MLESWT-A1-0000-0002E7
    CREELED
    SMD4_EP
    LED 照明 XLamp® ML-E 白色,暖色 3000K(2850K ~ 3250K) 9.6V 50mA 120° 4-SMD,J 形引线裸露焊盘
MLESWT-A1-0000-0002E7 数据手册
PRODUCT FAMILY DATA SHEET ® XLamp ML-E LEDs PRODUCT DESCRIPTION FEATURES The XLamp® ML-E LED brings lighting-class reliability and • Available in white (2600 K to 8300 K CCT), 80-, 85- and 90‑CRI performance to ½-watt LEDs. The XLamp ML-E LED expands minimum Cree LED’s lighting-class leadership to LED bulbs and linear and • Available in royal blue, blue, green, amber and red distributed lighting applications. With XLamp LED lighting‑class • Available in parallel and series Vf configurations for white and reliability, a wide viewing angle, uniform light output, and color industry‑leading chromaticity binning in a 3.5‑mm X 3.5-mm • ANSI-compatible sub-bins package, the XLamp ML-E LED continues Cree LED’s history • Maximum drive current: 500 mA for parallel white, 167 mA for of segment-focused product innovation in LEDs for lighting series white, 350 mA for parallel royal blue, blue, green and applications. red, 250 mA for parallel amber, 120 mA  for series blue and green, 65 mA for series amber, 88 mA for series red The XLamp ML-E LED brings high performance and a smooth look • 120° viewing angle for white, 125° viewing angle for color to a wide range of lighting applications, including linear lighting, • Uniform chromaticity profile LED light bulbs, fluorescent retrofits and retail-display lighting. • Electrically neutral thermal path • RoHS and REACH compliant • UL® recognized component (E349212) Cree LED / 4001 E. Hwy. 54, Suite 2000 / Durham, NC 27709 USA / +1.919.313.5330 / www.cree-led.com © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 1 XLAMP ® ML-E LED TABLE OF CONTENTS Characteristics...................................................................................3 Performance Groups – Chromaticity............................................. 32 Characteristics...................................................................................4 Standard Cool White Kits Plotted on ANSI Standard Flux Characteristics - Parallel White.................................................5 Chromaticity Regions..................................................................... 35 Flux Characteristics - Series White...................................................8 Standard Warm and Neutral White Kits Plotted on ANSI Flux Characteristics - Parallel Color............................................... 11 Standard Chromaticity Regions..................................................... 37 Flux Characteristics - Series Color................................................. 13 Standard Chromaticity Kits............................................................ 39 Relative Spectral Power Distribution - White................................. 15 Bin and Order Code Formats.......................................................... 40 Relative Spectral Power Distribution - Color................................. 15 Reflow Soldering Characteristics................................................... 41 Relative Luminous Flux vs. Junction Temperature - White.......... 16 Notes............................................................................................... 42 Relative Luminous Flux vs. Junction Temperature - Parallel: Mechanical Dimensions................................................................. 44 Blue, Green, Amber, Red, Series: Blue, Green, Amber, Red............ 16 Tape and Reel.................................................................................. 46 Relative Radiant Flux vs. Junction Temperature - Parallel Royal Packaging........................................................................................ 47 Blue.................................................................................................. 17 Electrical Characteristics - Parallel White...................................... 18 Electrical Characteristics - Series White........................................ 18 Electrical Characteristics - Parallel Color...................................... 19 Electrical Characteristics - Series Color........................................ 19 Relative Luminous Flux vs. Current - Parallel White...................... 20 Relative Luminous Flux vs. Current - Series White........................ 20 Relative Luminous Flux vs. Current - Parallel Blue, Green, Amber, Red...................................................................................... 21 Relative Luminous Flux vs. Current - Series Blue, Green, Amber, Red................................................................................................... 21 Relative Radiant Flux vs. Current - Parallel Royal Blue................. 22 Typical Spatial Distribution - White................................................ 22 Typical Spatial Distribution - Royal Blue, Blue, Green................... 23 Typical Spatial Distribution - Amber, Red...................................... 23 Thermal Design - Parallel White..................................................... 24 Thermal Design - Series White....................................................... 24 Thermal Design - Parallel Royal Blue............................................. 25 Thermal Design - Parallel Blue....................................................... 25 Thermal Design - Series Blue......................................................... 26 Thermal Design - Parallel Green..................................................... 26 Thermal Design - Series Green....................................................... 27 Thermal Design - Parallel Amber................................................... 27 Thermal Design - Series Amber..................................................... 28 Thermal Design - Parallel Red........................................................ 28 Thermal Design - Series Red.......................................................... 29 Performance Groups – Luminous or Radiant Flux....................... 30 Performance Groups – Dominant Wavelength............................. 