HSL0004
N-Ch 100V Fast Switching MOSFETs
Description
Product Summary
The HSL0004 is the high cell density trenched
N-ch MOSFETs, which provides excellent
RDSON and efficiency for most of the small
power switching and load switch applications.
The HSL0004 meets the RoHS and Green
Product requirement with full function
reliability approved.
VDS
100
V
RDS(ON),typ
90
mΩ
ID
3
A
SOT223 Pin Configuration
Green Device Available
Super Low Gate Charge
Excellent Cdv/dt effect decline
Advanced high cell density Trench
technology
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
100
V
VGS
Gate-Source Voltage
±20
V
ID@TA=25℃
Continuous Drain Current, VGS @ 10V1
3
A
ID@TA=70℃
2.5
A
IDM
Pulsed Drain Current2
10
A
PD@TA=25℃
Total Power Dissipation3
1.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient 1
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
Max.
Unit
85
℃/W
30
℃/W
1
HSL0004
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
100
V
VGS=10V , ID=2A
90
112
m
VGS=4.5V , ID=1A
95
120
m
VGS=VDS , ID =250uA
1.0
1.5
2.5
V
VDS=80V , VGS=0V , TJ=25℃
1
VDS=80V , VGS=0V , TJ=55℃
5
VGS=0V , ID=250uA
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
±100
nA
gfs
Forward Transconductance
VDS=5V , ID=2A
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
2
4
Qg
Total Gate Charge (10V)
26.2
36.7
Qgs
Gate-Source Charge
3.8
5.32
Qgd
Gate-Drain Charge
4.8
6.7
VDS=80V , VGS=10V , ID=2A
nC
4.2
8.4
Rise Time
VDD=50V , VGS=10V , RG=3.3
7.6
14
Turn-Off Delay Time
ID=2A
41
82
Fall Time
14
28
Ciss
Input Capacitance
1535
2149
Coss
Output Capacitance
60
84
Crss
Reverse Transfer Capacitance
37
52
Min.
Typ.
Max.
Unit
Td(on)
Tr
Td(off)
Tf
Turn-On Delay Time
VDS=15V , VGS=0V , f=1MHz
ns
pF
Diode Characteristics
Symbol
IS
Parameter
Conditions
Continuous Source Current1,4
VG=VD=0V , Force Current
2.5
A
VSD
Diode Forward Voltage2
VGS=0V , IS=1A , TJ=25℃
1.2
V
trr
Reverse Recovery Time
35
nS
Qrr
Reverse Recovery Charge
17
nC
IF=2A , dI/dt=100A/µs , TJ=25℃
Note:
1. The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2. The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3. The power dissipation is limited by 150℃ junction temperature
4. The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSL0004
Typical Characteristics
96
15
ID=2A
VGS=10V
VGS=7V
94
VGS=5V
VGS=4.5V
RDSON (mΩ)
ID Drain Current (A)
12
9
92
VGS=3V
6
90
3
88
1
1.5
2
VDS , Drain-to-Source Voltage (V)
4
2.5
6
8
10
VGS (V)
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs G-S Voltage
10
IS Source Current(A)
8
6
TJ=150℃
4
TJ=25℃
2
0.25
0.50
0.75
1.00
VSD , Source-to-Drain Voltage (V)
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
2.5
Normalized On Resistance
1.8
2.0
Normalized VGS(th)
1.4
1.5
1
0.6
1.0
0.2
0.5
-50
100
150
-50
Fig.5 Normalized VGS(th) vs TJ
www.hs-semi.cn
100
150
TJ , Junction Temperature (℃)
TJ ,Junction Temperature (℃ )
Fig.6 Normalized RDSON vs TJ
Ver 2.0
3
HSL0004
10000
10.00
F=1.0MHz
100us
1ms
1000
1.00
ID (A)
Capacitance (pF)
Ciss
100
TA=25o C
Single Pulse
Crss
10
5
9
13
17
21
100ms
0.10
Coss
1
10ms
0.01
0.01
25
VDS , Drain to Source Voltage (V)
0.1
Fig.7 Capacitance
DC
1
VDS (V)
10
100
1000
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJA)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.01
P DM
0.01
T ON
T
D = TON/T
SINGLE
TJpeak = TC+P DMXRθJC
0.001
0.0001
0.001
0.01
0.1
1
10
100
1000
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
VDS
90%
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Gate Charge Waveform
Ver 2.0
4
很抱歉,暂时无法提供与“HSL0004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.05063
- 50+0.83279
- 150+0.73948
- 500+0.62306
