BAS40W-05
BAS40W-05
    MSKSEMI(美森科)
    SOT-323-3
    肖特基二极管 电压:40V 电流:200mA SOT-323-3
BAS40W-05 数据手册
BAS40W/-04/-05/-06 Product specification BAS40W/-04/-05/-06 FEATURES  Low Forward Voltage  Fast Switching Reference News PACKAGE OUTLINE SOT-323 BAS40W BAS40W-06 BAS40W-05 BAS40W-04 43 46 45 44 MARKING:43 MARKING:46 MARKING:45 MARKING:44 Maximum Ratings @Ta=25℃ Parameter Symbol Peak repetitive peak reverse voltage VRRM Working peak reverse voltage DC blocking voltage VRWM Limit Unit 40 V VR Forward continuous current IFM 200 mA Power dissipation PD 150 mW Thermal resistance junction to ambient RθJA 667 ℃/W Operating Junction Temperature Range TJ -40 ~ +125 ℃ TSTG -55 ~ +150 ℃ Storage Temperature Range ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Reverse breakdown voltage Symbol V(BR) Reverse voltage leakage current IR Forward voltage VF Diode capacitance Reverse recovery time Copyright© Msksemi Incorporated IR= 10μA VR=30V CD t Test conditions rr Min Max 40 V 200 IF=1mA 380 IF=40mA 1000 VR=0,f=1MHz Irr=1mA, IR=IF=10mA RL=100Ω Unit nA mV 5 pF 5 ns www.msksemi.com BAS40W/-04/-05/-06 Forward 200 Characteristics Reverse 100 Characteristics (uA) ℃ T= a 2 5 T= a 1 00 ℃ 0.1 0.01 0.0 0.2 0.4 0.6 FORWARD VOLTAGE VF 10 Ta=100 ℃ 1 0.1 Ta=25℃ 0.01 1E-3 1.0 0 10 (V) 20 30 REVERSE VOLTAGE Capacitance Characteristics 4 Ta=25℃ f=1MHz 40 (V) 150 PD 3 VR Power Derating Curve 200 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) 0.8 (mW) FORWARD CURRENT 1 REVERSE CURRENT IR 10 IF (mA) 100 2 1 0 0 5 10 REVERSE VOLTAGE Copyright© Msksemi Incorporated 15 VR (V) 20 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 (℃) www.msksemi.com BAS40W/-04/-05/-06 PACKAGEMECHANICALDATA Symbol A A1 A2 b c D E E1 e e1 L L1  Dimensions In Millimeters Min Max 0.900 1.100 0.000 0.100 0.900 1.000 0.200 0.400 0.080 0.150 2.000 2.200 1.150 1.350 2.150 2.450 0.650 TYP 1.200 1.400 0.525 REF 0.260 0.460 0° 8° Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.008 0.016 0.003 0.006 0.079 0.087 0.045 0.053 0.085 0.096 0.026 TYP 0.047 0.055 0.021 REF 0.010 0.018 0° 8° Suggested Pad Layout Note: 1.Controlling dimension:in millimeters. 2.General tolerance:±0.05mm. 3.The pad layout is for reference purposes only. REEL SPECIFICATION P/N PKG QTY BAS40W/-04/-05/-06 SOT-323 3000 Copyright© Msksemi Incorporated www.msksemi.com BAS40W/-04/-05/-06 Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
BAS40W-05 价格&库存
很抱歉,暂时无法提供与“BAS40W-05”相匹配的价格&库存,您可以联系我们找货
BAS40W-05
  • 20+0.14250
  • 200+0.11101
  • 600+0.09351
  • 3000+0.08301
  • 9000+0.07397
  • 21000+0.06902
库存:1527
