XL7EL89CKI-111YLC-16M 数据手册
CRYSTAL UNIT
YSX211SL
Applications
Small Size
Features
‧SmartWearable
‧Dimensions:2.05 x 1.65 x 0.50 mm.
‧High precision and high frequency stability.
IOT Communication.
‧Standard Frequency: 16~54MHz
‧Excellent heat resistance and environmental
characteristics.
Specifications
Standard Frequency
16~54MHz or 96MHZ
Vibration Mode
AT Fundamental
Load Capacitance
8pF,9pF,12pF,or specify
Frequency Tolerance (at 25 )
±10ppm,±20ppm,or specify
Frequency Versus Temperature Characteristics
±20ppm,or specify
Operating Temperature
-40~+85℃
Storage Temperature
-40~+85℃ or specify
Shunt Capacitance
3 pF Max.
Level of Drive
10~200μWMax.(100uW typical)
Aging (at 25 ℃ )
±3ppm/year Max.
Equivalent Series Resistance(ESR)
16 ~ 30 MHz
31 ~ 54 MHz
Dimensions and Patterns [unit:mm]
100 Ω Max.
80 Ω Max.
Package Size – Dimensions (Unit: mm)
2.00±0.10
1.60±0.10
3
4
Marking
To p Vi e w
2
0 . 90
0 . 80
0 . 50
0 . 80
0.475±0.10
0 . 30
2
0.5±0.10
4
1
0 . 90
0.7±0.10
1
3
To p Vi ew
2
S id e Vie w
0.575±0.10
4
GND
GND
0.50Max
1
Recommended Land Pattern (Unit: mm)
Sug ge s te d L a yo u t
B o t to m V i ew 3
www.yxc.hk
第1页共2页
CRYSTAL UNIT
YSX211SL
Small Size
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-2016
180±2.0
8.0±0.3
2.30±0.1
1.90±0.1
4.0±0.1
0.95±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxc.hk
第2页共2页
XL7EL89CKI-111YLC-16M 价格&库存
很抱歉,暂时无法提供与“XL7EL89CKI-111YLC-16M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.57780
- 100+0.45987
- 300+0.40079
- 3000+0.33448
- 6000+0.29906
- 9000+0.28134