31 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 2 XLAMP ® ML-E LED CHARACTERISTICS (TJ = 25 °C) Characteristics Unit Thermal resistance, junction to solder point - white◊ °C/W 9 Thermal resistance, junction to solder point - royal blue, blue◊ °C/W 8 Thermal resistance, junction to solder point - green◊ °C/W 11 Thermal resistance, junction to solder point - amber °C/W 23 Thermal resistance, junction to solder point - red °C/W 19 Viewing angle (FWHM) - white degrees 120 Viewing angle (FWHM) - royal blue, blue, green, amber, red degrees 125 Temperature coefficient of voltage - parallel - white, royal blue mV/°C -3.3 Temperature coefficient of voltage - parallel - blue mV/°C -2 Temperature coefficient of voltage - series - white mV/°C -10 Temperature coefficient of voltage - series - blue mV/°C -5 Temperature coefficient of voltage - parallel - green mV/°C -3 Temperature coefficient of voltage - series - green mV/°C -9 Temperature coefficient of voltage - parallel - amber mV/°C -1 Temperature coefficient of voltage - series - amber mV/°C -3.2 Temperature coefficient of voltage - parallel - red mV/°C -1.8 Temperature coefficient of voltage - series - red mV/°C -5.4 ◊ ◊ ESD withstand voltage (HBM per Mil-Std-883D) - white, royal blue, blue, green Minimum Typical V ESD classification (HBM per Mil-Std-883D) - amber, red Maximum 8000 Class 2 DC forward current - parallel - white mA 500 DC forward current - series - white mA 167 DC forward current - parallel - royal blue, blue, green, red mA 350 DC forward current - series - blue, green mA 120 DC forward current - parallel - amber mA 250 DC forward current - series - amber mA 65 DC forward current - series - red mA 88 V 1 Reverse voltage © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 3 XLAMP ® ML-E LED CHARACTERISTICS (TJ = 25 °C) - CONTINUED Characteristics Unit Minimum Typical Maximum Forward voltage (@ 150 mA) - parallel - white, royal blue V 3.2 3.4 Forward voltage (@ 50 mA) - series - white V 9.6 10.2 Forward voltage (@ 150 mA) - parallel - blue V 3.0 Forward voltage (@ 50 mA) - series - blue V 8.9 Forward voltage (@ 150 mA) - parallel - green V 2.8 Forward voltage (@ 50 mA) - series - green V 8.5 Forward voltage (@ 150 mA) - parallel - amber, red V 2.4 Forward voltage (@ 37.5 mA) - series - amber, red V 9.6 LED junction temperature °C 150 Note: ◊ Thermal resistance measurement was performed per the JEDEC JESD51-14 standard. See the Thermal Resistance Measurement application note for more details. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 4 XLAMP ® ML-E LED FLUX CHARACTERISTICS - PARALLEL WHITE (TJ = 25 °C) The following table provides order codes for XLamp ML-E LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 40). Chromaticity Kit CCT DT 7000 K E0 51 E1 50 DV E2 DY DZ 7000 K 6500 K 6500 K 6200 K 6000 K 5750 K 5500 K 5000 K Minimum Luminous Flux (lm) @ 150 mA Calculated Minimum Luminous Flux (lm)* Order Codes Code Flux 350 mA 500 mA 75 CRI Typical N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005DT N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004DT M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003DT N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005E0 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E0 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E0 N3 56.8 114.1 146.0 MLEAWT-A1-0000-000551 N2 51.7 104.8 132.9 MLEAWT-A1-0000-000451 M3 45.7 92.6 117.4 MLEAWT-A1-0000-000351 N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005E1 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E1 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E1 N3 56.8 114.1 146.0 MLEAWT-A1-0000-000550 MLEAWT-A1-0000-000450 N2 51.7 104.8 132.9 M3 45.7 92.6 117.4 MLEAWT-A1-0000-000350 N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005DV N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004DV M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003DV N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005E2 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E2 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E2 N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005DY N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004DY M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003DY N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005DZ N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004DZ M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003DZ 80 CRI Minimum Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 5 XLAMP ® ML-E LED FLUX CHARACTERISTICS - PARALLEL WHITE (TJ = 25 °C) - CONTINUED Chromaticity Kit E3 F4 E4 Chromaticity Kit CCT F5 4250 K E5 4000 K Z5 4000 K F6 3750 K Minimum Luminous Flux (lm) @ 150 mA CCT 5000 K 4750 K 4500 K Minimum Luminous Flux (lm) @ 150 mA Calculated Minimum Luminous Flux (lm)* Order Codes Code Flux 350 mA 500 mA 75 CRI Typical N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005E3 80 CRI Minimum N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E3 MLEAWT-H1-0000-0004E3 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E3 MLEAWT-H1-0000-0003E3 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002E3 MLEAWT-H1-0000-0002E3 N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005F4 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004F4 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003F4 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002F4 N3 56.8 114.1 146.0 MLEAWT-A1-0000-0005E4 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E4 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E4 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002E4 Calculated Minimum Luminous Flux (lm)* Order Codes Code Flux 350 mA 500 mA 80 CRI Typical N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004F5 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003F5 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002F5 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004E5 M3 45.7 92.6 117.4 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 N2 51.7 104.8 132.9 MLEAWT-A1-0000-0004Z5 M3 45.7 92.6 117.4 M2 39.8 80.7 102.3 80 CRI Minimum 85 CRI Minimum MLEAWT-A1-0000-0003E5 MLEAWT-H1-0000-0003E5 MLEAWT-P1-0000-0003E5 MLEAWT-A1-0000-0002E5 MLEAWT-H1-0000-0002E5 MLEAWT-P1-0000-0002E5 MLEAWT-U1-0000-0002E5 MLEAWT-H1-0000-0001E5 MLEAWT-P1-0000-0001E5 MLEAWT-U1-0000-0001E5 MLEAWT-A1-0000-0003Z5 MLEAWT-H1-0000-0003Z5 MLEAWT-P1-0000-0003Z5 MLEAWT-A1-0000-0002Z5 MLEAWT-H1-0000-0002Z5 MLEAWT-P1-0000-0002Z5 MLEAWT-U1-0000-0002Z5 MLEAWT-H1-0000-0001Z5 MLEAWT-P1-0000-0001Z5 MLEAWT-U1-0000-0001Z5 MLEAWT-H1-0000-0002F6 MLEAWT-P1-0000-0002F6 MLEAWT-U1-0000-0002F6 MLEAWT-H1-0000-0001F6 MLEAWT-P1-0000-0001F6 MLEAWT-U1-0000-0001F6 K3 35.2 71.4 90.5 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003F6 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002F6 K3 35.2 71.4 90.5 90 CRI Minimum Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 