pass 3.4 1.1 15.3 3.6 6.8 5.0 Pass -2.6 1.1 15.7 3.7 6.7 5.0 Pass 2.9 1.1 14.6 3.8 6.6 5.1 Pass 3.6 1.1 14.3 3.6 6.8 5.0 Pass 2.0 1.1 13.5 3.7 6.7 5.0 Pass 3.5 1.1 13.7 3.8 6.5 5.2 Pass 4.0 1.1 13.2 3.8 6.5 5.2 Pass 2.8 1.1 18.4 3.8 6.5 5.2 - - Remark - 7 /15- 5. Reliability test 5.1 Environment Test Contents Condition ℃±5℃, 240 hr -55℃±5℃, 240 hr High temperature Storage humidity Storage *Testing is complete, leave +125 Low temperature Storage High temperature High Remark at room temperature for 24 hours, and ℃ ℃, RH=85%, 96 hr +85 ±5 ℃ ℃, RH=100%, 24hr PCT +121 ±5 ℃ ℃) Measure.(25 ±5 * Be satisfied with contents No 2. Specification 5.2 Thermal shock , Reflow Test Contents Condition Remark *Testing is complete, leave ℃±5℃,+85℃±5℃, 30 min, Thermal shock -40 32 cycle 24 hours, and ℃ , 30∼60 sec Peak Heating 260℃±5℃ , 30sec Max Pre Heating 200±5 REFLOW at room temperature for ℃ ℃) Measure.(25 ±5 * Be satisfied with contents No 2. Specification 5.3 Mechanical Test Contents Vibration Condition Frequency : 10~500Hz, 10 ×9.8 Remark ㎨(G) Sweep time 15min ,X.Y.Z each 5 times *Testing is complete, leave at room temperature for 1 hours, and ℃ ℃) Measure.(25 ±5 12 times falling at a 160cm height Drop test (falling with jig) * Be satisfied with contents No 2. Specification 5.4 Table Frequency change permitted A1-PTR A216 ±3ppm Max. - 8 /15- 6. Soldering Condition 6.1 Standard Reflow soldering condition 240℃ 200℃ 160℃ 100℃ Max최대temp 온도 240 ±5 ℃ pre heating 예열 130 ~ 130~180℃ 180℃ 25℃ 0℃ 90 ~ 180초 90 ~180 sec 6.2 The maximum temperature guarantees to the 260 최대 30초 max 30sec 30~60sec 30∼60 초 ℃(10sec Max) 6.3 Soldering Iron Method - Pre heating - Max temp - Time A1-PTR A216 ℃ (30 ~ 300 sec) : 410℃ Max : 120 : Max 4 sec - 9 /15- 7. Construction I Ceramic package 2 Crystal blank 5 Electrode 3 Conductive epoxy 4 Cover A1-PTR A216 No item 1 Ceramic package 2 Crystal blank 3 Conductive Epoxy 4 Lid(Cover) 5 Electrode - 10 /15- 8. Notices 8-1 Max. two(2) times reflow is allowed. Once miss soldering is happen, hand work soldering by soldering iron is recommended. ℃ x within 5 sec) (+400 8-2 Ultrasonic vibration may cause deterioration and destruction of the components. Please avoid ultrasonic cleaning 8-3 We recommend storing products at +15 8-4 ESD Level : ℃ to +35℃ and 25% R.H to 75% R.H Class2(2000V ~ 4000V) 8-5 MSL LEVEL 1 (JEDEC J-STD-020C) ITEM 1 Floor Life Soak Requirements Time Conditions Time Conditions Unlimited =< 30℃/85%RH 165+5/-0 =< 85℃/85%RH 8-6 Unless adequate negative resistance is allocated in the oscillation circuit, start up time of oscillation may be increased, or no oscillation may occur. In order to avoid this, please provide enough negative resistance in the circuit design. ◎ How to check the negative resistance (1) Connect the resister (R) to the circuit in series with the crystal resonator. (2) Adjust R so that oscillation can start (or stop). (3) Measure R when oscillation just start (or stop) in above (2). (4) Get the negative resistance -R = R + R1 value (5) Recommended -R [-R] > R1 max × 5 A1-PTR A216 - 11 /15- 9. Packing 9.1 Reel, carrier tape material item Main Material Cover Tape PE (Polyester film) Carrier Tape PC (Poly Carbonate +Carbon) or (Clear Poly Carbonate) Reel PS (Poly Styrene) 9.2 inner Box :1 reel/inner box and 2,000 pcs/1 reel. 9.3 Outer Box : 10 inner boxes/Outer Box Total 20,000 pcs are packed in a 1 outer box 9.4 Reel and Carrier tape dimensions(unit : mm) ■ Carrier tape *Heating press cover tape A1-PTR A216 - 12 /15- 9.5 Reel Dimensions (unit : mm) A1-PTR A216 - 13 /15- 9.6 Tape and Reel Trailer Top Tape 200 min Leader Empty Pockets 150 min Products Empty Pockets 150 min Top Tape 250 min Unreeling Direction A1-PTR A216 - 14 /15- 9.7 Inner, outer box Dimensions (unit : mm) A1-PTR A216 - 15 /15-
CXC3X320000GHVRP5M 价格&库存
很抱歉,暂时无法提供与“CXC3X320000GHVRP5M”相匹配的价格&库存,您可以联系我们找货
CXC3X320000GHVRP5M
    • 5+1.31026
    • 50+1.04793
    • 150+0.93550
    库存:47
