KN681M20025*30A
KN681M20025*30A
    KFSON(康富松)
    插件,D25xL30mm
    680UF ±20% 200V
KN681M20025*30A 数据手册
KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN ◆ ◆ series Load life 2000 Hrs at 105℃ RoHS Compliant Specifications 規格表 Ltem 項目 Operating Temperature Range 工作溫度範圍 Rated Voltage Range 額定電壓範圍 Capacitance Range 容量範圍 Performance Characteristics -40 to +105℃ -25 to +105℃ 16 to 100 VDC 160 to 500 VDC 68 to 56000 μF Capacitance Tolerance 靜電容量偏差 Leakage Current 漏電流 ±20%(120Hz,+20℃) After 5 minutes at 20°C application of rated voltage, leakage current is not more than 0.01CV or 1.5mA, whichever is smaller C: Nominal Capacitance(μF) V: Rated Voltage(V) rated voltage(V) 16 Dissipation Factor tanδ(Max) 50 損耗角正切值 tanδ(%) Low Temperature Characteristics 低溫特性 Load Life 使用壽命 特性參數 25 40 35 40 50 30 63 100 160-400 450-500 20 20 15 20 impedance ratio max 電容器最大阻抗比值 rated voltage(V) 16 25 35 50 63 100 160-400 450-500 Z(-25℃)/Z(+20℃) 4 4 4 4 4 4 4 8 Z(-40℃)/Z(+20℃) 15 15 15 15 15 15 105℃施加額定工作電壓2000小時,經恢復後,產品性能應滿足以下要求 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied for 2000H at 105℃ Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦200% of the specified value Leakage current ≦The specified value 105℃放置1000小時,經恢復後20℃后,產品性能應滿足以下要求 The following specifications shall be satisfied when the capacitors are restored Shelf Life 存儲特性 to 20℃ after exposing them for 1000 hours at 105℃ without voltage applied. Capacitance change D.F.(tanδ) Leakage current Diagram of Dimensions 外形尺寸圖 (mm) ≦±20% of the initial value ≦150% of the specified value ≦The specified value KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Frequency Coefficient Frequency Voltage(v) ≤100V 160-250V ≥350 50/60 120 300 1K 10K ≥50K Hz Hz Hz Hz Hz Hz 0.95 0.87 0.80 1.00 1.00 1.00 1.07 1.17 1.16 1.13 1.32 1.30 1.19 1.45 1.41 1.20 1.50 1.43 Rated Voltage Rated Capacity V μF Standard Ratings Rated Voltage Rated Capacity V μF mm A 3300 22*26 22*26 25*26 22*31 25*26 30*26 22*31 22*31 25*26 30*26 22*36 30*26 22*41 25*36 30*26 35*32 22*51 25*46 30*36 35*32 25*51 30*36 35*32 25*51 30*41 35*32 30*46 35*37 30*51 35*42 35*45 35*47 1.17 1.53 1.55 2.02 2.02 2.02 2.20 2.79 2.79 2.81 3.06 3.06 3.24 3.24 3.24 3.24 3.54 3.51 3.51 3.54 4.25 4.08 4.08 4.30 4.30 4.30 4.83 4.83 5.78 5.78 6.32 6.48 4700 6800 8200 10000 12000 15000 16V 18000 22000 27000 33000 39000 47000 56000 Size Rated ripple φD*L current 3300 4700 6800 8200 10000 25V 12000 15000 18000 22000 27000 33000 39000 47000 Size Rated ripple φD*L current mm A 22*26 25*26 22*26 25*26 22*31 25*26 30*26 22*36 25*31 30*26 22*41 25*36 30*31 35*27 22*46 25*41 30*31 35*27 25*46 30*36 35*32 25*51 30*41 35*32 30*46 35*37 35*42 35*52 35*52 35*52 1.48 1.48 1.88 1.90 2.60 2.60 2.60 3.14 3.14 3.14 3.50 3.50 3.50 3.50 4.02 4.02 4.02 4.02 4.58 4.58 4.58 4.82 4.82 4.79 5.12 5.12 5.30 6.09 6.20 6.30 Rated ripple current(A,rms)at 105℃,120Hz KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity V μF mm A 1500 22*26 22*26 25*26 22*26 25*26 22*26 25*26 22*36 25*26 30*26 22*41 25*36 30*26 35*27 25*46 30*36 35*27 25*51 30*41 35*32 30*46 35*37 35*52 35*52 35*45 35*52 1.26 1.35 1.45 1.55 1.65 