HYG350P13NA1B
HYG350P13NA1B
    HUAYI(华羿微)
    TO-263(D²Pak)
    P沟道 耐压:125V 电流:39A
HYG350P13NA1B 数据手册
HYG350P13NA1B Single P-Channel Enhancement Mode MOSFET Feature  Pin Description -125V/-39A RDS(ON)=35mΩ (typ.) @ VGS = -10V  100% Avalanche Tested  Reliable and Rugged  Lead- Free and Green Devices Available (RoHS Compliant) TO-263-2L Applications  Power Tool Application  Networking DC-DC Power System Single P-Channel MOSFET Ordering and Marking Information Package Code B B: TO-263-2L G350P13 Date Code XYMXXXXXX XYMXXXXXX Note: HUAYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HUAYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hymexa.com 1 V1.0 HYG350P13NA1B Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage -125 V VGSS Gate-Source Voltage ±20 V Maximum Junction Temperature 175 °C -55 to 175 °C Tc=25°C -39 A Tc=25°C -150 A Tc=25°C -39 A Tc=100°C -27 A Tc=25°C 120 W Tc=100°C 60 W 1.25 °C/W 62 °C/W 388.7 mJ TJ TSTG IS Storage Temperature Range Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RJC Thermal Resistance, Junction-to-Case RJA Thermal Resistance, Junction-to-Ambient ** EAS SinglePulsed-Avalanche Energy *** L=0.3mH * Repetitive rating;pulse width limited by max.junction temperature. ** Surface mounted on FR-4 board. *** Limited by TJmax , starting TJ=25°C, L = 0.3mH, VDS =-100V., VGS =-10V. Electrical Characteristics(Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HYG350P13NA1 Unit Min Typ. Max VGS=0V,IDS=250μA -125 - - V VDS=-125V,VGS=0V - - -1 μA - - -50 μA -1.0 -2.4 -3.0 V Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source Leakage Current VGS(th) IGSS RDS(ON)* TJ=100°C Gate Threshold Voltage VDS=VGS, IDS=-250μA Gate-Source Leakage Current VGS=±20V,VDS=0V - - ±100 nA Drain-Source On-State Resistance VGS=-10V,IDS=-20A - 35 43 mΩ Diode Characteristics VSD* Diode Forward Voltage ISD=-20A,VGS=0V - -0.84 -1.3 V trr Reverse Recovery Time ISD=-20A, - 35.6 - ns Qrr Reverse Recovery Charge dISD/dt=100A/μs - 58.2 - nC www.hymexa.com 2 V1.0 HYG350P13NA1B Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HYG350P13NA1 Min Typ. Max Unit Dynamic Characteristics RG Gate Resistance VGS=0V,VDS=0V,F=1MHz - 3.0 - Ciss Input Capacitance VGS=0V, - 4118 - Coss Output Capacitance VDS= -25V, - 285 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 194.8 - td(ON) Turn-on Delay Time - 35.2 - Tr Turn-on Rise Time VDD=-62V,RG=4Ω, - 101.2 - td(OFF) Turn-off Delay Time IDS=-20A,VGS=-10V - 35 - - 92.3 - Tf Turn-off Fall Time Gate Charge Qg(10V) Ω pF ns Characteristics Total Gate Charge VDS =-100V, VGS=-10V, - 79.4 - Qgs Gate-Source Charge ID=-20A - 13.0 - Qgd Gate-Drain Charge - 30.3 - VDS =-100V, VGS=-10V, ID=-20A nC nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hymexa.com 3 V1.0 HYG350P13NA1B Typical Operating Characteristics Figure 2: Drain Current ID-Drain Current(A) Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Tc-Case Temperature(℃) Zθjc -ID-Drain Current(A) Thermal Impedance Figure 4: Thermal Transient Impedance Normalized Transient Figure 3: Safe Operation Area Maximum Effective Transient Thermal Impedance, Junction-to-Case -VDS-Drain-Source Voltage(V) Figure 6: Drain-Source On Resistance ID-Drain Current(A) RDS(ON)-ON-Resistance(mΩ) Figure 5: Output Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com ID-Drain Current(A) 4 V1.0 HYG350P13NA1B Typical Operating Characteristics(Cont.) Figure 8: Source-Drain Diode Forward IS-Source Current (A) Normalized On-Resistance Figure 7: On-Resistance vs. Temperature Tj-Junction Temperature (℃) VSD-Source-Drain Voltage(V) Figure 10: Gate Charge Characteristics C-Capacitance(F) VGS-Gate-Source Voltage (V) Figure 9: Capacitance Characteristics VDS-Drain-Source Voltage (V) www.hymexa.com QG-Gate Charge (nC) 5 V1.0 HYG350P13NA1B Avalanche Test Circuit Switching Time Test Circuit Gate Charge Test Circuit www.hymexa.com 6 V1.0 HYG350P13NA1B Device Per Unit Package Type TO-263-2L TO-263-2L Package Information Unit Quantity Tube Reel 50 800 TO-263-2L COMMON DIMENSIONS SYMBOL mm MIN NOM MAX A 4.37 4.57 4.77 A1 1.22 1.27 1.42 A2 2.49 2.69 2.89 A3 0 0.13 0.25 b 0.7 0.81 0.96 b1 1.17 1.27 1.47 c 0.3 0.38 0.53 D1 8.5 8.7 8.9 D4 6.6 - - E 9.86 10.16 10.36 E5 7.06 - - e 2.54 BSC H 14.7 15.1 15.5 H2 1.07 1.27 1.47 L 2 2.3 2.6 L1 1.4 1.55 1.7 L4 θ www.hymexa.com 0.25 BSC 0° 5° 7 9° V1.0 HYG350P13NA1B Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmaxto TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5°C of the specified classification temperature (Tc) Average ramp-down rate (Tpto Tsmax) Time 25°C to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150 °C 200 °C 60-120 seconds 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 217 °C 60-150 seconds 60-150 seconds See Classification Temp in table 1 SeeClassification Tempin table 2 20** seconds 30** seconds 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hymexa.com 8 V1.0 HYG350P13NA1B Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HYG350P13NA1B 价格&库存
很抱歉,暂时无法提供与“HYG350P13NA1B”相匹配的价格&库存,您可以联系我们找货
