L6219
L6219
    YW(友旺)
    SOP-24-300mil
    步进电机驱动电路
L6219 数据手册
L6219 LINEAR INTEGRATED CIRCUIT STEPPER MOTOR DRIVER DESCRIPTION The L6219 is a bipolar monolithic integrated circuits intended to control and drive both winding of a bipolar stepper motor or bidirectionally control two DC motors. The L6219 with a few external components form a complete control and drive circuit for LS-TTL or microprocessor controlled SOP-24-375-1.27 stepper motor system. The power stage is a dual full bridge capable of sustaining 46V and including four diodes for current ORDERING INFORMATION recirculation. A cross conduction protection is provided to avoid simultaneous cross conduction during switching current direction. Device Package L6219 SOP-24-375-1.27 An internal pulse-width-modulation (PWM) controls the output current to 750mA with peak start-up current up to 1A. Wide range of current control from 750mA (each bridge) is permitted by means of two logic inputs and an external voltage reference. A phase input to each bridge determines the load current direction. A thermal protection circuitry disables the outputs if the chip temperature exceeds safe operating limits. FEATURES Able to drive both windings of bipolar stepper motor  Internal PWM current control  Output current up to 750mA each winding  Low output saturation voltage  Wide voltage range 10V to 46V  Designed for unstabilized motor  Half-step, full-step and micro-stepping mode  Built-in protection diodes  Supply voltage  Internal thermal shutdown BLOCK DIAGRAM YOUWANG ELECTRONICS CO.LTD 1 2017.09.15 V1.1 L6219 LINEAR INTEGRATED CIRCUIT PIN CONFIGURATION PIN FUNCTIONS Note: ESD on GND, VS, VSS, OUT 1A and OUT 2A is guaranteed up to 1.5KV (Human Body Model, 1500Ω, 100pF). YOUWANG ELECTRONICS CO.LTD 2 2017.09.15 V1.1 LINEAR INTEGRATED CIRCUIT L6219 ABSOLUTE MAXIMUM RATINGS Symbol Parameter Value Unit VS Supply Voltage 50 V Io Output Current (peak) ±1 A Io Output Current (continuous) ±0.75 A VSS Logic Supply Voltage VIN Logic Input Voltage Range 7 V -0.3 to +7 V Vsense Sense Output Voltage 1.5 V TJ Junction Temperature +150 ℃ Top Operating Temperature Range -20 to +85 ℃ Tstg Storage Temperature Range -55 to +150 ℃ THERMAL DATA Symbol Rthj-case Rthj-amb Description Thermal Resistance Junction-case Thermal Resistance Junction-ambient Max. Max. PDIP SO 14 60 (*) 18 75 (*) Unit ℃/W ℃/W (*) With minimized copper area. ELECTRICAL CHARACTERISTICS (Tj = 25°C, VS = 46V, VSS = 4.75V to 5.25V, VREF = 5V; unless otherwise specified) See fig. 1. Symbol Parameter Test Condition OUTPUT DRIVERS (OUTA or OUTB) Motor Supply Range VS ICEX Output Leakage Current VCE(sat) Output Saturation Voltage Min. Typ. 10 Max. Unit 46 V VOUT = Vs VOUT = 0 -
L6219 价格&库存
很抱歉,暂时无法提供与“L6219”相匹配的价格&库存,您可以联系我们找货
