7V13000001
7V13000001
    TXC(台晶)
    SMD3225_4P
    13MHZ 10PF ±20PPM
7V13000001 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD GLASS SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 13.000000MHz TXC P/N : 7V13000001 REVISION : A2 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Data:12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD GLASS SEALING X'TAL 3.2*2.5 NOMINAL FREQ. : 13.000000MHz TXC P/N : 7V13000001 REVISION : A2 PE/RD QA MFG 25-May-09 25-May-09 25-May-09 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required. RoHS Compliant FMT-DOC024 Issue Data:12.15'08 VER.E TXC CORPORATION Rev Revise page A1 N/A A2 3 FMT-DOC024 TXC P/N: Revise contents Initial released Marking Change 7V13000001 A2 REVISION: PAGE: 1 Date Ref.No. Reviser 5-Mar-09 N/A Xiaoyan Jiang 25-May-09 ECN-09N050404 Xiaoyan Jiang Issue Data:12.15'08 VER.E TXC CORPORATION 7V13000001 TXC P/N: A2 REVISION: PAGE: 2 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by HP E5100A or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.018±0.001 g/pcs Parameters 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance 4 Frequency Tolerance SYM. Electrical Spec. MIN TYPE FL 13.000000 MAX Notes UNITS MHz - - Fundamental - - CL 10 pF - - ±20 ppm at 25 ℃ ± 3 ℃ Rr - - 80 Ω - 6 Operating Temperature Range - -20 ~ 70 ℃ - 7 Frequency Tolerance - 5 Series Resonant Resistance ±20 8 Drive Level DL - 9 Shunt Capacitance C0 0 10 - - 2 10 Aging - 11 Insulation Resistance - 500 - 12 Storage Temperature Range - -40 ~ FMT-DOC024 ppm ±3 Over Operating Temp. Range (Reference 25℃) uW - pF - ppm 1st Year - MΩ at DC 100V 85 ℃ - Issue Data:12.15'08 VER.E TXC CORPORATION TXC P/N: 7V13000001 A2 REVISION: PAGE: 3 UNIT:mm ■ DIMENSIONS ■ MARKING   T□□□ TXC Logo Frequency Code ex:14.318180 MHz=143 □□□ Lot Code Line Code Date Code Date Code MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2001 2005 2009 2013 2017 A B C D E F G H J K L M 2002 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2003 2007 2011 2015 2019 a b c d e f g h j k l m 2004 2008 2012 2016 2020 n p q r s t u v w x y z This date code will be cycled every four years (℃) ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ 10 sec 260 220 180 150 Time (sec) 120 sec FMT-DOC024 60 sec Issue Data:12.15'08 VER.E TXC CORPORATION TXC P/N: 7V13000001 REVISION: A2 PAGE: 4 ■ STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Cap Ceramic Color black 2 Package Ceramic Color black 3 PAD Au 4 Crystal blank SiO2 5 Conductive adhesive Ag Tungsten metalize + Ni plating + Au plating Silicon resin 6 Electrode Ag + Cr - 7 Glass - - FMT-DOC024 Issue Data:12.15'08 VER.E TXC CORPORATION TXC P/N: 7V13000001 A2 REVISION: PAGE: 5 ■ PACKING : (EIA-481-2) DIMENSIONS A B C D E F G H 1.40 3.40 2.70 4.00 8.00 4.00 1.50 1.75 (UNIT : mm) REMARK : Trailer Parts 160mm(Min) Leader Empty Sealed 230mm(Min) 160mm(Min) User direction of feed W W1 2.0 L1 DIMENSIONS FMT-DOC024 L L1 W W1 178 13 11.5 8 L pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel Issue Data:12.15'08 VER.E TXC CORPORATTXC P/N: 7V13000001 REVISION: PAGE:6 A2 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item Test Methods CRITIREA REF.DOC 1.1 Drop Test 100 cm height, 3 times on concrete floor. △F/F
7V13000001 价格&库存
很抱歉,暂时无法提供与“7V13000001”相匹配的价格&库存,您可以联系我们找货
7V13000001
    • 5+1.24287
    • 50+0.97071
    • 150+0.85407
    • 500+0.70859
    库存:2365
