2S40000063
2S40000063
    YL(惠伦晶体)
    SMD2520_4P
    40MHZ ±10PPM 14PF
2S40000063 数据手册
36 Donghuan Road,Jitigang Village,Huangjiang,Dongguan,Guangdong Province,P.R.China TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com PRODUCT SPECIFICATION SHEET CUSTOMER : PRODUCT TYPE : SMD X'TAL 2.5*2.0(4PAD) NOMINAL FREQ. : 40.000000 MHz FL P/N : 2S40000063 PREPARE REVISION : A0 CUSTOMER P/N : CUSTOMER'S APPROVAL&DATE PREPPR P PREP QA QA QA PREP QAQA QA APPROVED PREP FL CORPORATION APPROVED Yasuda Katsushi CHECKED QA DESIGNED QA QA APPROVED QA APPROVED PREP PREP QA QA QA QA QA QA Chen XuanRu Jin QA Qi RoHS Compliant 2S40000063 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: CONTENTS A0 PAGE ‧ SPECIFICATION REVISION RECORD SHEET 2 ‧ ELECTRICAL SPECIFICATIONS 3 ‧ DIMENSIONS & MARKING 4 ‧ STRUCTURE ILLUSTRATION 5 ‧ RELIABILITY TEST SPECIFICATIONS 6 ‧ PACKAGING REQUIREMENT 7/8 ‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES 9 ATTACHMENT(optional) ‧ ELECTRICAL CHARACTERISTICS TEST A YES NO ‧ TEMPERATURE CHARACTERISTICS TEST B YES NO PAGE: 1/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2S40000063 A0 PAGE: 2/9 SPECIFICATION REVISION RECORD SHEET Rev. Revise page A0 N/A Revise Contents Initial released Date Ref. No. Reviser 8-Apr-19 N/A Chen XuanRu 2S40000063 YL P/N: TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 A0 VER: PAGE: PRODUCT DESCRIPION Standard atmospheric conditions Unless otherwise specified. The standard range of atmospheric conditions for making measurement and tests are as follow: 25±2℃ Ambient temperature : 40%~70% Relative humidity : If there is no doubt the results, measurement shall be made within the following limits: 25±2℃ Ambient temperature : 40%~70% Relative humidity : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode) ELECTRICAL SPECIFICATIONS Electrical Spec. No. Items 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance Remarks Symbol Min Typ Max Units FL - 40 - MHz - - - - AT-cut Fundamental CL - 14.0 - pF - 4 Frequency Tolerance - -7 - 7 ppm at 25±2℃ 5 Frequency Stability - -15 - 15 ppm at -40~+85℃ (reference 25℃) 6 Shunt Capacitance C0 - - 3 pF 7 Motional Capacitance C1 - - - fF 8 Motional Inductance L1 - - - mH 9 Aging (/1 year) - -3 - 3 ppm/year at 25±2℃ 10 Reflow - -3 - 3 ppm after 24Hrs 11 Operating Temperature - -40 85 ℃ - 12 Storage Temperature - -40 85 ℃ - ESR - 40 ohms - 14 Insulation Resistance IR 500 - M-ohms at DC 100V 15 Drive Level DL 100 uW - 13 Equivalent series resistance - 3/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: DIMENSIONS unit:mm 2S40000063 A0 PAGE: CONNECTION DIAGRAM (TOP VIEW)  #4 #3 #3  #4 #1 #2 #2 #1 Pin #1 #2 #3 #4 Function Xtal terminal (Input) GND terminal Xtal terminal (Output) GND terminal LAND PATTERN unit:mm MARKING Frequency EX: 40.000MHz = 400 SUGGESTED REFLOW PROFILE Temp. Total time : 360 sec. Max. Solder melting point :225 oC 10 sec. Max. 260 5 220 60 sec. Max. 180 150 120 sec. Max. Time 4/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2S40000063 A0 PAGE: STRUCTURE ILLUSTRATION NO COMPONENTS MATERIALS QTY FINISH/SPECIFICATIONS 1 Cap(Lid) Kovar(Fe+Co+Ni) 1 Ni plating 2 Base(Package) Almina Ceramics (AI2O3) 1 3 Pad(Package) Ni + Au 4 Ni+Au plating 4 Crystal blank SiO2 1 - 5 Conductive adhesive Ag 2 Silicone resin 6 Electrode Cr + Ag 2 - 5/9 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2S40000063 A0 PAGE: 6/9 RELIABILITY SPECIFICATIONS 1.MECHANICAL ENDURANCE Test Item Test Methods No. 1 Drop Test 150 cm height, fall freely onto stainless plate 3 times. 2 Shock Test 3 Mechanical Shock 4 Vibration 5 Gross Leak 6 Fine Leak 7 Solderability 8 Resistance To Soldering Heat 150g/150cm Height,3times in the direction of ±x, ±y, ±z on concrete floor JIS C6701 IEC-68-02-27 Device are shocked to half sine wave ( 1000 G ) three mutually MIL-STD-202F pendicular axes each 3 times. 