TXC CORPORATION
4F, NO. 16, Sec. 2 Chung Yang S Rd., Peitou, Taipei, Taiwan.
TEL : 886-2-2894-1202 , 886-2-2895-2201 FAX : 886-2-2894-1206 , 886-2-2895-6207
www.txccorp.com
SPECIFICATION FOR APPROVAL
CUSTOMER
PRODUCT TYPE
SMD GLASS SEALING XTAL 5.0*3.2
NOMINAL FREQ.
9.216000MHz
TXC P/N
AA09200001
REVISION
S1
CUSTOMER P/N
PM / SALES
DATE
CUSTOMER SIGNATURE & Date
(1) TXC requires one copy returned with signature and title of authorized individual that signifies acceptance
of the attached specifications.
(2) Orders received and accepted by TXC after return of signed copy of specification will be produced per
these specifications.
(3) Any changes to these specifications must be agreed upon by both parties and new revision of the
Product Specification Sheet will be issued.
(4) Any issuance of purchase order prior to consigning back the Approval page of "Specification Sheets"
from customers will be regarded as the agreement on the contents of these specifications.
MSL:Level 1
RoHS Compliant
Pb used in sealing glass material is exempt from EU directive
FMT-DOC024
Issue Date: 12.15'08 VER.E
TXC CORPORATION
www.txccorp.com
PRODUCT SPECIFICATION SHEET
PRODUCT TYPE
NOMINAL FREQ.
9.216000MHz
TXC P/N
AA09200001
REVISION
S1
PE/RD
QA
MFG
11-Nov-11
NOTE:
(1)Lead Free Products are "Directive 2002/95/EC of The European Parliament of 27 January 2003
on the restriction of the use of certain hazardous substances (RoHS) in electrical and
electronic equipment" Compliant (Attachment: SGS Test Report).
(2)Revision "Sx" is for engineering samples only. PE/RD's approval required.
(3)Revision "Ax" is production ready. PE, QA and MFG's approval required
MSL:Level 1
RoHS Compliant
FMT-DOC024
TXC P/N:
TXC CORPORATION
Rev
Revise page
S1
N/A
FMT-DOC024
Revise contents
Initial released
AA09200001
S1
REVISION:
PAGE:
1
Date
Ref.No.
Reviser
11-Nov-11
N/A
Xiaoyan Jiang
TXC CORPORATION
TXC P/N:
AA09200001
REVISION:
S1
PAGE:
2
Spec Sheet Contents
No.
Content
Page
1
ELECTRICAL SPECIFICATIONS
P.3
2
FACTORY LOCATION
P.3
3
DIMENSIONS
P.4
4
MARKING
P.4
5
SUGGESTED REFLOW PROFILE& MANUAL SOLDER CONDITION
P.4
6
STRUCTURE ILLUSTRATION
P.5
7
EMBOSS CARRIER TAPE & REEL
P.6
8
PACKING
P.7
9
RELIABILITY SPECIFICATIONS
FMT-DOC024
P.8~9
TXC P/N: AA09200001
TXC CORPORATION
REVISION:
S1
PAGE: 3
■ ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature :
25±5℃
Relative humidity
40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
25±3℃
Relative humidity
40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Unit Weight:
0.054±0.05 g/pcs
Parameters
SYM.
Electrical Spec.
MIN
TYP
FL
9.216000
1
Nominal Frequency
2
Oscillation Mode
3
Load Capacitance
4
Frequency Tolerance
5
Frequency Stability
6
Operating Temperature
7
Aging
8
Drive Level
9
Effective Resistance Rr
MAX
Notes
UNITS
MHz
Fundamental
CL
15
pF
±25
ppm
at 25 ℃ ± 3 ℃
ppm
Over Operating Temp. Range (Reference 25℃)
DL
±30
-40
85
±5
ppm
50
100
1st Year
uW
Rr
80
Ω
10 Shunt Capacitance C0
C0
2
pF
11 Insulation Resistance
500
MΩ
12 Storage Temperature Range
-40
85
at DC 100V
■ FACTORY LOCATION
TXC (NINGBO) CORPORATION
NO.189 Huang Shan West Road, Beilun District,
Ningbo Zhejiang China
FMT-DOC024
AA09200001
TXC P/N:
TXC CORPORATION
REVISION:
S1
PAGE:
4
■ DIMENSIONS
(Unit:mm)
*Coplanarity of solderable areas Camber 0.10 mm Max
■ MARKING
TXC □□□□
TXC Logo
Frequency Code
MHz=
Ex.: 9.216000
9.00
Lot Code
Line Code
Date Code
Date Code:
MONTH
YEAR
JAN FEB MAR APR MAY JUN JUL AUG SEP OCT NOV DEC
2005
2009
2013
2017
A
B
C
D
E
F
G
H
J
K
L
M
2006
2010
2014
2018
N
P
Q
R
S
T
U
V
W
X
Y
Z
2007
2011
2015
2019
a
b
c
d
e
f
g
h
j
k
l
m
2008
2012
2016
2020
n
p
q
r
s
t
u
v
w
x
y
z
*This date code will be cycled every four years
■ SUGGESTED REFLOW PROFILE
Solder melting point :220 ± 10 ℃ , 60 sec. Min
Peak Temperature: 260 ± 5 ℃ , 10 sec. Max.
