1MAA19200ACA
1MAA19200ACA
    KDS(大真空)
    SMD2520_4P
    DSR221STH 19.200MHZ 7PF 10PPM
1MAA19200ACA 数据手册
SMD Crystal Resonators with dedicated temperature sensor / MHz Band Crystal Resonators〈For Automotive〉 DSR211ATH/DSR211STH/DSR221STH NEW ■ Features ● DSR211ATH: Actual size DSR211ATH DSR221STH DSR211STH 2016size, height 0.65mm max. DSR211STH: 2016size, ‌ height 0.8mm max. (19.2MHz) 0.65mm max. (38.4MHz) DSR221STH: 2520size, height 1.0mm max. ● Built-in NTC thermistor ● Moisture prevention packing is unnecessary. Moisture Sensitivity Level : LEVEL 1(IPC/JEDEC J-STD-033) ● AEC-Q200 Compliant Pb-Free RoHS/ELV Compliant ■ Applications ● Multimedia devices such as car navigation systems and car audio ● GPS/GNSS ■ Standard Specification Item               Type Frequency Range Overtone Order Load Capacitance Drive Level Frequency Tolerance Series Resistance Frequency Characteristics over Temperature DSR211ATH 19.2MHz DSR211STH 19.2MHz/38.4MHz Fundamental 7pF, 8pF 10μW (100μW max.) ±10×10−6(at 25℃) 80Ω max. ±30×10−6 / −40 to +105 ℃ (±12×10−6 / −30 to+85 ℃) Storage Temperature Range Thermistor Resistance Thermistor B-constant Reliability Packing Unit DSR221STH 19.2MHz ±30×10−6 / −40 to +105 ℃ (±12×10−6 / −30 to +85 ℃) ±20×10−6 / −40 to +105 ℃ −40 to +125 ℃ 100kΩ (at +25℃ ) 4250K (+25℃ to +50℃ ) AEC-Q200 3000pcs./reel (φ180) Consult our sales representative for other specifications. 1.375 #4 SENSOR #3 X'tal #1 X'tal #2 GND ■ Recommended Land 〈Top View〉   Pattern R0.20 1.80 0.46 2.20 Logo 0.65 #1 #2 C0.20 Index 0.975 #2 Lot No. 1.0mm max. #1 0.55 #4 1.375 #3 ■ Internal Connections〈Top View〉 #4 SENSOR #3 X'tal #1 X'tal #2 GND ■ Recommended Land 〈Top View〉   Pattern R0.20 0.75 0.75 0.43 0.75 C0.15 Index #3 TH 19.2 D 701 #1 Index #2 #1 Frequency #4 #2 Lot No. 0.475 2.5±0.15 Model Code 2.0±0.15 1.6±0.1 #3 Logo 0.46 1.80 #4 ■ Internal Connections〈Top View〉 #1 Index 0.43 0.475 C0.15 Index 0.975 #2 #1 TH 19.2 D 701 0.475 0.475 Lot No. 0.65mm max. #2 Logo Frequency #3 #1 #1 #1 Index 2.0±0.1 Model Code #4 TH 19.2 D 701 [mm] 1.25 Frequency #3 ■DSR221STH ■ Dimensions 0.8mm max.:19.2MHz 0.65mm max.:38.4MHz 2.0±0.1 1.6±0.1 [mm] ■ Dimensions Model Code #4 0.75 ■DSR211STH 2.20 #4 1.65 #3 ■ Internal Connections〈Top View〉 #4 SENSOR #3 X'tal #1 X'tal #2 GND ■ Recommended Land 〈Top View〉   Pattern 0.85 [mm] ■ Dimensions 1.55 ■DSR211ATH 1.95 0.95
1MAA19200ACA 价格&库存
很抱歉,暂时无法提供与“1MAA19200ACA”相匹配的价格&库存,您可以联系我们找货
1MAA19200ACA
  • 1+2.97000
  • 10+2.31120
  • 30+2.03040
  • 100+1.68480
库存:2728