1.80 1.90 2.42 2.30 2.54 3.24 3.24 3.21 3.24 3.96 3.96 3.75 4.21 4.21 4.21 4.69 4.69 5.50 5.80 5.60 5.90 2200 2700 3300 4700 6800 35V 10000 12000 15000 22000 27000 33000 Size Rated ripple φD*L current Rated ripple current(A,rms)at 105℃,120Hz Rated Voltage Rated Capacity V μF 1500 2200 2700 3300 4700 50V 6800 8200 10000 15000 18000 22000 Size Rated ripple φD*L current mm A 22*26 25*26 22*31 25*26 22*31 25*26 30*26 22*36 25*31 30*26 22*46 25*36 30*31 35*27 25*46 30*41 35*32 30*46 35*37 30*51 30*45 35*42 30*40 25*50 35*30 35*52 35*52 35*60 1.10 1.02 1.65 1.65 1.85 1.85 1.95 2.24 2.24 2.24 2.95 2.80 2.95 2.95 3.23 3.20 3.26 3.58 3.58 4.11 4.01 4.11 4.00 3.90 3.86 5.05 5.30 5.50 KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity V μF mm A 820 22*26 22*26 25*26 22*26 25*26 30*26 22*31 25*26 22*36 25*31 30*26 22*41 25*36 30*26 22*46 25*36 30*31 35*27 25*41 30*36 35*27 25*51 30*41 35*32 30*46 35*37 30*51 35*42 35*47 35*52 30*60 30*50 35*52 35*60 0.75 0.85 0.85 1.10 1.12 1.14 1.40 1.40 1.65 1.65 1.65 2.07 2.07 2.07 2.46 2.40 2.48 2.48 2.92 3.05 3.05 3.43 3.43 3.43 3.86 3.86 4.64 4.64 5.05 5.75 5.65 5.35 5.40 5.56 1000 1500 1800 2200 2700 3300 63V 3900 4700 5600 6800 8200 10000 15000 Size Rated ripple φD*L current Rated ripple current(A,rms)at 105℃,120Hz Rated Voltage Rated Capacity V μF mm A 330 22*26 22*26 25*26 22*26 25*26 22*31 25*26 30*26 22*31 25*26 30*26 22*36 25*31 30*26 22*41 25*36 30*31 22*46 25*41 30*31 35*27 25*41 30*36 35*32 25*51 30*41 35*32 30*46 35*37 30*56 35*47 35*47 35*52 35*40 30*50 35*60 35*52 35*60 0.54 0.79 0.81 0.90 0.95 1.02 1.02 1.14 1.26 1.26 1.32 1.38 1.38 1.38 1.65 1.65 1.65 1.83 1.83 1.83 1.83 2.52 2.52 2.52 3.03 3.03 3.03 4.10 4.10 4.59 4.59 4.98 5.03 4.80 4.65 5.10 5.09 5.20 470 560 680 820 1000 1200 100V 1500 1800 2200 2700 3300 3900 4700 5600 5600 6800 Size Rated ripple φD*L current KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity V μF mm A 220 22*26 22*31 25*26 30*26 22*36 25*31 30*26 22*31 22*41 25*36 30*31 35*27 22*46 25*36 30*31 35*27 22*36 25*41 30*36 35*32 25*51 30*41 35*32 25*56 30*46 35*37 30*51 35*42 30*51 35*42 35*52 35*42 35*52 35*45 22*26 25*26 22*31 25*26 30*26 22*31 25*26 30*26 0.42 0.98 0.98 1.00 1.21 1.21 1.21 1.15 1.40 1.40 1.40 1.40 1.64 1.58 1.65 1.71 1.49 1.76 1.85 1.85 2.15 2.15 2.15 2.46 2.46 2.46 2.80 2.80 3.13 3.13 3.26 3.18 3.50 3.35 0.54 0.54 0.92 0.92 0.92 1.03 1.03 1.05 330 470 560 680 160V 820 1000 1200 1500 1800 2200 3300 150 200V 220 270 Size Rated ripple φD*L current Rated Voltage Rated Capacity V μF 330 390 470 560 680 200V 820 1000 1200 1500 1800 2200 2700 100 250V 120 150 Rated ripple current(A,rms)at 105℃,120Hz Size Rated ripple φD*L current mm A 22*36 25*31 30*26 22*36 25*31 30*31 22*41 25*36 30*31 35*27 22*30 22*46 25*41 30*31 35*27 22*51 25*46 30*31 35*32 25*51 30*36 35*37 30*40 35*37 25*45 25*40 35*30 25*50 30*30 1.21 1.21 1.21 1.33 1.34 1.45 1.57 1.59 1.65 1.65 1.55 1.81 1.85 1.85 1.85 2.04 2.07 2.04 2.17 2.30 2.30 2.31 2.62 2.62 2.55 2.51 2.50 2.55 2.45 30*35 2.51 30*50 35*42 35*47 35*52 35*52 30*50 35*52 35*45 22*31 25*26 22*31 25*26 22*31 25*26 30*26 3.00 3.00 3.28 4.01 4.10 3.85 4.10 3.80 