6 XLAMP ® ML-E LED FLUX CHARACTERISTICS - PARALLEL WHITE (TJ = 25 °C) - CONTINUED Chromaticity Kit CCT E6 3500 K Z6 3500 K F7 3250 K E7 3000 K Z7 3000 K F8 2850 K E8 2700 K Z8 2700 K Minimum Luminous Flux (lm) @ 150 mA Calculated Minimum Luminous Flux (lm)* Order Codes Code Flux 350 mA 500 mA 80 CRI Typical M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E6 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002E6 K3 35.2 71.4 90.5 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003Z6 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002Z6 K3 35.2 71.4 90.5 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003F7 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002F7 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003E7 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002E7 K3 35.2 71.4 90.5 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum MLEAWT-H1-0000-0002E6 MLEAWT-P1-0000-0002E6 MLEAWT-U1-0000-0002E6 MLEAWT-H1-0000-0001E6 MLEAWT-P1-0000-0001E6 MLEAWT-U1-0000-0001E6 MLEAWT-H1-0000-0002Z6 MLEAWT-P1-0000-0002Z6 MLEAWT-U1-0000-0002Z6 MLEAWT-H1-0000-0001Z6 MLEAWT-P1-0000-0001Z6 MLEAWT-U1-0000-0001Z6 MLEAWT-H1-0000-0002F7 MLEAWT-P1-0000-0002F7 MLEAWT-U1-0000-0002F7 MLEAWT-H1-0000-0001F7 MLEAWT-P1-0000-0001F7 MLEAWT-U1-0000-0001F7 MLEAWT-H1-0000-0000F7 MLEAWT-P1-0000-0000F7 MLEAWT-U1-0000-0000F7 MLEAWT-H1-0000-0002E7 MLEAWT-P1-0000-0002E7 MLEAWT-U1-0000-0002E7 MLEAWT-H1-0000-0001E7 MLEAWT-P1-0000-0001E7 MLEAWT-U1-0000-0001E7 MLEAWT-H1-0000-0000E7 MLEAWT-P1-0000-0000E7 MLEAWT-U1-0000-0000E7 K2 30.6 62.0 78.6 M3 45.7 92.6 117.4 MLEAWT-A1-0000-0003Z7 M2 39.8 80.7 102.3 MLEAWT-A1-0000-0002Z7 MLEAWT-H1-0000-0002Z7 MLEAWT-P1-0000-0002Z7 MLEAWT-U1-0000-0002Z7 K3 35.2 71.4 90.5 MLEAWT-H1-0000-0001Z7 MLEAWT-P1-0000-0001Z7 MLEAWT-U1-0000-0001Z7 K2 30.6 62.0 78.6 MLEAWT-H1-0000-0000Z7 MLEAWT-P1-0000-0000Z7 MLEAWT-U1-0000-0000Z7 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 MLEAWT-H1-0000-0001F8 MLEAWT-P1-0000-0001F8 MLEAWT-U1-0000-0001F8 K2 30.6 62.0 78.6 MLEAWT-H1-0000-0000F8 MLEAWT-P1-0000-0000F8 MLEAWT-U1-0000-0000F8 M3 45.7 92.6 117.4 MLEAWT-H1-0000-0003E8 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 MLEAWT-H1-0000-0001E8 MLEAWT-P1-0000-0001E8 MLEAWT-U1-0000-0001E8 K2 30.6 62.0 78.6 MLEAWT-H1-0000-0000E8 MLEAWT-P1-0000-0000E8 MLEAWT-U1-0000-0000E8 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 MLEAWT-H1-0000-0001Z8 MLEAWT-P1-0000-0001Z8 MLEAWT-U1-0000-0001Z8 K2 30.6 62.0 78.6 MLEAWT-H1-0000-0000Z8 MLEAWT-P1-0000-0000Z8 MLEAWT-U1-0000-0000Z8 MLEAWT-A1-0000-0002F8 MLEAWT-A1-0000-0002E8 MLEAWT-H1-0000-0002F8 MLEAWT-H1-0000-0002E8 MLEAWT-A1-0000-0002Z8 Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 7 XLAMP ® ML-E LED FLUX CHARACTERISTICS - SERIES WHITE (TJ = 25 °C) The following table provides order codes for XLamp ML-E LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 40). Chromaticity Kit CCT DT 7000 K E0 7000 K 51 6500 K E1 6500 K 50 6200 K DV 6000 K E2 5750 K DY 5500 K DZ 5000 K E3 5000 K F4 E4 4750 K 4500 K Minimum Luminous Flux (lm) @ 50 mA Calculated Minimum Luminous Flux (lm)* Code Flux 117 mA Order Codes 166 mA 75 CRI Typical N2 51.7 104.8 132.9 MLESWT-A1-0000-0004DT M3 45.7 92.6 117.4 MLESWT-A1-0000-0003DT N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E0 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E0 N2 51.7 104.8 132.9 MLESWT-A1-0000-000451 M3 45.7 92.6 117.4 MLESWT-A1-0000-000351 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E1 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E1 N2 51.7 104.8 132.9 MLESWT-A1-0000-000450 M3 45.7 92.6 117.4 MLESWT-A1-0000-000350 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004DV M3 45.7 92.6 117.4 MLESWT-A1-0000-0003DV N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E2 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E2 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004DY M3 45.7 92.6 117.4 MLESWT-A1-0000-0003DY N2 51.7 104.8 132.9 MLESWT-A1-0000-0004DZ M3 45.7 92.6 117.4 MLESWT-A1-0000-0003DZ 80 CRI Minimum N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E3 MLESWT-H1-0000-0004E3 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E3 MLESWT-H1-0000-0003E3 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002E3 MLESWT-H1-0000-0002E3 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004F4 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003F4 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002F4 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E4 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E4 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002E4 Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 8 XLAMP ® ML-E LED FLUX CHARACTERISTICS - SERIES WHITE (TJ = 25 °C) - CONTINUED Chromaticity Minimum Luminous Flux (lm) @ 50 mA Calculated Minimum Luminous Flux (lm)* Order Codes Kit CCT Code Flux 117 mA 166 mA 80 CRI Typical N2 51.7 104.8 132.9 MLESWT-A1-0000-0004F5 F5 4250 K M3 45.7 92.6 117.4 MLESWT-A1-0000-0003F5 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002F5 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004E5 M3 45.7 92.6 117.4 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 E5 4000 K Z5 4000 K F6 3750 K E6 3500 K Z6 3500 K F7 3250 K E7 3000 K Z7 3000 K 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum MLESWT-A1-0000-0003E5 MLESWT-H1-0000-0003E5 MLESWT-P1-0000-0003E5 MLESWT-A1-0000-0002E5 MLESWT-H1-0000-0002E5 MLESWT-P1-0000-0002E5 MLESWT-U1-0000-0002E5 MLESWT-H1-0000-0001E5 MLESWT-P1-0000-0001E5 MLESWT-U1-0000-0001E5 N2 51.7 104.8 132.9 MLESWT-A1-0000-0004Z5 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003Z5 MLESWT-H1-0000-0003Z5 MLESWT-P1-0000-0003Z5 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002Z5 MLESWT-H1-0000-0002Z5 MLESWT-P1-0000-0002Z5 MLESWT-U1-0000-0002Z5 K3 35.2 71.4 90.5 MLESWT-H1-0000-0001Z5 MLESWT-P1-0000-0001Z5 MLESWT-U1-0000-0001Z5 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003F6 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002F6 MLESWT-H1-0000-0002F6 MLESWT-P1-0000-0002F6 MLESWT-U1-0000-0002F6 K3 35.2 71.4 90.5 MLESWT-H1-0000-0001F6 MLESWT-P1-0000-0001F6 MLESWT-U1-0000-0001F6 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E6 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002E6 MLESWT-H1-0000-0002E6 MLESWT-P1-0000-0002E6 MLESWT-U1-0000-0002E6 K3 35.2 71.4 90.5 MLESWT-H1-0000-0001E6 MLESWT-P1-0000-0001E6 MLESWT-U1-0000-0001E6 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003Z6 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002Z6 