BSMD0603-050-16V
BSMD0603-050-16V
    BHFUSE(佰宏)
    PTC自恢复保险丝 0603 16V
BSMD0603-050-16V 数据手册
BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝  Features       Size 0.06*0.03 inch /1.5*0.8 mm RoHS compliant, lead-free and halogen-free Fast response to fault current Low resistance Low profile Compatible with high temperature solders  Applications  Computer, Mobile phones, Multimedia  Automotive, Industrial controls, Telephony and broadband  Game machines, Portable electronics, Battery  Electrical Characteristics(25℃) Part Number BSMD0603-001-60V BSMD0603-002-60V BSMD0603-003-30V BSMD0603-004-24V BSMD0603-005-15V BSMD0603-005-24V BSMD0603-005-33V BSMD0603-010-15V BSMD0603-010-24V BSMD0603-010-33V BSMD0603-020-9V BSMD0603-020-12V BSMD0603-020-16V BSMD0603-020-24V BSMD0603-025-9V BSMD0603-025-12V BSMD0603-025-16V BSMD0603-025-24V BSMD0603-035-6V BSMD0603-035-12V Ihold (A) 0.01 0.02 0.03 0.04 0.05 0.05 0.05 0.10 0.10 0.10 0.20 0.20 0.20 0.20 0.25 0.25 0.25 0.25 0.35 0.35 Itrip (A) 0.05 0.06 0.09 0.12 0.15 0.15 0.15 0.30 0.30 0.30 0.50 0.50 0.50 0.50 0.55 0.55 0.55 0.55 0.75 0.75 Vmax (Vdc) 60 60 30 24 15 24 33 15 24 33 9 12 16 24 9 12 16 24 6 12 Specifications are subject to change without notice Revision 2022 Imax (A) 20 20 20 20 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 Pd typ (W) 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 Time to trip (A) (Sec) 0.20 1.00 0.20 1.00 0.20 1.00 0.20 1.00 0.25 1.00 0.25 1.00 0.25 1.00 0.50 0.60 0.50 0.60 0.50 0.60 1.00 0.60 1.00 0.60 1.00 0.60 1.00 0.60 8.00 0.08 8.00 0.08 8.00 0.08 8.00 0.08 8.00 0.10 8.00 0.10 Rmin (Ω) 15.00 12.00 6.00 4.00 3.80 3.80 3.80 0.90 0.90 0.90 0.55 0.55 0.55 0.55 0.50 0.50 0.50 0.50 0.20 0.20 Polymer PTC Thermistor www.bhfuse.com R1max (Ω) 100.0 70.0 50.0 40.0 30.0 30.0 30.0 8.00 8.00 8.00 3.50 3.50 3.50 3.50 3.00 3.00 3.00 3.00 1.40 1.40 1/7 BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝 Part Number BSMD0603-035-16V BSMD0603-050-6V BSMD0603-050-9V BSMD0603-050-12V BSMD0603-050-16V BSMD0603-075-6V BSMD0603-075-8V BSMD0603-100-6V Ihold (A) 0.35 0.50 0.50 0.50 0.50 0.75 0.75 1.00 Itrip (A) 0.75 1.00 1.00 1.00 1.00 1.50 1.50 2.00 Vmax (Vdc) 16 6 9 12 16 6 8 6 Imax (A) 40 40 40 40 40 40 40 40 Pd typ (W) 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 Time to trip (A) (Sec) 8.00 0.10 8.00 0.10 8.00 0.10 8.00 0.10 8.00 0.10 8.00 0.10 8.00 0.10 8.00 0.10 Rmin (Ω) 0.20 0.10 0.10 0.10 0.10 0.06 0.06 0.05 R1max (Ω) 1.40 0.80 0.80 0.80 0.80 0.45 0.45 0.30  Vocabulary Ihold = Itrip = Vmax = Imax = Pd typ. = Rmin = R1max = Hold current: maximum current device will pass without tripping in 25℃ still air. Trip current: minimum current at which the device will trip in 25℃ still air. Maximum voltage device can withstand without damage at rated current (Imax). Maximum fault current device can withstand without damage at rated voltage (Vmax). Typical power dissipated from device when in the tripped state at 25℃ still air. Minimum resistance of device in initial (un-soldered) state. Maximum resistance of device at 25℃ measured one hour after tripping or reflow soldering of 260℃ for 20 sec. Caution:Operation beyond the specified ratings may result in damage and possible arcing and flame.  