0.44 0.44 0.50 0.50 0.60 0.60 0.60 KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity Size φD*L Rated ripple current V μF mm A 1.00 1.00 0.95 1.28 1.28 1.28 1.28 1.48 1.48 1.48 1.76 1.76 1.76 1.56 1.60 1.56 1.68 1.68 1.93 1.93 1.93 2.15 2.22 2.22 2.48 2.15 2.20 2.46 2.43 2.48 2.48 2.20 2.25 2.74 2.65 2.80 2.70 3.00 3.00 3.50 3.50 5.00 5.10 5.10 220 330 390 470 560 250V 680 22*36 25*31 22*30 22*46 25*36 30*31 35*27 22*46 30*31 35*27 25*41 30*36 35*32 25*30 25*35 22*36 30*30 22*40 25*51 30*41 35*32 25*40 30*46 35*37 30*51 22*45 30*35 820 25*45 30*35 30*51 35*42 25*40 35*30 1000 30*50 30*40 35*47 30*45 1200 1500 2200 35*50 35*55 35*50 35*55 35*55 35*60 35*70 Rated Voltage Rated Capacity Size φD*L Rated ripple current V μF mm A 0.82 0.82 0.70 0.80 0.90 0.90 0.80 0.85 0.98 0.98 0.95 0.95 0.90 0.90 1.05 1.21 1.21 1.21 1.21 1.21 1.10 1.10 1.10 1.40 1.30 1.30 1.57 1.57 1.50 1.50 1.50 1.60 1.68 1.71 1.94 1.80 1.80 1.80 1.85 1.85 1.85 1.98 100 120 150 180 220 400V 270 330 390 470 22*36 25*31 22*25 25*25 22*36 25*31 22*25 25*25 22*41 25*36 30*31 35*27 22*30 25*25 25*36 30*30 30*41 25*40 25*35 35*32 22*40 25*30 30*25 30*40 25*40 30*35 30*40 35*30 22*45 25*40 30*35 35*35 30*40 35*42 35*45 25*50 30*40 35*35 30*50 30*45 35*40 35*50 Rated ripple current(A,rms)at 105℃,120Hz KFSON ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity Size φD*L Rated ripple current V μF mm A 2.23 2.23 2.40 2.40 2.85 2.83 2.80 2.70 2.65 2.90 2.83 2.85 3.20 3.15 3.15 3.10 3.30 3.30 3.30 0.64 0.64 0.64 0.74 0.74 0.74 0.70 0.72 0.72 0.82 0.82 0.82 0.80 0.80 0.80 0.80 0.96 0.96 0.96 0.96 0.90 560 680 400V 820 1000 1200 82 100 450V 120 150 35*50 30*45 35*45 35*40 35*62 35*50 35*45 30*50 35*40 35*62 35*45 35*50 35*70 35*65 35*60 35*50 35*70 35*65 35*60 22*36 25*31 30*26 22*41 25*31 30*31 22*25 22*35 25*25 22*46 25*36 30*31 22*30 25*25 25*30 30*25 22*51 25*41 30*36 35*27 22*30 Rated ripple current(A,rms)at 105℃,120Hz Rated Voltage Rated Capacity Size φD*L Rated ripple current V μF mm A 0.90 0.90 0.95 0.95 0.95 1.14 1.10 1.14 1.24 1.24 1.20 1.20 1.20 1.20 1.48 1.48 1.60 1.64 1.60 1.60 1.60 1.80 1.86 1.65 1.90 1.90 1.90 1.90 2.40 2.40 2.40 2.40 2.90 2.85 2.80 2.80 3.20 3.20 3.20 3.30 3.30 3.60 150 180 220 270 22*35 25*30 25*35 30*25 30*30 25*46 30*36 35*32 30*41 35*37 22*40 25*40 25*50 30*30 30*51 35*42 30*40 330 450V 390 470 560 680 820 1000 1200 30*50 25*50 30*35 35*30 35*40 35*52 35*35 35*50 35*45 30*50 30*60 35*50 35*45 35*40 30*50 35*60 35*50 35*45 30*55 35*70 35*65 35*60 35*70 35*65 35*80 ALUMINUM ELECTROLYTIC CAPACITORS KN series Standard Ratings Rated Voltage Rated Capacity Size φD*L Rated ripple current V μF mm A 0.90 0.94 0.94 0.94 0.94 0.94 0.94 1.10 1.13 1.13 1.39 1.40 1.50 1.60 1.60 1.60 1.70 1.70 2.10 2.10 2.10 2.50 2.47 2.60 2.65 3.10 3.80 3.80 4.70 100 120 150 180 500V 220 270 330 390 470 680 820 1000 22*40 22*45 25*40 30*30 25*40 30*30 35*25 25*40 30*35 35*30 25*50 30*40 30*40 30*45 35*35 35*40 30*50 35*40 30*55 30*60 35*50 35*55 35*50 35*55 35*60 35*70 35*80 40*70 40*80 Rated ripple current(A,rms)at 105℃,120Hz KFSON
KN681M20025*30A 价格&库存
很抱歉,暂时无法提供与“KN681M20025*30A”相匹配的价格&库存,您可以联系我们找货