MLESWT-H1-0000-0002Z6 MLESWT-P1-0000-0002Z6 MLESWT-U1-0000-0002Z6 MLESWT-H1-0000-0001Z6 MLESWT-P1-0000-0001Z6 MLESWT-U1-0000-0001Z6 MLESWT-H1-0000-0002F7 MLESWT-P1-0000-0002F7 MLESWT-U1-0000-0002F7 MLESWT-H1-0000-0001F7 MLESWT-P1-0000-0001F7 MLESWT-U1-0000-0001F7 MLESWT-P1-0000-0000F7 MLESWT-U1-0000-0000F7 MLESWT-H1-0000-0002E7 MLESWT-P1-0000-0002E7 MLESWT-U1-0000-0002E7 MLESWT-H1-0000-0001E7 MLESWT-P1-0000-0001E7 MLESWT-U1-0000-0001E7 MLESWT-P1-0000-0000E7 MLESWT-U1-0000-0000E7 MLESWT-H1-0000-0002Z7 MLESWT-P1-0000-0002Z7 MLESWT-U1-0000-0002Z7 MLESWT-H1-0000-0001Z7 MLESWT-P1-0000-0001Z7 MLESWT-U1-0000-0001Z7 MLESWT-P1-0000-0000Z7 MLESWT-U1-0000-0000Z7 K3 35.2 71.4 90.5 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003F7 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002F7 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003E7 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002E7 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 M3 45.7 92.6 117.4 MLESWT-A1-0000-0003Z7 M2 39.8 80.7 102.3 MLESWT-A1-0000-0002Z7 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 9 XLAMP ® ML-E LED FLUX CHARACTERISTICS - SERIES WHITE (TJ = 25 °C) - CONTINUED Chromaticity Kit CCT F8 2850 K E8 2700 K Z8 2700 K Minimum Luminous Flux (lm) @ 50 mA Calculated Minimum Luminous Flux (lm)* Order Codes Code Flux 117 mA 166 mA 80 CRI Typical M2 39.8 80.7 102.3 MLESWT-A1-0000-0002F8 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 M2 39.8 80.7 102.3 K3 35.2 71.4 90.5 K2 30.6 62.0 78.6 80 CRI Minimum 85 CRI Minimum 90 CRI Minimum MLESWT-H1-0000-0001F8 MLESWT-P1-0000-0001F8 MLESWT-U1-0000-0001F8 MLESWT-P1-0000-0000F8 MLESWT-U1-0000-0000F8 MLESWT-P1-0000-0001E8 MLESWT-U1-0000-0001E8 MLESWT-P1-0000-0000E8 MLESWT-U1-0000-0000E8 MLESWT-P1-0000-0001Z8 MLESWT-U1-0000-0001Z8 MLESWT-P1-0000-0000Z8 MLESWT-U1-0000-0000Z8 MLESWT-A1-0000-0002E8 MLESWT-H1-0000-0001E8 MLESWT-A1-0000-0002Z8 MLESWT-H1-0000-0001Z8 Notes: • • • • • * Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. Minimum CRI for 80-CRI White is 80. Minimum CRI for 85-CRI White is 85. Minimum CRI for 90-CRI White is 90 Calculated flux values are for reference only. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 10 XLAMP ® ML-E LED FLUX CHARACTERISTICS - PARALLEL COLOR (TJ = 25 °C) The following table provides order codes for XLamp ML-E color LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 40). Royal Blue Kit Dominant Wavelengh (nm) 01 450 - 465 02 450 - 460 03 455 - 465 04 450-455 05 455-460 06 460-465 Blue Kit Dominant Wavelengh (nm) 01 465 - 485 02 465 - 480 05 470 - 480 Minimum Radiant Flux (lm) @ 150 mA Order Codes Code Flux (mW) 10 175 MLEROY-A1-0000-000501 9 147 MLEROY-A1-0000-000401 10 175 MLEROY-A1-0000-000502 9 147 MLEROY-A1-0000-000402 10 175 MLEROY-A1-0000-000503 9 147 MLEROY-A1-0000-000403 10 175 MLEROY-A1-0000-000504 9 147 MLEROY-A1-0000-000404 10 175 MLEROY-A1-0000-000505 9 147 MLEROY-A1-0000-000405 10 175 MLEROY-A1-0000-000506 9 147 MLEROY-A1-0000-000406 Minimum Luminous Flux (lm) @ 150 mA Order Codes Code Flux (lm) G2 13.9 MLEBLU-A1-0000-000U01 F2 10.7 MLEBLU-A1-0000-000T01 G2 13.9 MLEBLU-A1-0000-000U02 F2 10.7 MLEBLU-A1-0000-000T02 G2 13.9 MLEBLU-A1-0000-000U05 F2 10.7 MLEBLU-A1-0000-000T05 Note: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements and ±1 nm on dominant wavelength measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 11 XLAMP ® ML-E LED FLUX CHARACTERISTICS - PARALLEL COLOR (TJ = 25 °C) - CONTINUED Green Kit Dominant Wavelengh (nm) 01 520 - 535 02 03 520 - 530 525 - 535 Amber Kit Dominant Wavelengh (nm) 01 585 - 595 Red Kit Dominant Wavelengh (nm) 01 620 - 630 02 620 - 625 03 625 - 630 Minimum Luminous Flux (lm) @ 150 mA Order Codes Code Flux (lm) K3 35.2 MLEGRN-A1-0000-000101 K2 30.6 MLEGRN-A1-0000-000001 J3 26.8 MLEGRN-A1-0000-000X01 K3 35.2 MLEGRN-A1-0000-000102 K2 30.6 MLEGRN-A1-0000-000002 J3 26.8 MLEGRN-A1-0000-000X02 K3 35.2 MLEGRN-A1-0000-000103 K2 30.6 MLEGRN-A1-0000-000003 J3 26.8 MLEGRN-A1-0000-000X03 Minimum Luminous Flux (lm) @ 150 mA Order Codes Code Flux (lm) J3 26.8 MLEAMB-A1-0000-000X01 J2 23.5 MLEAMB-A1-0000-000W01 Minimum Luminous Flux (lm) @ 150 mA Code Flux (lm) Order Codes J2 23.5 H2 18.1 MLERED-A1-0000-000W01 MLERED-A1-0000-000V01 J2 23.5 MLERED-A1-0000-000W02 H2 18.1 MLERED-A1-0000-000V02 J2 23.5 MLERED-A1-0000-000W03 H2 18.1 MLERED-A1-0000-000V03 Note: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements and ±1 nm on dominant wavelength measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 12 XLAMP ® ML-E LED FLUX CHARACTERISTICS - SERIES COLOR (TJ = 25 °C) The following table provides order codes for XLamp ML-E color LEDs. For a complete description of the order‑code nomenclature, please consult the Bin and Order Code Formats section (page 40). Blue Kit Dominant Wavelengh (nm) 01 465 - 485 02 465 - 480 05 470 - 480 Green Kit Dominant Wavelengh (nm) 01 520 - 535 02 03 520 - 530 525 - 535 Amber Kit Dominant Wavelengh (nm) 01 585 - 595 Minimum Luminous Flux (lm) @ 50 mA Order Codes Code Flux (lm) G2 13.9 MLESBL-A1-0000-000U01 F2 10.7 MLESBL-A1-0000-000T01 G2 13.9 MLESBL-A1-0000-000U02 F2 10.7 MLESBL-A1-0000-000T02 G2 13.9 MLESBL-A1-0000-000U05 F2 10.7 MLESBL-A1-0000-000T05 Minimum Luminous Flux (lm) @ 50 mA Order Codes Code Flux (lm) K3 35.2 K2 30.6 MLESGN-A1-0000-000001 J3 26.8 MLESGN-A1-0000-000X01 K3 35.2 MLESGN-A1-0000-000102 K2 30.6 MLESGN-A1-0000-000002 J3 26.8 MLESGN-A1-0000-000X02 K3 35.2 MLESGN-A1-0000-000103 K2 30.6 MLESGN-A1-0000-000003 J3 26.8 MLESGN-A1-0000-000X03 Minimum Luminous Flux (lm) @ 37.5 mA MLESGN-A1-0000-000101 Order Codes Code Flux (lm) J3 26.8 MLESAM-A1-0000-000X01 J2 23.5 MLESAM-A1-0000-000W01 Note: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements and ±1 nm on dominant wavelength measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 13 XLAMP ® ML-E LED FLUX CHARACTERISTICS - SERIES COLOR (TJ = 25 °C) - CONTINUED Red Kit Dominant Wavelengh (nm) 01 620 - 630 02 620 - 625 03 625-630 Minimum Luminous Flux (lm) @ 37.5 mA Code Flux (lm) Order Codes J2 23.5 MLESRD-A1-0000-000W01 H2 18.1 MLESRD-A1-0000-000V01 MLESRD-A1-0000-000W02 J2 23.5 H2 18.1 MLESRD-A1-0000-000V02 J2 23.5 MLESRD-A1-0000-000W03 H2 18.1 MLESRD-A1-0000-000V03 Note: • • Cree LED maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and ±2 on CRI measurements and ±1 nm on dominant wavelength measurements. See the Measurements section (page 42). XLamp ML-E LED order codes specify only a minimum flux bin and not a maximum. Cree LED may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity or DWL bin restrictions specified by the order code. