2EDGVC-5.08-12P-14-130A(H)
    DEGSON(高松)
    P=5.08mm
    接线端子 P=5.08mm 12Pin
2EDGVC-5.08-12P-14-130A(H) 数据手册
FOR-1755 Rev.1.7 5 4 3 2 6 Transfer or duplication of this document as well as the utilization or communication of its contents are prohibited unless explicit authorization is granted. Violations will be liable for compensation. All rights reserved for patent, utility model or designs registrations. 除非给予明确授权,否则禁止转让、复制、利用、交流本文件的内容。侵犯者将负赔偿责任。本公司保留对涉及发明、实用新型和外观专利的所有权利。 未注公差/General tolerances(mm) 0 >3 >6 >10 >18 >30 >50 >80 >120 >180 >250 >315 >400 ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ >500 3 6 10 18 30 50 80 120 180 250 315 400 500 ±0.12 ±0.18 ±0.22 ±0.26 ±0.31 ±0.37 ±0.57 ±0.80 ±0.93 ±1.05 ±1.15 ±1.60 ±2.20 ±2.50 0.1/10 ±2° PCB LAYOUT O1 5.08 3.8 3.54 A .5 5.08x(N-1) N Tolerances(mm) 02-05P ±0.31 06-11P ±0.57 B 5.08xN+2 8.6 4 ±0.3 12 1 Note: The A&Z(H) in the name means:A(H) and Z(H). 2 3.54 5.08 q1 2 3.8 5.08x(N-1) 7.8 Pin 00 REV 1 ECN 2 DESCRIPTION 3 周锡锦 2022.10.21 DRFT DATE 4 2022.10.21 NAME 2022.10.21 2022.10.21 mm (inch) DRAWING NO. UL94V-0 1 Housing PBT NAME OF PART MATERIAL MATERIAL: MAT NO./REV: - / 00 APPD: 兰春华 CHKD: 龚耀志 DRFT: 周锡锦 A4 Sn Plated ITEM UL 标准/UL Standard: 额定电压/电流/Rated Voltage(V)/Current(A) IEC 标准/IEC Standard: 过压类别/Overvoltage Category/污染等级/Pollution Degree 额定电压/电流/Rated Voltage(V)/Current(A) 额定脉冲电压(KV)/Rate Impulse Voltage(KV) 间距/Pitch(mm)/线数范围/Poles 使用温度范围/Operating temperature(°C) 符合RoHS环保要求/Conform to RoHS C Copper NOTES B 300/15 Ⅲ/3 / / C / D 300/10 Ⅲ/2 Ⅱ/2 320/20 / 4 / 5.08/N=02~24P -30~+120 Yes SURFACE/COLOR: MAT STATUS: 批量 2EDGVC-5.08-XXP-1Y-130A&Z(H) TYPE CUSTOMER DRAWING 200021105 5 DRAWING STATUS SCALE SHEET 已发布 2:1 1/1 6 D
2EDGVC-5.08-12P-14-130A(H) 价格&库存
很抱歉,暂时无法提供与“2EDGVC-5.08-12P-14-130A(H)”相匹配的价格&库存,您可以联系我们找货
