8Z24000016
8Z24000016
    TXC(台晶)
    SMD2520_4P
    24MHZ 8PF 20PPM
8Z24000016 数据手册
TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com SPECIFICATION FOR APPROVAL CUSTOMER : PRODUCT TYPE : SMD SEAM SEALING X'TAL 2.5 × 2.0 NOMINAL FREQ. : 24.000000MHz TXC P/N : 8Z24000016 REVISION : S1 CUSTOMER P/N : PM / SALES : DATE : CUSTOMER SIGNATURE & Date (1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance of the attached specifications. (2) Orders received and accepted by TXC after return of signed copy of specification will be produced per these specifications. (3) Any changes to these specifications must be agreed upon by both parties and new revision of the Product Specification Sheet will be issued. (4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets" from customers will be regarded as the agreement on the contents of these specifications. Attachment: Product Specification Sheet 1 2 3 4 5 FMT-DOC024 RoHS Compliant Issue Date: 12.15'08 VER.E TXC CORPORATION 4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan. TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207 www.txccorp.com PRODUCT SPECIFICATION SHEET PRODUCT TYPE : SMD SEAM SEALING X'TAL 2.5 × 2.0 NOMINAL FREQ. : 24.000000MHz TXC P/N : 8Z24000016 REVISION : S1 PE/RD QA MFG 16-Jul-12 NOTE: (1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003 on the restriction of the use of certain hazardous substances (RoHS) in electrical and electronic equipment" Compliant (Attachment: SGS Test Report). (2)Revision "Sx" is for engineering samples only. PE/RD's approval required. (3)Revision "Ax" is production ready. PE, QA and MFG's approval required RoHS Compliant FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION Rev Revise page S1 N/A FMT-DOC024 TXC P/N: Revise contents Initial released 8Z24000016 REVISION: S1 PAGE: 1 Date Ref.No. Reviser 16-Jul-12 N/A Xiaoyan Jiang Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 2 Spec Sheet Contents No. Content Page 1 ELECTRICAL SPECIFICATIONS P.3 2 FACTORY LOCATION P.3 3 DIMENSIONS P.4 4 MARKING P.4 5 SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION P.4 6 STRUCTURE ILLUSTRATION P.5 7 EMBOSS CARRIER TAPE & REEL P.6 8 PACKING P.7 9 RELIABILITY SPECIFICATIONS&HANDING CAUTIONS FMT-DOC024 P.8~9 Issue Date: 12.15'08 VER.E TXC CORPORATION 8Z24000016 TXC P/N: REVISION: S1 PAGE: 3 ■ ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±10℃ Relative humidity 40%~70% : If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity 40%~70% : Measure equipment Electrical characteristics measured by S&A250B or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Unit Weight: 0.009±0.001 g/pcs Parameters Symbol Electrical Spec. Min. Typ. Max. Notes Units FL 24.000000 MHz - - Fundamental - - CL 8 pF - 4 Frequency Tolerance - ±20 ppm at 25 ℃ ± 3 ℃ 5 Frequency Stability - ±20 ppm Over Operating Temp. Range (Reference 25℃) 6 Operating Temperature - 7 Aging - 1 Nominal Frequency 2 Oscillation Mode 3 Load Capacitance -20 ~ 75 ±3 - ℃ ppm 1st Year 8 Drive Level DL - 100 - uW - 9 Equivalent Series Resistance Rr - - 50 Ω - 10 Insulation Resistance - 500 - - MΩ 11 Storage Temperature Range - -40 ~ 85 ℃ FMT-DOC024 at DC 100V - Issue Date: 12.15'08 VER.E TXC CORPORATION 8Z24000016 TXC P/N: REVISION: S1 PAGE: 4 2.55±0.05 ■ DIMENSIONS (Unit:mm) 4 GND 4 3 2.05±0.05 3 2 0.85 GND 1.00 0.65 0.90 2 4 Connection 0.70±0.10 0.675±0.10 0.825±0.10 1 2 1 0.55±0.05 1 3 0.9±0.10 ■ MARKING   