HSH250N10
N-Ch 100V Fast Switching MOSFETs
General Description
Product Summary
100% EAS Guaranteed
Green Device Available
Super Low RDS(ON)
Advanced high cell density Trench
technology
100
V
RDS(ON),typ
1.9
mΩ
ID
250
A
TO263 Pin Configuration
Applications
VDS
MOTOR Driver.
BMS.
High frequency switching and
synchronous rectification.
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20/-12
V
ID@TC=25℃
Continuous Drain Current, VGS @
10V1,6
250
A
ID@TC=100℃
Continuous Drain Current, VGS @ 10V1,6
158
A
IDM
Pulsed Drain Current2
1000
A
EAS
Single Pulse Avalanche Energy3
940
mJ
IAS
Avalanche Current
135
A
411
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
Max.
Unit
RθJA
Thermal Resistance Junction-Ambient 1
62
℃/W
RθJC
Thermal Resistance Junction-Case1
0.3
℃/W
www.hs-semi.cn
Ver 2.0
Typ.
1
HSH250N10
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
On-Resistance2
RDS(ON)
Static Drain-Source
VGS(th)
Gate Threshold Voltage
IDSS
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
100
V
VGS=10V , ID=40A
1.9
2.3
m
VGS=VDS , ID =250uA
2.0
3.0
4.0
V
VDS=100V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=85℃
10
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=10V , ID=3A
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.1
195
21
30
Qg
Total Gate Charge (10V)
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
Td(on)
Turn-On Delay Time
Tr
Rise Time
VDS=50V , VGS=10V , ID=10A
21
VDD=50V , VGS=10V , RG=3.3,
21
ID=1A
69
nC
ns
Td(off)
Turn-Off Delay Time
Tf
Fall Time
120
Ciss
Input Capacitance
10150
Coss
Output Capacitance
2100
Crss
Reverse Transfer Capacitance
55
Min.
Typ.
Max.
Unit
VDS=50V , VGS=0V , f=1MHz
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
VG=VD=0V , Force Current
250
A
Voltage2
VGS=0V , IS=1A , TJ=25℃
1
V
trr
Reverse Recovery Time
IF=10A , dI/dt=100A/µs ,
95
nS
Qrr
Reverse Recovery Charge
TJ=25℃
670
nC
VSD
Continuous Source
Current1,5
Diode Forward
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=50V,VGS=10V,L=0.1mH,Rg=25,IAS=138A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as I D and IDM , in real applications , should be limited by total power dissipation.
6.Package limitation current.
www.hs-semi.cn
Ver 2.0
2
HSH250N10
Typical Characteristics
Fig.1 Continuous Drain Current vs. TC
Fig.2 Normalized RDSON vs. TJ
Fig.3 Normalized Vth vs. Tj
Fig.4 Gate Charge Characteristics
Fig.5 Normalized Transient Impedance
www.hs-semi.cn
Fig.6 Maximum Safe Operation Area
Ver 2.0
3
HSH250N10
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.7 Switching Time Waveform
www.hs-semi.cn
Fig.8 Unclamped Inductive Switching Waveform
Ver 2.0
4
HSH250N10
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSH250N10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+18.82440
- 10+15.93000
- 30+14.12640