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 14 XLAMP ® ML-E LED Relative Spectral Power ML-E - OK RELATIVE SPECTRAL POWER DISTRIBUTION - WHITE Relative Radiant Power (%) 100 80 5000 K - 8300 K CCT 60 3500 K - 5000 K CCT 40 2600 K - 3500 K CCT 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) Relative Spectral Power - Color RELATIVE SPECTRAL POWER DISTRIBUTION - COLOR Relative Radiant Power (%) 100 80 Royal Blue 60 Blue Green 40 Amber Red 20 0 380 430 480 530 580 630 680 730 780 Wavelength (nm) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 15 XLAMP ® ML-E LED RELATIVE LUMINOUS FLUX VS. JUNCTION TEMPERATURE - WHITE (PARALLEL: IF = 150 mA, SERIES: IF = 50 mA) Relative Luminous Flux (%) 120 100 80 60 40 20 0 25 50 75 100 125 150 Junction Temperature (ºC)- RBG Relative Flux Output vs. Junction Temperature blue, green from: DataSheet_MLE Color_Final_AddSR370.xls RELATIVE LUMINOUS FLUX VS. JUNCTION TEMPERATURE - PARALLEL: BLUE, GREEN, AMBER, RED (IF = 150 mA), SERIES: BLUE, GREEN (IF = 50 mA), AMBER, RED (IF = 37.5 mA) Relative Luminous Flux (%) 120 100 80 Blue Green 60 Amber Red 40 20 0 25 50 75 100 125 150 Junction Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 16 XLAMP ® ML-E LED Relative Flux Output vs. Junction Temperature - Royal Blue RELATIVE RADIANT FLUX VS. JUNCTION TEMPERATURE - PARALLEL ROYAL BLUE (IF = 150 mA) Relative Radiant Flux (%) 120 100 80 Royal Blue 60 40 20 0 25 50 75 100 125 150 Junction Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 17 XLAMP ® ML-E LED PARALLEL ELECTRICAL CHARACTERISTICS - PARALLEL WHITE (TJ = 25 °C) 500 450 Forward Current (mA) 400 350 300 250 200 150 100 50 0 2.50 2.75 3.00 3.25 3.50 3.75 4.00 Forward Voltage (V) SERIES ELECTRICAL CHARACTERISTICS - SERIES WHITE (TJ = 25 °C) 175 Forward Current (mA) 150 125 100 75 50 25 0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 Forward Voltage (V) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 18 XLAMP ® ML-E LED ELECTRICALElectrical CHARACTERISTICS - PARALLEL (TJ = 25 °C) Characteristics (Tj COLOR = 25ºC) - Parallel Color blue, green from: DataSheet_MLE Color_Final_AddSR370.xls 350 Forward Current (mA) 300 250 Royal Blue Blue 200 Green 150 Amber Red 100 50 0 2 2.25 2.5 2.75 3 3.25 3.5 3.75 4 Forward Voltage (V) Electrical Characteristics (Tj = 25ºC) - Series Color ELECTRICAL CHARACTERISTICS - SERIES COLOR (TJ = 25 °C) blue, green from: DataSheet_MLE Color_Final_AddSR370.xls 120 Forward Current (mA) 100 80 Blue Green 60 Amber Red 40 20 0 8 8.5 9 9.5 10 10.5 11 11.5 12 Forward Voltage (V) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 19 XLAMP ® ML-E LED PARALLEL RELATIVE LUMINOUS FLUX VS. CURRENT - PARALLEL WHITE (TJ = 25 °C) 300 Relative Luminous Flux (%) 250 200 150 100 50 0 0 50 100 150 200 250 300 350 400 450 500 160 180 200 Forward Current (mA) SERIES RELATIVE LUMINOUS FLUX VS. CURRENT - SERIES WHITE (TJ = 25 °C) 300 Relative Luminous Flux (%) 250 200 150 100 50 0 0 20 40 60 80 100 120 140 Forward Current (mA) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 20 XLAMP ® ML-E LED Relative Intensity vs. Current (Tj = 25ºC) - parallel RGB blue, green from: DataSheet_MLE Color_Final_AddSR370.xls RELATIVE LUMINOUS FLUX VS. CURRENT - PARALLEL BLUE, GREEN, AMBER, RED (TJ = 25 °C) 225 Relative Luminous Flux (%) 200 175 150 Blue 125 Green 100 Amber Red 75 50 25 0 0 50 100 150 200 250 300 350 Forward Current (mA) Relative Intensity vs. Current (Tj = 25ºC) - series RGB blue, green from: DataSheet_MLE Color_Final_AddSR370.xls RELATIVE LUMINOUS FLUX VS. CURRENT - SERIES BLUE, GREEN, AMBER, RED (TJ = 25 °C) 225 Relative Luminous Flux (%) 200 175 150 Blue 125 Green 100 Amber Red 75 50 25 0 0 20 40 60 80 100 120 Forward Current (mA) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 21 XLAMP ® ML-E LED Relative Intensity vs. Current (Tj = 25ºC) - parallel Royal Blue RELATIVE RADIANT FLUX VS. CURRENT - PARALLEL ROYAL BLUE (TJ = 25 °C) 225 200 Relative Radiant Flux (%) 175 150 125 Royal Blue 100 75 50 25 0 0 50 100 150 200 250 300 350 Forward Current (mA) Typical Spatial Radiation Pattern TYPICAL SPATIAL DISTRIBUTION - WHITE Relative Luminous Intensity (%) 100 80 60 40 20 -90 -70 -50 -30 -10 0 10 30 50 70 90 Angle (º) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 22 XLAMP ® ML-E LED Typical Spatial Distribution (Tj = 25ºC) - blue, royal blue, green TYPICAL SPATIAL DISTRIBUTION - ROYAL BLUE, BLUE, GREEN Relative Luminous Intensity (%) 100 80 60 40 20 -90 -70 -50 -30 -10 0 10 30 50 70 90 30 50 70 90 Angle (º) Typical Spatial Distribution (Tj = 25ºC) - red, amber TYPICAL SPATIAL DISTRIBUTION - AMBER, RED Relative Luminous Intensity (%) 100 80 60 40 20 -90 -70 -50 -30 -10 0 10 Angle (º) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 23 XLAMP ® ML-E LED THERMAL DESIGN - PARALLEL WHITE The maximum forward current is determined by the thermal resistance between the LED junction and ambient. It is crucial for the end product to be designedPARALLEL in a manner that minimizes the thermal resistance from the solder point to ambient in order to optimize lamp life and optical characteristics. 600 Maximum Current (mA) 500 400 300 200 Rj-a = 20°C/W Rj-a = 30°C/W 100 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) THERMAL DESIGN -SERIES SERIES WHITE 200 180 160 Maximum Current (mA) 140 120 100 80 60 Rj-a = 20°C/W 40 Rj-a = 30°C/W Rj-a = 40°C/W 20 Rj-a = 50°C/W 0 0 20 40 60 80 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 24 XLAMP ® ML-E LED Thermal Design - Parallel Royal Blue THERMAL DESIGN - PARALLEL ROYAL BLUE 400 350 Maximum Current (mA) 300 250 200 150 100 Rj-a = 20°C/W Rj-a = 30°C/W 50 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) THERMAL DESIGN - PARALLEL Thermal Design - ParallelBLUE Blue 400 350 Maximum Current (mA) 300 250 200 150 100 Rj-a = 20°C/W Rj-a = 30°C/W 50 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 25 XLAMP ® ML-E LED Thermal Design - Series Blue THERMAL DESIGN - SERIES BLUE 140 120 Maximum Current (mA) 100 80 60 40 Rj-a = 20°C/W Rj-a = 30°C/W 20 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) THERMAL DESIGN - PARALLEL GREEN Thermal Design - Parallel Green 400 350 Maximum Current (mA) 300 250 200 150 100 Rj-a = 20°C/W Rj-a = 30°C/W 50 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 26 XLAMP ® ML-E LED THERMAL DESIGN - SERIES GREEN Thermal Design - Series Green 140 120 Maximum Current (mA) 100 80 60 40 Rj-a = 20°C/W Rj-a = 30°C/W 20 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 