T□□□ TXC Logo Pin 1 Location ■ Frequency Code Ex. 24.000000 MHz = □□□□ 240 Lot Code Date Code Line Code Date Code: MONTH YEAR JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC 2005 2009 2013 2017 A B C D E F G H J K L M 2006 2010 2014 2018 N P Q R S T U V W X Y Z 2007 2011 2015 2019 a b c d e f g h j k l m 2008 2012 2016 2020 n p q r s t u v w x y z *This date code will be cycled every four years Production location:Taiwan&Ningbo ■ SUGGESTED REFLOW PROFILE Total time : 200 sec. Max. Solder melting point :220 ℃ ■ SUGGESTED MANUAL SOLDER CONDITION Temperature: 350 ± 10 ℃ Time: 3 sec. Re-solder times: twice FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 5 ■ STRUCTURE ILLUSTRATION 4 5 3 1 2 NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 Lid Kovar (Fe/Co/Ni) - 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+Pad(Au) Tungsten metalize + Ni plating + Au plating 3 Crystal blank SiO2 - 4 Conductive adhesive Resin+Ag - 5 Electrode Noble Metal - FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 6 ■ PACKING DIMENSIONS A B C D E F G H 1.05 2.70 2.25 4.00 8.00 4.00 1.55 1.75 (UNIT : mm) REMARK : DIMENSIONS FMT-DOC024 L L1 W W1 178 13 11.5 8 pcs / Reel (UNIT : mm) Standard Reel Quantity is 3,000 pcs per reel Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 7 ■ PACKING Reel Quantity : 1. Reel X 6 (6 Reels) 2. Reel X 12 (12 Reels) 3. Reel X 25 (12 Reels + 13 Reels) 4. Reel X 50 ( 12 Reelsx2 + 13 Reelsx2 ) Label B Box Size: 1. L200 X W200 X H140mm 2. L200 X W200 X H250mm 3. L400 X W200 X H250mm 4. L400 X W400 X H280mm Tape Tape Label A Label B QA Pass (Label A) Size:100 X 100mm (Lable B) Size:80 X 40mm [STORAGE] 1.The storage time to be 1 year maximum. 2.Don't be caught in the rain. 3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine. 4.If customers have special requirements, we can paste labels according to it. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 8 ■ RELIABILITY SPECIFICATIONS 1.Mechanical Endurance No. Test Item 1 Drop Test Test Methods Test Criteria A.C 150 cm height, 3 times on concrete floor. 1 Mechanical Shock 1 Vibration Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes perpendicular axes each test time 4 Hrs A.C A.C (Total test time 12 Hrs) 1 Solder ability Temperature 240 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol E solvent ( 1 : 4 ) 2.Environmental Endurance No. Test Methods Test Item 2 Resistance To Soldering Heat Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ Test time 10 ± 1 sec. 2 High Temp. Storage + 125 ℃ ± 3 ℃ for 500 ± 12 Hrs 2 Low Temp. Storage - 40 ℃ ± 3 ℃ for 500 ± 12 Hrs Test Criteria B.C.D B.C.D Total 100 cycles of the following temperature cycle 2 Temperature cycle 3 High Temp&Humidity B.C.D 85℃ ± 3℃, RH 85% , 500Hrs B.C.D ■HANDING CAUTIONS Prohibit the use of ultrasound in any process. FMT-DOC024 Issue Date: 12.15'08 VER.E TXC CORPORATION TXC P/N: 8Z24000016 REVISION: S1 PAGE: 9 RELIABILITY SPECIFICATIONS Specifications A Frequency change: Within ±5ppm or in customer's specification. B Frequency change: Within ±10ppm or in customer's specification. C Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value). D After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 2 hour, and measured. E Minimum 95% of immersed terminal shall be covered with new uniform solder. Measurement condition Electrical characteristics measured by S&A250B or equivalent. FMT-DOC024 Issue Date: 12.15'08 VER.E
