LM-L2N7002LT1G
N-Channel Enhancement Mode Field Effect Transistor
Product Summary
● VDS
● ID
● RDS(ON)( at VGS=10V)
● RDS(ON)( at VGS=4.5V)
60V
340mA
<2.5ohm
<3.0ohm
General Description
● Trench Power MV MOSFET technology
● Voltage controlled small signal switch
● Low input Capacitance
● Fast Switching Speed
● Low Input / Output Leakage
Applications
● Battery operated systems
● Solid-state relays
● Direct logic-level interface:TTL/CMOS
■ Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Drain-source Voltage
VDS
60
V
Gate-source Voltage
VGS
±20
V
TA=25℃ @ Steady State
Drain Current
340
ID
TA=70℃ @ Steady State
Unit
mA
272
Pulsed Drain Current A
IDM
1.5
A
Total Power Dissipation @ TA=25℃
PD
350
mW
RθJA
357
℃/ W
TJ ,TSTG
-55~+150
Thermal Resistance Junction-to-Ambient @ Steady State B
Junction and Storage Temperature Range
■ Ordering Information (Example)
PREFERED P/N
PACKING
CODE
Marking
MINIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
OUTER CARTON
QUANTITY(pcs)
DELIVERY MODE
LM-L2N7002LT1G
F2
7002.
3000
30000
120000
7“ reel
Rev : 03.12.2021
1/5
www.leiditech.com
LM-L2N7002LT1G
■ Electrical Characteristics (TJ=25℃ unless otherwise noted)
Parameter
Symbol
Conditions
Min
Typ
Max
Units
Drain-Source Breakdown Voltage
BVDSS
VGS= 0V, ID=250μA
60
Zero Gate Voltage Drain Current
IDSS
VDS=60V,VGS=0V
1
μA
IGSS1
VGS= ±20V, VDS=0V
±100
nA
IGSS2
VGS= ±10V, VDS=0V
±50
nA
VGS(th)
VDS= VGS, ID=250μA
1.5
2.5
V
VGS= 10V, ID=-300mA
1.2
2.5
VGS= 4.5V, ID=200mA
1.3
3.0
Static Parameter
V
Gate-Body Leakage Current
Gate Threshold Voltage
Static Drain-Source On-Resistance
Diode Forward Voltage
Maximum Body-Diode Continuous Current
1
Ω
RDS(ON)
VSD
IS=300mA,VGS=0V
IS
1.2
V
340
mA
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
16
VDS=30V,VGS=0V,f=1MHZ
10
pF
5.5
Switching Parameters
Total Gate Charge
Turn-on Delay Time
Qg
VGS=10V,VDS=30V,ID=0.3A
1.7
Reverse recovery Time
tD(off)
trr
nC
5
tD(on)
VGS=10V,VDD=30V, ID=300mA,
RGEN=6Ω
Turn-off Delay Time
2.4
ns
17
VGS=0V,IS=300mA,VR=25V, dIS/dt=100A/μs
30
ns
A. Pulse Test: Pulse Width≤300us,Duty cycle ≤2%.
B. Device mounted on FR-4 PCB, 1 inch x 0.85 inch x 0.062 inch.
Rev : 03.12.2021
2/5
www.leiditech.com
LM-L2N7002LT1G
■ Typical Performance Characteristics
Figure1. Output Characteristics
Figure2. Transfer Characteristics
Figure3. Capacitance Characteristics
Figure4. Gate Charge
Figure5. Drain-Source on Resistance
Rev : 03.12.2021
Figure6. Drain-Source on Resistance
3/5
www.leiditech.com
LM-L2N7002LT1G
Figure7. Safe Operation Area
Rev : 03.12.2021
Figure8. Switching wave
4/5
www.leiditech.com
LM-L2N7002LT1G
■ SOT-23 Package information
■SOT-23 Suggested Pad Layout
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 03.12.2021
5/5
www.leiditech.com
很抱歉,暂时无法提供与“LM-L2N7002LT1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.34253
- 100+0.28322
- 300+0.25357
- 3000+0.23133
- 6000+0.21356
- 9000+0.20462