Warning  Users shall independently assess the suitability of these devices for each of their applications.  Operation of these devices beyond the stated maximum ratings could result in damage to the devices and lead to electrical arcing and/or fire.  These devices are intended to protect against the effects of temporary over-current or over-temperature conditions and are not intended to perform as protective devices where such conditions are expected to be repetitive or prolonged in duration.  Exposure to silicon-based oils, solvents, electrolytes, acids, and similar materials can adversely affect the prolonged of these PPTC devices.  These devices undergo thermal expansion under fault conditions, and thus shall be provided with adequate space and be protected against mechanical stresses.  Circuits with inductance may generate a voltage (L di/dt) above the rated voltage of the PPTC device. Specifications are subject to change without notice Revision 2022 Polymer PTC Thermistor www.bhfuse.com 2/7 BHFUSE 佰宏保险丝 BSMD0603 Series Surface Mount PTC Device  Thermal Derating Curve Derating Curves for BSMD0603 Series  Average Time-Current Curve A=BSMD0603-001 B=BSMD0603-002 C=BSMD0603-003 D=BSMD0603-004 E=BSMD0603-005 F=BSMD0603-010 G=BSMD0603-020 H=BSMD0603-025 I=BSMD0603-035 J=BSMD0603-050 K=BSMD0603-075 L=BSMD0603-100 Specifications are subject to change without notice Revision 2022 Polymer PTC Thermistor www.bhfuse.com 3/7 BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝  Thermal Derating Chart Part Number BSMD0603-001 BSMD0603-002 BSMD0603-003 BSMD0603-004 BSMD0603-005 BSMD0603-010 BSMD0603-020 BSMD0603-025 BSMD0603-035 BSMD0603-050 BSMD0603-075 BSMD0603-100 Ambient operating temperature hold current(Ihold) -40℃ 0.016 -20℃ 0.014 0℃ 0.012 25℃ 0.010 40℃ 0.008 50℃ 0.007 60℃ 0.006 70℃ 0.005 85℃ 0.0035 0.031 0.027 0.024 0.020 0.016 0.014 0.012 0.011 0.007 0.048 0.052 0.041 0.048 0.036 0.044 0.030 0.040 0.024 0.032 0.021 0.028 0.018 0.024 0.016 0.020 0.011 0.012 0.065 0.060 0.055 0.050 0.040 0.035 0.031 0.025 0.015 0.13 0.12 0.11 0.10 0.08 0.07 0.06 0.05 0.03 0.27 0.32 0.25 0.29 0.23 0.27 0.20 0.25 0.17 0.21 0.14 0.18 0.12 0.16 0.10 0.14 0.07 0.10 0.47 0.67 0.41 0.59 0.38 0.51 0.35 0.50 0.29 0.41 0.26 0.37 0.24 0.34 0.20 0.29 0.14 0.20 0.98 0.85 0.81 0.75 0.60 0.54 0.44 0.40 0.31 1.19 1.13 1.08 1.00 0.80 0.72 0.59 0.54 0.43  Environmental Specifications Test Conditions Passive aging +85°C, 1000 hours Humidity aging +85°C, 85% R.H. , 168 hours Thermal shock +85°C to -40°C, 20 times Resistance to solvent MIL-STD-202,Method 215 Vibration MIL-STD-202,Method 201 Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is Specifications are subject to change without notice Revision 2022 Resistance change ±5% typical ±5% typical ±33% typical No change No change 125 °C Polymer PTC Thermistor www.bhfuse.com 4/7 BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝  Soldering Parameters Profile Feature Average Ramp-Up Rate(Tsmax to Tp) Preheat -Temperature Min(Tsmin) -Temperature Max(Tsmax) -Time(Tsmin to Tsmax) Time maintained above: -Temperature(TL) -Time(tL) Peak Temperature(Tp) Ramp-Down Rate Time 25℃ to Peak Temperature Storage Condition Pb-Free Assembly 3℃/second max 150℃ 200℃ 60~180 seconds 217℃ 60~150 seconds 260℃ 6℃/second max 8 minutes max 0℃~30℃,30%-60%RH  Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free.  