120 140 160 Ambient Temperature (ºC) THERMAL DESIGN - PARALLEL AMBER Thermal Design - Parallel Amber 300 Maximum Current (mA) 250 200 150 100 Rj-a = 25°C/W Rj-a = 35°C/W 50 Rj-a = 45°C/W Rj-a = 55°C/W 0 0 20 40 60 80 100 160 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 27 XLAMP ® ML-E LED THERMAL DESIGN - SERIES AMBER Thermal Design - Series Amber 70 Maximum Current (mA) 60 50 40 30 20 Rj-a = 25°C/W Rj-a = 35°C/W 10 Rj-a = 45°C/W Rj-a = 55°C/W 0 0 20 40 60 80 100 120 140 160 100 120 140 160 Ambient Temperature (ºC) Thermal Design - Parallel Red THERMAL DESIGN - PARALLEL RED 400 350 Maximum Current (mA) 300 250 200 150 100 Rj-a = 20°C/W Rj-a = 30°C/W 50 Rj-a = 40°C/W Rj-a = 50°C/W 0 0 20 40 60 80 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 28 XLAMP ® ML-E LED Thermal Design - Series Red THERMAL DESIGN - SERIES RED 100 90 Maximum Current (mA) 80 70 60 50 40 30 Rj-a = 20°C/W 20 Rj-a = 30°C/W Rj-a = 40°C/W 10 Rj-a = 50°C/W 0 0 20 40 60 80 100 120 140 160 Ambient Temperature (ºC) © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 29 XLAMP ® ML-E LED PERFORMANCE GROUPS – LUMINOUS OR RADIANT FLUX White and color ML-E LEDs (except for royal-blue) are tested for luminous flux and placed into one of the following luminous-flux groups: Group Code Minimum Luminous Flux (lm) Maximum Luminous Flux (lm) F2 10.7 12.3 F3 12.3 13.9 G2 13.9 15.8 G3 15.8 18.1 H2 18.1 20.6 H3 20.6 23.5 J2 23.5 26.8 J3 26.8 30.6 K2 30.6 35.2 K3 35.2 39.8 M2 39.8 45.7 M3 45.7 51.7 N2 51.7 56.8 N3 56.8 62 N4 62 67.2 P2 67.2 73.9 P3 73.9 80.6 Royal-blue ML-E LEDs are tested for radiant flux and sorted into one of the following radiant-flux bins. Group Minimum Radiant Flux (mW) Maximum Radiant Flux (mW) 09 147 175 10 175 210 11 210 250 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 30 XLAMP ® ML-E LED PERFORMANCE GROUPS – DOMINANT WAVELENGTH ML-E color LEDs are tested individually for dominant wavelength (DWL) and sorted into one of the DWL bins defined below. Color Royal Blue Blue Green Amber Red DWL Group Minimum DWL (nm) Maximum DWL (nm) D36 450 452.5 D37 452.5 455 D46 455 457.5 D47 457.5 460 D56 460 462.5 D57 462.5 465 B3 465 470 B4 470 475 B5 475 480 B6 480 485 G2 520 525 G3 525 530 G4 530 535 A2 585 590 A3 590 595 R2 620 625 R3 625 630 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 31 XLAMP ® ML-E LED PERFORMANCE GROUPS – CHROMATICITY Region 0A 0R 1A 1R 2A 2R 3A 3R 4A x y 0.2950 0.2970 0.2920 0.3060 0.2984 0.3133 0.3009 Region x y 0.2920 0.3060 x y 0.2984 0.3133 0.2895 0.3135 0.2962 0.3220 0.2962 0.3220 0.3028 0.3304 0.3042 0.2984 0.3133 0.3048 0.3207 0.2980 0.2880 0.2950 0.2970 0.2895 0.3135 0.2962 0.2870 0.3210 0.2937 0.3009 0.3042 0.3037 0.2937 0.2937 0.3312 0.3005 0.3415 0.2962 0.3220 0.3028 0.3304 0.3048 0.3130 0.3207 0.3028 0.3304 0.3115 0.3290 0.3115 0.3391 0.3205 0.3144 0.3186 0.3130 0.3290 0.3213 0.3373 0.3068 0.3068 0.3113 0.3048 0.3207 0.3130 0.3113 0.3005 0.3415 0.3099 0.3144 0.3186 0.3161 0.3059 0.3099 0.3509 0.3196 0.3602 0.3115 0.3391 0.3205 0.3481 0.3093 0.2993 0.3028 0.3304 0.3115 0.3391 0.3215 0.3350 0.3207 0.3462 0.3290 0.3290 0.3417 0.3290 0.3538 0.3376 0.3290 0.3300 0.3290 0.3417 0.3371 0.3490 0.3222 0.3243 0.3215 0.3350 0.3290 0.3417 0.3222 0.3243 0.3196 0.3602 0.3290 0.3690 0.3290 0.3300 0.3290 0.3690 0.3381 0.3762 0.3290 0.3180 0.3290 0.3538 0.3376 0.3616 0.3231 0.3120 0.3207 0.3462 0.3290 0.3371 0.3490 0.3376 0.3616 0.3463 0.3451 0.3554 0.3463 0.3687 0.3551 0.3760 0.3440 0.3427 0.3451 0.3554 0.3533 0.3620 0.3366 0.3369 0.3371 0.3490 0.3451 0.3554 0.3366 0.3369 0.3381 0.3762 0.3480 0.3440 0.3428 0.3480 0.3840 0.3571 0.3429 0.3307 0.3463 0.3687 0.3551 0.3760 0.3361 0.3245 0.3376 0.3616 0.3463 0.3530 0.3597 0.3548 0.3736 0.3641 0.3615 0.3659 0.3641 0.3804 0.3736 0.3874 0.3590 0.3521 0.3615 0.3659 0.3702 0.3722 0.3512 0.3465 0.3530 0.3597 0.3615 0.3659 0B 0S 1B 1S 2B 2S 3B 3S 4B Region 0C 0T 1C 1T 2C 2T 3C 3T 4C x y 0.2984 0.3133 0.3048 0.3207 0.3068 0.3113 0.3009 0.3042 0.3220 0.3037 0.2937 0.3312 0.3009 0.3042 0.3068 0.3113 0.3093 0.2993 0.3391 0.3130 0.3290 0.3481 0.3213 0.3373 0.3221 0.3261 0.3290 0.3144 0.3186 0.3509 0.3144 0.3186 0.3221 0.3261 0.3231 0.3120 0.3161 0.3059 0.3538 0.3290 0.3417 0.3616 0.3371 0.3490 0.3366 0.3369 0.3290 0.3300 0.3290 0.3300 0.3366 0.3369 0.3361 0.3245 0.3538 0.3290 0.3180 0.3687 0.3451 0.3554 0.3533 0.3620 0.3515 0.3487 0.3440 0.3427 0.3840 0.3440 0.3428 0.3907 0.3515 0.3487 0.3495 0.3339 0.3687 0.3429 0.3307 0.3804 0.3615 0.3659 0.3702 0.3722 0.3670 0.3578 0.3590 0.3521 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 0D 0U 1D 1U 2D 2U 3D 3U 4D CLD-DS30 REV 16 32 XLAMP ® ML-E LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 4R 5A1 5B1 5C1 5D1 6A1 6B1 6C1 6D1 7A1 x y 0.3512 0.3465 0.3590 0.3521 0.3567 0.3389 0.3495 0.3339 0.3670 0.3686 0.3744 0.3685 0.3726 0.3702 0.3719 0.3797 0.3782 0.3837 0.3763 Region x y 0.3571 0.3907 x y 0.3668 0.3957 0.3641 0.3804 0.3548 0.3736 0.3578 0.3686 0.3649 0.3702 0.3649 0.3744 0.3722 0.3763 0.3763 0.3760 0.3825 0.3798 0.3612 0.3744 0.3722 0.3719 0.3685 0.3804 0.3797 0.3782 0.3736 0.3874 0.3802 0.3916 0.3802 0.3916 0.3869 0.3958 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3847 0.3877 0.3847 0.3877 0.3912 0.3869 0.3958 0.3937 0.3912 0.3917 0.3887 0.3836 0.3937 0.4001 0.4006 0.4044 0.3912 0.3917 0.3978 0.3958 0.3783 0.3646 0.3804 0.3721 0.3863 0.3758 0.3804 0.3721 0.3863 0.3758 0.3825 0.3798 0.3887 0.3836 0.3887 0.3836 0.3950 0.3875 0.3840 0.3889 0.3681 0.3863 0.3758 0.3924 0.3690 0.3915 0.3768 0.3981 0.3915 0.3768 0.3941 0.3848 0.4010 0.3882 0.3981 0.3800 0.3953 0.3720 0.4010 0.3882 0.4080 0.3916 0.3981 0.3800 0.4048 0.3832 0.3941 0.3968 0.3848 0.3968 0.3930 0.4040 0.3930 0.3996 0.4015 0.4071 0.4040 0.3966 0.4010 0.3882 0.4071 0.4052 0.4146 0.4089 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4113 0.4001 0.4186 0.4037 0.4113 0.4001 0.4186 0.4037 0.4146 0.4089 0.4222 0.4127 0.4222 0.4127 0.4299 0.4165 0.4150 0.4017 0.3950 0.4186 0.4037 0.4259 0.3751 0.4048 0.3832 0.4116 0.4048 0.3832 0.4080 0.3916 0.4150 0.3950 0.4116 0.3865 0.4082 0.3782 0.4150 0.3950 0.4221 0.3984 0.4116 0.3865 0.4183 0.3898 0.4147 0.4183 0.3814 0.4183 0.3898 0.4242 0.3898 0.4221 0.3984 0.4281 0.4242 0.3919 0.4281 0.4006 0.4342 0.4028 0.4203 0.3833 0.4242 0.3919 0.4300 0.3939 4S 5A2 5B2 5C2 5D2 6A2 6B2 6C2 6D2 7A2 Region 5A3 5B3 5C3 5D3 6A3 6B3 6C3 6D3 7A3 x y 0.3685 0.3726 0.3612 0.3760 0.3744 0.3685 0.3804 0.3721 0.3721 0.3783 0.3646 0.3837 0.3763 0.3760 0.3782 0.3837 0.3847 0.3877 0.3825 0.3798 0.3917 0.3887 0.3836 0.4001 