10 sec
260
220
180
150
■ SUGGESTED MANUAL SOLDER CONDITION
Temperature: 350 ± 10 ℃
Time: 3 sec.
Time (sec)
120 sec
60 sec
Re-solder times: twice
FMT-DOC024
TXC P/N:
TXC CORPORATION
AA09200001
S1
REVISION:
PAGE:
5
■ STRUCTURE ILLUSTRATION
COMPONENTS
NO
MATERIALS
FINISH/SPECIFICATIONS
1
Cap
Ceramic (AI2O3)
2
Base(Package)
Ceramic (AI2O3)
3
PAD
Au
Tungsten metalize
+ Ni plating
+ Au plating
4
Crystal blank
SiO2
5
Conductive adhesive
Resin+Ag
6
Electrode
Noble Metal
7
Sealing Glass
Glass(PbO)
FMT-DOC024
TXC P/N:
TXC CORPORATION
AA09200001
S1
REVISION:
PAGE: 6
■ EMBOSS CARRIER TAPE & REEL
F
B
E
H
G
DIMENSIONS
A
1.65±0.10
B
C
Feeding
D
C
A
D
E
F
G
H
5.40±0.10 3.50±0.10 8.00±0.10 12.00±0.30 4.00±0.10 1.55±0.10 1.75±0.10 (UNIT:mm)
REMARK :
Products put in 1000pcs
Trailer
160mm(Min)
Empty Sealed
Leader
160mm(Min)
230mm(Min)
User direction of feed
DIMENSIONS
FMT-DOC024
L
L1
W
W1
180±1.00
13±0.50
16.5±0.20
12±0.10
(UNIT:mm)
TXC CORPORATION
TXC P/N:
AA09200001
REVISION:
S1
PAGE:
7
■ PACKING
Reel Quantity :
1. Reel X 5 (5 Reels x1 )
2. Reel X 10 (10 Reels x1 )
3. Reel X 20 (10 Reels x2 )
4. Reel X 40 (10 Reels x4 )
Label B
Box Size:
1. L200 X W200 X H140mm
2. L200 X W200 X H250mm
3. L400 X W200 X H250mm
4. L400 X W400 X H280mm
Tape
Tape
Label A
Label B
QA Pass
(Label A) Size:100 X 100mm
(Label B) Size:80 X 40mm
[STORAGE]
1.The storage time to be 1 year maximum.
2.Don't be caught in the rain.
3.The storage environment shall be 5℃ ~40℃ temperature and 30% ~ 75%RH humidity and free from the sun shine.
4.If customers have special requirements, we can paste labels according to it.
FMT-DOC024
TXC P/N:
TXC CORPORATION
AA09200001
S1
REVISION:
PAGE:
8
■ RELIABILITY SPECIFICATIONS
1.Mechanical Endurance
No.
1.1
1.2
Test Item
Mechanical Shock
Vibration
Test Methods
Test Criteria
2000 G , 0.3 m Sec. ,3 times for all 3 directions.
Frequency range
10 ~ 2000 Hz
Acceleration
5G
Sweep time
20 minute
Pendicular axes each test time
4 hours
BC
BC
(Total test time 12 hours)
1.3
Terminal Strength
17.7N force for 60sec +/-1sec.
1.4
Board Flex
Duration time:60 Sec Minimum,Deviation:3mm
F
BC
2.Environmental Endurance
No.
2.1
Test Methods
Test Item
Solderability
SPEC
Temperature
245 oC +/- 5oC
Immersing depth
0.5 mm minimum
Immersion time
5 +/- 0.5 seconds
Flux
Rosin resin methyl alcohol
E
solvent ( 1 : 4 )
2.2
Resistance To
Soldering Heat
Test temperature
260 +/- 5 oC
Test time
10 +/- 1 sec.
Emersion Rate
25 ± 6 mm/s
Immersed of specimen
1.5mm
BCD
2.3
High Temp. Storage + 85℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
2.4
Low Temp. Storage - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
BCD
-40℃~85℃,for 1000 cycles.
B C D
1 cycle
85+/-3 0C
2.5
Thermal Shock
25 0C
-40+/-3 0C
BCD
5 min.
5 min.
10 Sec.
1000 hrs @ 85± 3°C. Rated VDD applied with 1 MΩ.
2.6
Operational Life
2.7
High Temp&Humidit 85℃ ± 3℃ , RH 85% , 1000 Hrs
FMT-DOC024
BCD
BCD
TXC CORPORATION
TXC P/N: AA09200001
REVISION
S1
PAGE: 9
Specifications
A
Frequency change: Within ±5ppm or in customer's specification.
B
Frequency change: Within ±10ppm or in customer's specification.
C
Equivalent series resistance(E.S.R) change: Within ±15% or 10Ω(larger value).
D
After conditioning , quartz crystal units shall be subjected to standard atmospheric conditions for 24 hour,
and measured.
E
Minimum 95% of immersed terminal shall be covered with new uniform solder.
Measurement condition
FMT-DOC024
很抱歉,暂时无法提供与“AA09200001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.17520
- 10+2.47320
- 30+2.17080
- 100+1.79280
- 500+1.62000
- 1000+1.52280