1.0m sec. duration time Frequency range 10 ~ 55 Hz Amplitude 1.52 mm MIL-STD-883E Pendicular axes each test time 2 hours(x,y,z Axis) Total test time 6 hours Standard Sample For Automatic Gross Leak Detector Test Pressure 2kg/cm2 Helium Bombing 4.5kgf/cm2 for 2 hr MIL-STD-883E MIL-STD-883E o o Temperature Immersing depth Immersion time Flux 215 C +/- 5 C 0.5 mm minimum 10 +/- 0.5 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) Pre-heat temperature Pre-heat time Test temperature Test time 125 oC 60 ~ 120 sec. 260 +/- 5 oC 5 +/- 1 sec. 2.ENVIRONMENTAL ENDURANCE Test Item Test Methods No. o o 9 High Temp. Storage + 125 C +/- 3 C for 500 +/- 12 hours 10 Low Temp. Storage - 40 oC +/- 3 oC for 500 +/- 12 hours MIL-STD-883E MIL-STD-202F MIL-STD-883E Total 100 cycles of the following temperature cycle 1 cycle o 125+/- 3 C 11 Thermal Shock MIL-STD-883E 25 oC -55+/- 3 o C 30 min. 30 min. 10 min. max. 12 High Temp&Homidity 13 Pressure Cooker Storage 85℃±3℃, RH 85%,500Hrs JIS C5023 o 120 +/- 3 C, RH100%, 2 bar, for 240 hours JIS C6701 TEL : +86(0)769-38879888 FL P/N: FAX : 86(0)769-38879889 VER: 2S40000063 A0 PAGE: PACKING : (EIA-481-2) 16 2S1600F001 Dimension PKG Type 2520(8mm) A0 B0 K0 Unit : mm T W E F 2.25±0.1 2.70±0.1 0.75±0.1 0.25±0.05 8±0.3 1.75±0.1 3.50±0.1 P1 P2 D1 D0 P0 4±0.1 2±0.1 1±0.1 1.55±0.05 4±0.1 Standard Reel Quantity is 3,000 pcs per reel. THE INSPECTION FOR TAPE TENSION REMARK : NA 7/9 TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 YL P/N: 2S40000063 VER: A0 PAGE: 8/9 SMD PRODUCT PACKING STANDARD Out-going packing instruction Reel Packing Inner Packing name:reel name:inner box standard:diameter 18cm standard:L19.0xW19.0xH2.5cm material:plastics material:B corrugated paper Carton name:carton standard:L34.0xW22.0xH22.0cm material:AB corrugated paper(10 boxes enter) L2 L1 L1 L3 The label instruction Label Drawing Mark Name of Article Spec. L1 条码标签 1.Date Code Bar Code 2.Lot No. Label 3.Part No. (Chintz Paper) 4.Freq 5.Q'ty Size Printing 75x35mm White L2 机打标签 Printing Label (Printing Paper) 1.Freq 2.Electrical Parameters 3.Q'ty 4.Part No. 5.Packing Date 75x35mm White L3 运输标签(唛头) Shipping Mark (Printing Paper) 1.inv No. 2.PO No. 3.Part No. 4.Q'ty 5.C/No. 100x100m White m Remark Specifications on the label is for the use of templates with different product specifications may vary. If customer specified requirements for labels packaging. please provide the operation procedure. TEL : +86(0)769-38879888 FAX : 86(0)769-38879889 Range Banned Substances 1.镉及镉化合物 Cadmium and cadmium compounds 2.铅及铅化合物 Lead and lead compounds 3.汞及汞化合物 Mercury and mercury compounds 4.六价铬化合物 Hexavalent-Chromium VI (Cr+6) 5.聚溴联苯 PBB Polybrominated biphenyls Products Maximum concentration ppm(mg/kg) 5 40 5 10 5 6.聚溴二苯醚 PBDE Polybrominated diphenyl ethers 5 7.多氯联苯 (PCB) Polychlorinated biphenyl 8.多氯化萘 (PCN) Polychlorinated naphthalene 9.氯代烷烃 (CP) Chiorinated paraffin 10.其他有机氯化合物 Other chlorinated organic compounds 11.其他有机溴化合物 Other brominated organic compounds 12.有机锡化合物 (三丁基锡化合物,三苯 基锡化合物) Organic tin compounds (Tributyl tin category & Triphenyl tin category ) 13.石棉 Asbestos 14.偶氮化合物 Azo compounds 15.甲醛 Formaldehyde 16.聚氯乙烯(PVC)以及聚氯乙烯混合物 Polyvinyl chloride (PVC) and PVC blends 17.包装材料中重金属(汞、镉、六价铬 、铅、PBB、PBDE)之总量 Heavy metals (mercury, cadmium, lead, Cr+6,PBB and PBDE) in packing 5 VER: 2S40000063 A0 PAGE: 9/9 Packing Material Maximum Test Method concentration ppm(mg/kg) 5 ICP-AES as per EN1122, method B2001 or other acid digestion. 100 ICP-AES after as per EPA 3050B or other acid digestion. 5 ICP-AES after as per EPA 3052 or other acid digestion. 10 As per US EPA 7196A and US EPA 3060A. 5 With reference to USEPA 3540 or USEPA3550. Analysis was performed by LPLC/DAD, LC/MS or GC/MS. (prohibited by 2002/95/EC (RoHS),83/261/EEC, and76/769/EEC) 5 With reference to USEPA3540or USEPA3550. Analysis was performed by HPLC/DAD LC/MS or GC/MS.(prohibited by 2002/95/EC(RoHS), 83/264/EEC, and 76/769/EEC) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 No detect No detect N/A
2S40000063 价格&库存
很抱歉,暂时无法提供与“2S40000063”相匹配的价格&库存,您可以联系我们找货