0.3912 0.3917 0.3978 0.3958 0.3950 0.3875 0.3840 0.3681 0.3863 0.3758 0.3924 0.3794 0.3794 0.3898 0.3716 0.3800 0.3953 0.3720 0.3981 0.3800 0.4048 0.3832 0.4017 0.3751 0.3966 0.4010 0.3882 0.4052 0.4040 0.3966 0.4113 0.4001 0.4080 0.3916 0.4150 0.3950 0.4186 0.4037 0.4259 0.4073 0.4073 0.4221 0.3984 0.3865 0.4082 0.3782 0.4116 0.3865 0.4183 0.3898 0.4147 0.3814 0.3919 0.4203 0.3833 0.4006 0.4242 0.3919 0.4300 0.3939 0.4259 0.3853 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 5A4 5B4 5C4 5D4 6A4 6B4 6C4 6D4 7A4 CLD-DS30 REV 16 33 XLAMP ® ML-E LED PERFORMANCE GROUPS – CHROMATICITY (CONTINUED) Region 7B1 7C1 7D1 8A1 8B1 8C1 8D1 x y 0.4221 0.3984 0.4259 0.4073 0.4322 0.4096 0.4281 0.4006 0.4342 0.4385 0.4449 0.4141 0.4403 0.4259 0.4300 0.3939 0.4359 0.3960 0.4316 Region x y 0.4259 0.4073 x y 0.4322 0.4096 0.4299 0.4165 0.4364 0.4188 0.4364 0.4188 0.4322 0.4096 0.4430 0.4212 0.4385 0.4119 0.4028 0.4385 0.4119 0.4430 0.4119 0.4449 0.4212 0.4496 0.4496 0.4236 0.4562 0.4260 0.4049 0.4449 0.3853 0.4300 0.4141 0.4513 0.3939 0.4359 0.4342 0.4028 0.4403 0.4049 0.4403 0.4049 0.4465 0.4071 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.4418 0.3981 0.4418 0.3981 0.4475 0.4465 0.4071 0.4523 0.4475 0.3994 0.4428 0.3906 0.4523 0.4085 0.4582 0.4099 0.4475 0.3994 0.4532 0.4008 0.4465 0.4071 0.4513 0.4164 0.4573 0.4178 0.4513 0.4164 0.4573 0.4178 0.4562 0.4260 0.4624 0.4274 0.4624 0.4274 0.4687 0.4289 0.4523 0.4582 0.4085 0.4573 0.4178 0.4634 0.4099 0.4634 0.4193 0.4695 0.4634 0.4193 0.4687 0.4289 0.4750 0.4304 0.4695 0.4207 0.4641 0.4112 0.4750 0.4304 0.4813 0.4319 0.4695 0.4207 0.4756 0.4221 0.4483 0.4532 0.3919 0.4532 0.4008 0.4589 0.4008 0.4582 0.4099 0.4641 0.4589 0.4021 0.4538 0.3931 0.4641 0.4112 0.4700 0.4126 0.4589 0.4021 0.4646 0.4034 7B2 7C2 7D2 8A2 8B2 8C2 8D2 Region 7B3 7C3 7D3 8A3 8B3 8C3 8D3 x y 0.4281 0.4006 0.4322 0.4096 0.4385 0.4119 0.4342 0.4028 0.4141 0.4403 0.4049 0.4236 0.4449 0.4141 0.4513 0.4164 0.4164 0.4465 0.4071 0.3960 0.4316 0.3873 0.4359 0.3960 0.4418 0.3981 0.4373 0.3893 0.3994 0.4428 0.3906 0.4085 0.4475 0.3994 0.4532 0.4008 0.4483 0.3919 0.4523 0.4085 0.4573 0.4178 0.4634 0.4193 0.4193 0.4582 0.4099 0.4207 0.4641 0.4112 0.4695 0.4207 0.4756 0.4221 0.4700 0.4126 0.4021 0.4538 0.3931 0.4112 0.4589 0.4021 0.4646 0.4034 0.4593 0.3944 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. Region 7B4 7C4 7D4 8A4 8B4 8C4 8D4 CLD-DS30 REV 16 34 XLAMP ® ML-E LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.40 0.40 5000 K 0.39 0.38 0.38 5700 K 6500 K DT 0T 0C 0A ANSI C78.377A 2R 1U 0.31 1R 0R 1R 0U 0.36 0.35 0.34 0.33 0.32 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.30 0.28 0.29 0D ANSI C78.377A 2R 0R 0.29 CCx 0.40 0.40 5000 K 0.39 0.38 DV 6500 K 0.36 0.38 0.36 1T 0S 0.32 0.31 2A 1B 0C 0B 1D 2U 1U 0S 0C 2D 1C 1D 2U ANSI C78.377A 2R 1A 1U 0D 0A 3R 2A 1B 0B 0.31 1R 0U 0.30 0T 0.33 3A 2B 1S 0.32 ANSI C78.377A 2R 1A 0D 0A 8000 K CCy 0T 0.33 3B 2C 1T 0.34 2D 1C 2T 2S 0.35 2B 1S 3S 50 6500 K 2T 2C 8000 K 0.34 5700 K 0.37 2S 0.35 5000 K 0.39 5700 K 0.37 1R 0U 0.30 0R 0R 0.29 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.28 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.30 0.28 0.28 0.29 CCx CCx 0.40 0.42 5000 K E3 0.39 0.38 0.41 E2 0.37 6500 K E1 0.35 8000 K E0 0.34 0T 0S 0.32 0C 0B 0.31 3R 2A 1D 0.30 8000 K 0T 0S 1R 0B 0.31 0.30 0R 0D 0A 1D 1A 4U 4R 3U 3R 2A 1B 0C 3A 2D 1C 4A 3D 2C 2B 1S 4D 3B 2S 0.32 0U 4C 4B 3C 2T 1T 0.33 ANSI C78.377A 2R 1U 0.35 0.34 2U 1A 0D 0A 2D 1C 1B 6500 K 0.36 3A 2B 4T 4S 3T 3S 0.37 3D 2C 1T 1S 0.33 3C 3B 2S DZ 5700 K 0.38 CCy 0.36 5000 K 0.39 3S 2T 4500 K 0.40 5700 K ANSI C78.377A 2U 2R 1U 1R 0U 0R 0.29 0.29 CCx © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. 0.38 0.37 0.36 0.35 0.34 0.32 0.31 0.30 0.29 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 0.28 0.28 0.33 CCy 2U 1U CCx CCy 3R 2A 1D 1A 0A 0.30 0.29 0.28 0C 0B 2D 1C 1B 0S 0.32 0U 0.30 0T 3A 2B 1S 0.33 2U 1A 0D 2C 0.31 0.31 2A 1D 3B 2S 0.30 0B 0.34 2T 1T 8000 K 1C 1B 0S 0.32 2D 2B 1S 0.33 0.35 0.29 8000 K 1T 2C CCy CCy 0.36 2S 3S 51 6500 K 2T 0.36 0.34 5700 K 0.37 0.37 0.35 5000 K 0.39 CCx CLD-DS30 REV 16 35 XLAMP ® ML-E LED STANDARD COOL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS - CONTINUED 0.42 0.41 4500 K 0.40 5000 K 0.39 6500 K 4C 0T 0.33 0S 0.32 0B 0.31 0.30 4U 4R 3U 3R 2A 1D 1A 0D 0A 2D 1C 1B 0C 3A 2B 1S 4A 3D 2C 1T 8000 K 4D 3B 2S 0.34 4B 3C 2T 0.36 CCy 4T 4S 3T 3S 0.37 0.35 DY 5700 K 0.38 ANSI C78.377A 2U 2R 1U 1R 0U 0R 0.29 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.28 CCx © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 36 XLAMP ® ML-E LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 4000 K 0.41 E6 4500 K E5 0.40 CCy E7 3500 K 5000 K 0.39 0.38 5B4 4B 3C 0.36 4D 3B 5B1 5D2 5A3 5D4 6A1 5A2 5D1 5A4 5A1 6D4 6D1 6A4 7A4 7A1 8A1 7D4 7D1 8A3 8A2 7D3 7D2 7A3 7A2 6D3 6D2 6A3 5D3 6A2 6C1 6B4 5C4 6B1 7C1 7B4 7B1 6C4 6B2 5C1 5B2 4C 0.37 5C3 5C2 5B3 E4 6C2 6B3 8C3 8C4 8C1 8B4 8B1 7C4 8C2 8B3 8B2 7C3 7C2 7B3 7B2 6C3 E8 8D3 8D2 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx 0.46 0.45 2700 K 3000 K 0.44 0.43 3500 K 0.42 4000 K 0.41 4500 K CCy 0.40 F5 5000 K 0.39 F4 0.38 0.37 4B 4D 3B 5C4 5C1 5B1 5D2 5A3 5A2 5D1 5A4 5A1 5D4 6A1 6C2 6B3 6B4 6B1 5D3 6A2 5B4 3C 0.36 5B3 6A3 6A4 7B2 6C3 6B2 5C3 5C2 5B2 4C F6 F7 6C1 6D2 6D1 7B1 6C4 6D3 6D4 7A2 7A1 7A4 F8 7A3 7D1 7C2 7B3 7B4 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 ANSI C78.377A 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 37 XLAMP ® ML-E LED STANDARD WARM AND NEUTRAL WHITE KITS PLOTTED ON ANSI STANDARD CHROMATICITY REGIONS CONTINUED 0.46 0.45 2700 K 3000 K 0.44 0.43 0.42 Z6 4000 K 0.41 Z5 4500 K 0.40 CCy Z7 3500 K 6C3 6C2 6B3 6B2 5C3 5000 K 0.39 5C2 5B3 5D3 6A2 5B4 0.38 5B1 4C 0.37 3C 0.36 4D 3B 5D2 5A3 5A2 4B 5A1 5C4 6B1 5C1 5B2 6B4 5D4 6A1 6A3 6A4 6C4 6C1 6D2 6D1 7B1 6D3 6D4 7A2 7A1 7A4 7B4 7A3 7D1 7C2 7B3 7B2 7C1 7D4 8B1 7C4 7D3 7D2 7C3 8A1 8A2 8A3 8B2 Z8 8B3 8B4 8D2 8C1 8C2 8C3 8C4 8D3 8D4 8A4 8D1 5D1 ANSI C78.377A 5A4 4A 3D 0.35 3A 0.34 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.33 CCx © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 38 XLAMP ® ML-E LED STANDARD CHROMATICITY KITS The following table provides the chromaticity bins associated with chromaticity kits for the ML-E LEDs. Color Cool White Warm White CCT Kit Chromaticity Bins 7000 K DT 0A, 0B, 0C,0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U 7000 K E0 0A, 0B, 0C, 0D 6500 K 51 0A, 0B, 0C, 0D, 0R, 0S, 0T, 0U, 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3R, 3S 6500 K E1 1A, 1B, 1C, 