600L0R4AT200T4K
600L0R4AT200T4K
    ATC
    0.4 pF ±0.05pF 200V 陶瓷电容器 C0G,NP0 0402(1005 公制)
600L0R4AT200T4K 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors FEATURES • • • • • Lowest ESR in Class Highest Working Voltage in Class - 200 V Capacitance Range 0.1 pF to 27 pF High Q High Self-Resonance 600 SERIES OVERVIEW APPLICATIONS • Subscriber-based Wireless Devices • WiFi (802.11) • Public Safety Radio CIRCUIT APPLICATIONS EIA Case Size 600 L 0402 600 S 0603 600 F 0805 LEAD-FREE COMPATIBLE COMPONENT Tape & Reel ENVIRONMENTAL CHARACTERISTICS • Filter Networks • High Q Frequency Sources • Matching Networks • Tuning, Coupling, Bypass and DC Blocking ELECTRICAL SPECIFICATIONS Temperature Coefficient (TCC) 0 ± 30 PPM/ºC Capacitance Range 0.1 pF to 27 pF Operating Temperature -55ºC to +125ºC* Quality Factor Greater than 2,000 at 1 MHz Themal Shock 5 Cycles, -55ºC to 125ºC Moisture Resistance Mil-STD-202, Method 106 Life Test 2000 hours at 125ºC at 2X Solderability Solder Coverage > 90% of end termination Terminal Strength 2 lbs. typ., 1 lb. min. Military Approval DSCC Drawing Number 05003 105 Megohms min. @ 25ºC at rated WVDC 104 Megohms min. @ 125ºC at rated WVDC Working Voltage (WVDC) 200 V Dielectric Withstanding Voltage (DWV) 250% of rated WVDC for 5 seconds Aging Effects None Piezoelectric Effects None 484 Case Size PACKAGING OPTIONS • Cellular Base Stations • Broadband Wireless Services • Satellite Communications Insulation Resistance (IR) Series The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.kyocera-avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. TDS-RFM-0015 | Rev 1 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors CAPACITANCE VALUES Value (pF) Cap Code Tolerances Value (pF) Cap Code Tolerances Value (pF) Cap Code Tolerances 0.1 0R1 A, B 1.6 1R6 A, B, C, D 6.2 6R2 A, B, C, D 0.2 0R2 A, B 1.8 1R8 A, B, C, D 6.8 6R8 B, C, J, K 0.3 0R3 A, B, C 2.0 2R0 A, B, C, D 7.5 7R5 B, C, J, K 0.4 0R4 A, B, C 2.2 2R2 A, B, C, D 8.2 8R2 B, C, J, K 0.5 0R5 A, B, C 2.4 2R4 A, B, C, D 9.1 9R1 B, C, J, K 0.6 0R6 A, B, C 2.7 2R7 A, B, C, D 10 100 F, G, J, K, M 0.7 0R7 A, B, C 3.0 3R0 A, B, C, D 11 110 F, G, J, K, M 0.8 0R8 A, B, C 3.3 3R3 A, B, C, D 12 120 F, G, J, K, M 0.9 0R9 A, B, C 3.6 3R6 A, B, C, D 15 150 F, G, J, K, M 1.0 1R0 A, B, C, D 3.9 3R9 A, B. C. D 18 180 F, G, J, K, M 1.1 1R1 A, B, C, D 4.3 4R3 A, B, C, D 20 200 F, G, J, K, M 1.2 1R2 A, B, C, D 4.7 4R7 A, B, C, D 22 220 F, G, J, K, M 1.3 1R3 A, B, C, D 5.1 5R1 A, B, C, D 24 240 F, G, J, K, M 1.5 1R5 A, B, C, D 5.6 5R6 A, B, C, D 27 270 F, G, J, K, M HOW TO ORDER 600 L 100 J T 200 T Series Packaging Case Size T=Tape and Reel, 500 pcs T4K=Tape and Reel, 4000 pcs T10K = Tape and Reel, 10,000 pcs See mechanical dimensions below Capacitance Voltage Rating EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures Termination Style Code Capacitance Tolerance Code Code Tol. A B C D ±0.05 pF ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% T = Tin Plated over Nickel Barrier (RoHS Compliant) TN = Tin Plated Non-Magnetic Barrier W = Tin/Lead Solder Nickel Barrier *All Tape and Reel Packaging comes on 7" reels. The above part number refers to a 600L Series (case size L) 11 pF capacitor, J tolerance (±5%), 200 WVDC, with T termination (Tin Plated over Nickel Barrier, RoHS Compliant), Tape and Reel packaging. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.kyocera-avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. TDS-RFM-0015 | Rev 1 – rf microwave products – 485 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors ESR (Ohms) 1 600L ESR vs. Frequency 27 pF 15 pF 8.2 3.3 pF 1.0 pF 0.1 (Typical) 0.01 100 1000 10000 Frequency (MHz) Frequency (GHz) 600L Resonant Frequency Data ) 0.1 1.0 10.0 Capacitance (pF) ATC 600L Series Data Sheet Test Condition Description Capacitors mounted in series microstrip configuration on 10-mil thick Rogers RO4350® softboard, 22-mils wide 1/2 oz. Cu traces. FSR = lowest frequency at which S11 response, referenced at capacitor edge, crosses real axis on Smith Chart. FPR = lowest frequency at which there is a notch in S21 magnitude response. 486 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.kyocera-avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. TDS-RFM-0015 | Rev 1 – rf microwave products – 100.0 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 600L Ultra-Low ESR NPO Capacitors OUTLINE DIMENSIONS L (0402) Y L: .040 ± .004 (1.02 ± 0.1) W: .020 ± .004 (.51 ± 0.1) T: .024 max (0.60 max) Y: .010 ± .006 (0.25 ± 0.15) inches (mm) W T L SUGGESTED MOUNTING PAD DIMENSIONS Case Size L, S, and F W L T B A Case Size A Min. B Min. C Min. D Min. 0402 (1005) .0275 (0.70) .0354 (0.90) .0157 (0.40) .0866 (2.20) 0603 (1608) .0393 (1.00) .0433 (1.10) .0236 (0.60) .110 (2.80) 0805 (2012) .0590 (1.50) .0512 (1.30) .0236 (0.60) .1259 (3.20) B inches (mm) C D DESIGN KITS Kit # Kit 36T Kit 37T Kit 38T RoHS Compliant Item # Description 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0036T 16 different values, 15 pcs. min. per value 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0037T 16 different values, 15 pcs. min. per value 600L Series Ultra-low ESR, High Q Microwave Capacitors DK0038T 8 different values, 15 pcs. min. per value Cap. Value Range (pF) 0.1 to 2.0 Cap. Value (pF) Tol. (pF) 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0, 1.1, 1.2, 1.5.................. ±0.1 Price $100.00 1.6, 1.8, 2.0....................................... ±0.25 0.1 to 10 1.0, 1.2, 1.5, 1.8, 2.0. 2.2, 2.4, 2.7, 3.0, 3.3.............................................. ±0.1 3.9, 4.7, 5.6, 6.8, 8.2......................... ±0.25 10...................................................... ±5% $100.00 10 to 27 10, 12, 15, 18, 20, 22, 24, 27............. ±5% $100.00 For Online Kit Orders, Catalog & Application Notes, Visit: www.avx.com The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.kyocera-avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. TDS-RFM-0015 | Rev 1 – rf microwave products – 487
600L0R4AT200T4K 价格&库存
很抱歉,暂时无法提供与“600L0R4AT200T4K”相匹配的价格&库存,您可以联系我们找货
