TJ2125000JYGBC
TJ2125000JYGBC
    JYJE(晶友嘉)
    SMD2016_4P
    无源晶振 25MHz ±10ppm 10pF 60Ω -40℃~+85℃
TJ2125000JYGBC 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONICS CO.,LTD TJ21系列 ● Feature 特性 ◆电阻焊接 Resistance weiding ◆低功耗 Low power ◆高可靠性 High stability ◆频率范围宽 Wide frequency range ◆表面装贴 回流焊 IR R-flow ●Electricalspecifications 电气参数 型号 Holder Type 频率范围 Frequency Toleranc (△F) at25℃ 温度频差 TJ21 16MHz~96.0MHz (Fund) 老化 Frequency rift Operating Temperature Range Storage Temperature Range Aging 25℃ 静电容 Shunt Capacitance (C0) 工作温度范围 储存温度范围 SMD 2016 ●Mechanical Dimensions 外型尺寸 ±10ppm~±20ppm -20℃~+70℃ to -40℃~+85℃ -20℃~+60℃ to -55℃~+125℃ ±3ppm/year Maximum 7pf Maxmum 激励功率 Drive Level 10uw~50uw Typical 绝缘阻抗 Insulaton Resistance 500Mohms at DC 100V 负载电容 Load Capacitance (CL) Suggested by customer ●Equivalent Series Resistance and Mode of Operation 等效电阻和振荡模式 Frequency Range 频率范围 16.000-25.000 25.000-30.000 35.000-42.000 42.000-96.000 ESR(ohm)等效阻抗 Mode振荡模式 100Max 80Max 60Max 50Max Fundamental Fundamental Fundamental Fundamental MHz MHz MHz MHz ●Reflow condition 回流焊条件 ●Frequency VS.Temperature Curne SHENZHEN JINGYOUJIA ELECTRONICS CO.,LTD
TJ2125000JYGBC 价格&库存
很抱歉,暂时无法提供与“TJ2125000JYGBC”相匹配的价格&库存,您可以联系我们找货
