ZOS-T1405-A02-F6(ZD)
    BOCHEN(博晨)
    DIP-4
    对射式光电开关
ZOS-T1405-A02-F6(ZD) 数据手册
CHAU LIGHT Technical Data Sheet ZOS-T1405-A02-F6(ZD) Optical Sensor black Transistor Output Descriptions The ZOS-T1405-A02-F6(ZD) is a photrrupter high-performance standard type,combines high-output GaAlAs IRED with high sensitive phototransistor. Features       Fast response time High analytic Cut-off visible wavelength λp=940nm High sensitivity Pb free This product itself will remain within RoHS compliant version Applications      Printers Switch Scanner Floppy disk driver Non-contact Switching For Direct Board GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 1 页 共 6 页 CHAU LIGHT Technical Data Sheet Package Dimension Notes: 1.All dimensions are in millimeters. 2.Tolerances unless dimensions ±0.3mm. 3.Lead spacing is measured where the lead emerge from the package. GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 2 页 共 6 页 CHAU LIGHT Technical Data Sheet Absolute Maximum Ratings(Ta=25℃) Parameter(Ta=25℃) Symbo Ratings Unit Power Dissipation at(or Below)25℃ Free Air Temperature Pd 75 mW Reverse Voltage VR 5 V Forward Current IF 50 mA IFP 1 A Collector Power Dissipation Pd 75 mW Collector Current IC 20 mA Collector-Emitter Voltage VCEO 30 V Emitter-Collector Voltage VECO 5 V Operating Temperature TOPR -25~+85 ℃ Storage Temperature TSTG -40~+100 ℃ Lead Soldering Temperature *2mm from body for 5 seconds) TSOL 260 ℃ Input (Emitter) Peak Forward Current*1 (Pulse width≤100μs,Duty cycle=1%) Output (Detector) (*1) tw=100 μsec. , T=10 msec. (*2) t=5 Sec Electro-Optical Characteristics (Ta=25℃) Parameter(Ta=25℃) Input (Emitter) Output (Detector) Transfer Characteristics Symbo Min. Typ. Max. Unit Conditions Forward Voltage VF -- 1.2 1.5 V IF=20mA Reverse Current IR -- -- 10 μA VR=5V P -- 940 -- nm IF=20mA ICEO -- -- 100 nA VCE=20V,Ee=0mW/cm2 C-E Saturation Voltage VCE(sat) -- -- 0.4 V IC=2mA,Ee=1mW/cm2 Collect Current IC(ON) 0.5 -- -- mA VCE=5V,IF=20mA Rise time tr -- 15 -- μS VCE=5V,IC=1mA,RL=1KΩ Fall time tf -- 15 -- μS VCE=5V,IC=1mA,RL=1KΩ Peak Wavelength Dark Current GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 3 页 共 6 页 CHAU LIGHT Technical Data Sheet Typical Electrical/Optical/Characteristics Curves for IR GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 4 页 共 6 页 CHAU LIGHT Technical Data Sheet Typical Electrical/Optical/Characteristics Curves for PT GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 5 页 共 6 页 CHAU LIGHT Technical Data Sheet Packing Quantity Specification 1.150PCS//1Bag 2.4Bag/1box 2. 10bos/1Carton GuangDong Chau Light Infrared Semiconductor Co., Ltd. Phone: +86-0760-8850 4720 Mobile: +86-13702503706 www.zgy-led.com E-mail:tonny@zgy-led.com 第 6 页 共 6 页
ZOS-T1405-A02-F6(ZD) 价格&库存
很抱歉,暂时无法提供与“ZOS-T1405-A02-F6(ZD)”相匹配的价格&库存,您可以联系我们找货
