2520-16.00-12-10-10/A 数据手册
2 .5×2.0×0.45 mm typ
12MHz up to 60MHz
Feature
A small surface mount type crystal unit,especially suited for
small-sizing requirements.
Ultra compact and thin.(2.5×2.0×0.45 mm typ.)
Tight Tolerance 10ppm available.
Application:Bluetooth ;Mobile phone;W-LAN;Office Automation;
Audio & Visual.
Meets the requirements for re-flow profiling using lead-free solder.
Specifications
Type
Item
TX3-Type
12~13MHz
13~19.5MHz
19.5~27MHz
27~60MHz
Fundamental
Series,6~32pf,or speecify
10μW(200μW max.)
±10×10-6,±20×10-6,±30×10-6,±50×10 -6 (at 25°C)
150 Ω max.
80 Ω max.
60 Ω max.
50 Ω max.
-10~+60°C, -20~+70°C, -40~+85°C
-55~+125°C
3000pcs/reel(Ø180)
Frequency Range
Oscillator Mode
Load Capacitance
Drive Level
Frequency Tolerance
Series Resistance
Operating Temperature Range
Storage Temperature Range
Packing Unit
Outline Drawing(mm)
[ TOP VIEW ]
2.55±0.20
#4
#3
#1
#2
2.05±0.20
GND
#2 and #4 are connected to the cover
(please connect to ground)
#3
1.60
1.10
0.55±0.10
#4
1.62
GND
#2
1.25±0.10
[ BOTTOM VIEW ]
1.62±0.10
#1
0.45±0.10
[ SIDE VIEW ]
0.72±0.10
1.20
Frequency Stability Vs. Temperature Range
±30
±50
Conditional
Available
±20
-40 ~ +105
-40 ~ +125
±15
PPm
±15
Temp.(°C)
±10
-10 ~ +60
-20 ~ +70
-40 ~ +85
±5
PPm
Temp.(°C)
Not Available
Oscillation Circuit of Fundamental Mode
RF
R
C1
Crystal
C2
CL=
C1*C2
C1+C2
+3~5pf
①
②
③
④
1612
2016
2520
3225
5032
6035
3225
5032
8045
49S
49MD
⑤
B
产 品编号 :
① ② ③ ④ ⑤
① 型号
② 频率
③ 负载电容 ④ 频率稳定度(X10- 6 ,+25℃)
范例: 3225 -12.00-20-20-20/A
① ② ③ ④ ⑤
⑤温度
2520-16.00-12-10-10/A 价格&库存
很抱歉,暂时无法提供与“2520-16.00-12-10-10/A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.20874
- 10+0.94749
- 30+0.83549