Recommended maximum paste thickness is 0.25mm.  Devices can be cleaned using standard industry methods and solvents. Note 1: All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Specifications are subject to change without notice Revision 2022 Polymer PTC Thermistor www.bhfuse.com 5/7 BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝  Physical Dimensions & Recommended Pad Layout (mm) A 1.00±0.1 1.00±0.1 1.00±0.1 3 B 0.80±0.1 D Part Number BSMD0603-001-60V BSMD0603-002-60V BSMD0603-003-30V BSMD0603-004-24V BSMD0603-005-15V BSMD0603-005-24V BSMD0603-005-33V BSMD0603-010-15V BSMD0603-010-24V BSMD0603-010-33V BSMD0603-020-9V BSMD0603-020-12V BSMD0603-020-16V BSMD0603-020-24V BSMD0603-025-9V BSMD0603-025-12V BSMD0603-025-16V BSMD0603-025-24V BSMD0603-035-6V BSMD0603-035-12V BSMD0603-035-16V BSMD0603-050-6V BSMD0603-050-9V BSMD0603-050-12V BSMD0603-050-16V BSMD0603-075-6V BSMD0603-075-8V BSMD0603-100-6V E C Marking Quantity X Y Z 1 1 1 2 2 2 2 2 2 2 2 3 3 3 5 5 5 5 7 7 0 4000 4000 4000 4000 4000 4000 4000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 4000 4000 4000 4000 4000 4000 4000 Min 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 1.45 Specifications are subject to change without notice Revision 2022 A Max 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 1.85 Min 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 0.65 B Max 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 1.05 Min 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.40 0.55 0.55 0.55 0.55 0.55 0.55 0.55 C Max 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.15 1.15 1.15 1.15 1.15 1.15 1.15 Polymer PTC Thermistor www.bhfuse.com D Min 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 E Min 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 6/7 BHFUSE BSMD0603 Series Surface Mount PTC Device 佰宏保险丝  Tape And Reel Specifications (mm) Governing Specifications W F E1 D0 D1 P0 P1 P2 A0 B0 T K0 Leadermin Trailermin C D H W BSMD0603-001~ BSMD0603-025 8.0 ± 0.3 3.5 ± 0.05 1.75 ± 0.1 1.55 ± 0.05 1.0 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.10 ± 0.1 1.95 ± 0.1 0.2 ± 0.1 0.72 ± 0.1 390 160 BSMD0603-035~ BSMD0603-100 8.0 ± 0.3 3.5 ± 0.05 1.75 ± 0.1 1.55 ± 0.05 1.0 ± 0.1 4.0 ± 0.1 4.0 ± 0.1 2.0 ± 0.05 1.10 ± 0.1 1.95 ± 0.1 0.2 ± 0.1 0.85 ± 0.1 390 160 Reel Dimensions φ178 ± 1.0 φ60.2 ± 0.5 11.0 ± 0.5 9.0 ± 1.5  Contact information SHENZHEN BHFUSE INDUSTRIAL CO., LTD TEL: 0755-85259917 E-MAIL: sales@bhfuse.com Specifications are subject to change without notice Revision 2022 Polymer PTC Thermistor www.bhfuse.com 7/7
BSMD0603-050-16V 价格&库存
很抱歉,暂时无法提供与“BSMD0603-050-16V”相匹配的价格&库存,您可以联系我们找货