1D 6200 K 50 1A, 1B, 1C, 1D, 2A, 2B, 2C, 2D 6000 K DV 1A, 1B, 1C, 1D, 1R, 1S, 1T, 1U, 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U 5700 K E2 2A, 2B, 2C, 2D 5500 K DY 2A, 2B, 2C, 2D, 2R, 2S, 2T, 2U, 3A, 3B, 3C, 3D, 3R, 3S, 3T, 3U 5000 K DZ 2C, 2D, 2T, 2U, 3A, 3B, 3C, 3D, 3R, 3S, 3T, 3U, 4A, 4B, 4R, 4S 5000 K E3 3A, 3B, 3C, 3D 4750 K F4 3C, 3D, 4A, 4B 4500 K E4 4A, 4B, 4C, 4D 4250 K F5 4C, 4D, 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4 4000 K E5 5A1, 5A2, 5A3, 5A4, 5B1, 5B2, 5B3, 5B4, 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4 4000 K Z5 5A3, 5B4, 5C1, 5D2 3750 K F6 5C1, 5C2, 5C3, 5C4, 5D1, 5D2, 5D3, 5D4, 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4 3500 K E6 6A1, 6A2, 6A3, 6A4, 6B1, 6B2, 6B3, 6B4, 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4 3500 K Z6 6A3, 6B4, 6C1, 6D2 3250 K F7 6C1, 6C2, 6C3, 6C4, 6D1, 6D2, 6D3, 6D4, 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4 3000 K E7 7A1, 7A2, 7A3, 7A4, 7B1, 7B2, 7B3, 7B4, 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4 3000 K Z7 7A3, 7B4, 7C1, 7D2 2850 K F8 7C1, 7C2, 7C3, 7C4, 7D1, 7D2, 7D3, 7D4, 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4 2700 K E8 8A1, 8A2, 8A3, 8A4, 8B1, 8B2, 8B3, 8B4, 8C1, 8C2, 8C3, 8C4, 8D1, 8D2, 8D3, 8D4 2700 K Z8 8A3, 8B4, 8C1, 8D2 © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 39 XLAMP ® ML-E LED BIN AND ORDER CODE FORMATS Bin codes and order codes are configured in the following manner: Order Code Bin Code Series MLE = ML-E Series MLE = ML-E CRI Configuration A1 = Typical CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum CRI Configuration A1 = Typical CRI H1 = 80 CRI minimum P1 = 85 CRI minimum U1 = 90 CRI minimum Luminous flux group Luminous Flux SSSCCC-BB-HHHH-NNNFGG SSSCCC-BB-WWW-FF-A-AAAAA Chromaticity Internal code Internal code Chromaticity code Color/Configuration AWT = Parallel White SWT = Series White ROY = Parallel Royal Blue BLU = Parallel Blue SBL = Series Blue GRN = Parallel Green SGR = Series Green AMB = Parallel Amber SAM = Series Amber RED = Parallel Red SRD = Series Red Color/Configuration AWT = Parallel White SWT = Series White ROY = Parallel Royal Blue BLU = Parallel Blue SBL = Series Blue GRN = Parallel Green SGR = Series Green AMB = Parallel Amber SAM = Series Amber RED = Parallel Red SRD = Series Red © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 40 XLAMP ® ML-E LED REFLOW SOLDERING CHARACTERISTICS In testing, Cree LED has found XLamp ML-E LEDs to be compatible with JEDEC J-STD-020C, using the parameters listed below. As a general guideline, Cree LED recommends that users follow the recommended soldering profile provided by the manufacturer of the solder paste used, and therefore it is the lamp or luminaire manufacturer’s responsibility to determine applicable soldering requirements. Note that this general guideline may not apply to all PCB designs and configurations of reflow soldering equipment. tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 t 25˚C to Peak IPC/JEDEC J-STD-020C Time Profile Feature Average Ramp-Up Rate (Tsmax to Tp) Lead-Free Solder 1.2 °C/second Preheat: Temperature Min (Tsmin) 120 °C Preheat: Temperature Max (Tsmax) 170 °C Preheat: Time (tsmin to tsmax) 65-150 seconds Time Maintained Above: Temperature (TL) Time Maintained Above: Time (tL) Peak/Classification Temperature (Tp) 217 °C 45-90 seconds 235 - 245 °C Time Within 5 °C of Actual Peak Temperature (tp) 20-40 seconds Ramp-Down Rate 1 - 6 °C/second Time 25 °C to Peak Temperature 4 minutes max. Note: All temperatures refer to topside of the package, measured on the package body surface. Note: While the high reflow temperatures (above) have been approved, Cree LED’s best practice guideline for reflow is to use as low a temperature as possible during the reflow soldering process for these LEDs. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 41 XLAMP ® ML-E LED NOTES Measurements The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree LED’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended or provided as specifications. Pre‑Release Qualification Testing Please read the LED Reliability Overview for details of the qualification process Cree LED applies to ensure long-term reliability for XLamp LEDs and details of Cree LED’s pre-release qualification testing for XLamp LEDs. Lumen Maintenance Cree LED now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree LED’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. Moisture Sensitivity Cree LED recommends keeping XLamp ML-E LEDs in the provided, resealable moisture-barrier packaging (MBP) until immediately prior to soldering. Unopened MBPs that contain XLamp LEDs do not need special storage for moisture sensitivity. Once the MBP is opened, XLamp ML-E LEDs should be handled and stored as MSL 2a per JEDEC J-STD-033, meaning they have limited exposure time before damage to the LED may occur during the soldering operation. The table on the right specifies the maximum exposure time in days depending on temperature and humidity conditions. LEDs with exposure time longer than the specified maximums must be baked Temp. Maximum Percent Relative Humidity 30% 40% 50% 60% 70% 80% 90% 35 ºC - - - 17 1 .5 .5 30 ºC - - - 28 1 1 1 25 ºC - - - - 2 1 1 20 ºC - - - - 2 1 1 according to the baking conditions listed below. Baking Conditions It is not necessary to bake all XLamp ML-E LEDs. Only the LEDs that meet all of the following criteria must be baked: 1. LEDs that have been removed from the original MBP. 2. LEDs that have been exposed to a humid environment longer than listed in the Moisture Sensitivity section above. 3. LEDs that have not been soldered. © 2010-2023 Cree LED. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp®, and the Cree LED logo are registered trademarks of Cree LED. UL® and the UL logo are registered trademarks of UL LLC. CLD-DS30 REV 16 42 XLAMP ® ML-E LED NOTES - CONTINUED LEDs should be baked at 70 ºC for 24 hours. LEDs may be baked on the original reels. Remove LEDs from the MBP before baking. Do not bake parts at temperatures higher than 70 ºC. This baking operation resets the exposure time as defined in the Moisture Sensitivity section above. Storage Conditions XLamp ML-E LEDs that have been removed from the original MBP but not soldered should be stored in one of the following ways: • Store the parts in a rigid metal container with a tight-fitting lid. Verify that the storage temperature is
MLESWT-A1-0000-0002E7 价格&库存
很抱歉,暂时无法提供与“MLESWT-A1-0000-0002E7”相匹配的价格&库存,您可以联系我们找货
