HSH6115
P-Ch 60V Fast Switching MOSFETs
Description
Product Summary
The HSH6115 is the high cell density trenched Pch MOSFETs, which provide excellent RDSON
and gate charge for most of the synchronous
buck converter applications.
The HSH6115 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
VDS
-60
V
RDS(ON),max
25
mΩ
ID
-45
A
TO263 Pin Configuration
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Excellent CdV/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
-60
V
VGS
Gate-Source Voltage
ID@TC=25℃
ID@TC=100℃
±20
V
Continuous Drain
Current1
-45
A
Continuous Drain
Current1
-34
A
IDM
Pulsed Drain Current2
-90
A
EAS
Single Pulse Avalanche Energy3
113
mJ
IAS
Avalanche Current
-47.6
A
86.8
W
PD@TC=25℃
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Junction-Case1
www.hs-semi.cn
Thermal Resistance
Ver 2.0
Typ.
1
Max.
Unit
62
℃/W
1.44
℃/W
1
HSH6115
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=-250uA
-60
V
VGS=-10V , ID=-18A
25
VGS=-4.5V , ID=-12A
33
VGS=VDS , ID =-250uA
-1.0
-2.5
VDS=-48V , VGS=0V , TJ=25℃
1
VDS=-48V , VGS=0V , TJ=55℃
5
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=-10V , ID=-18A
23
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
7
14
Qg
Total Gate Charge (-4.5V)
25
Qgs
Gate-Source Charge
6.7
Qgd
Gate-Drain Charge
5.5
Td(on)
Turn-On Delay Time
VDS=-20V , VGS=-4.5V , ID=-12A
nC
38
Rise Time
VDD=-15V , VGS=-10V , RG=3.3,
23.6
Turn-Off Delay Time
ID=-1A
100
Fall Time
6.8
Ciss
Input Capacitance
3635
Coss
Output Capacitance
224
Crss
Reverse Transfer Capacitance
141
Min.
Typ.
Max.
Unit
VG=VD=0V , Force Current
-45
A
VGS=0V , IS=-1A , TJ=25℃
-1
V
Tr
Td(off)
Tf
VDS=-15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
VSD
Parameter
Continuous Source Current1,5
Diode Forward
Voltage2
Conditions
Note :
1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is VDD=-25V,VGS=-10V,L=0.1mH,IAS=-47.6A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSH6115
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs. G-S Voltage
12
10
VDS=-20V
-VGS Gate to Source Voltage (V)
-IS Source Current(A)
10
8
6
TJ=150℃
TJ=25℃
4
2
0.4
0.6
0.8
ID=-12A
8
6
4
2
-VSD , Source-to-Drain Voltage (V)
Fig.3 Source Drain Forward Characteristics
40
60
Fig.4 Gate-Charge Characteristics
2.0
Normalized On Resistance
1.5
Normalized -VGS(th)
QG , Total Gate Charge (nC)
1.5
1
1.0
0.5
0.5
100
TJ ,Junction Temperature ( ℃)
-50
150
Fig.5 Normalized VGS(th) vs. TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
Fig.6 Normalized RDSON vs. TJ
Ver 2.0
3
HSH6115
10000
100.00
F=1.0MHz
100us
Ciss
Capacitance (pF)
10.00
1ms
10ms
100ms
DC
-ID (A)
1000
1.00
Coss
100
Crss
0.10
Tc=25o C
Single Pulse
0.01
10
1
5
9
13
17
-VDS Drain to Source Voltage(V)
21
0.1
25
Fig.7 Capacitance
1
10
-VDS (V)
100
1000
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.3
0.1
0.1
0.05
PDM
T
0.02
0.01
0.01
0.00001
TON
D = TON/T
TJpeak = TC + PDM x RθJC
SINGLE PULSE
0.0001
0.001
0.01
0.1
1
10
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Waveform
Ver 2.0
4
HSH6115
www.hs-semi.cn
Ver 2.0
5
很抱歉,暂时无法提供与“HSH6115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.20120
- 10+3.40200
- 30+2.99160
- 100+2.59200
- 500+2.13840
- 800+2.00880
