HCP1104-R45-R
HCP1104-R45-R
    EATON(伊顿)
    450 nH 无屏蔽 鼓芯,绕线式 电感器 30 A 1.4 毫欧最大 非标准
HCP1104-R45-R 数据手册
HCP1104 Series High Current Pressed Power Inductors Description RoHS 2002/95/EC • 125°C maximum total temperature operation • Low profile surface mount inductors • 10mm x 11.5mm x 4.0mm package • Pressed powder iron core material • Enhanced core coating eliminates rusting and provides high insulation impedance • Inductance range from 0.2µH to 0.9µH • Current range from 42.0 Amps to 22 Amps • Frequency range up to 1MHz Applications • Notebook power • VRM, multi-phase buck regulator • DC-DC converters • PC workstations/Servers • Routers Environmental Data • Storage temperature range: -55°C to +125°C • Operating temperature range: -55°C to +125°C (range is application specific) • Solder reflow temperature: +260°C max. for 10 seconds maximum Part Number HCP1104-R20-R HCP1104-R36-R HCP1104-R45-R HCP1104-R56-R HCP1104-R90-R Rated Inductance (µH) 0.20 0.36 0.45 0.56 0.90 Packaging • Supplied in tape and reel packaging, 950 parts per reel OCL (1) µH ± 20% Irms (2) Amperes Isat (3) Amperes 0.20 0.36 0.45 0.56 0.90 32 30 30 25 22 42 40 35 32 25 (1) Open Circuit Inductance Test Parameters: 100kHz, 0.25V, 0.0Adc. (2) Irms: DC current for an approximate ∆T of 40°C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating conditions verified in the end application. DCR mΩ@20°C (Typical) 0.7 1.0 1.25 1.60 2.30 DCR mΩ@20°C (Maximum) 0.9 1.2 1.4 1.8 2.5 K-factor (4) 505 289 334 287 168 (3) Isat Amperes peak for approximately 20% rolloff (@20°C) (4) K-factor: Used to determine B p-p for core loss (see graph). B p-p = K*L*∆I, B-p-p: (Gauss), K: (K factor from table), L: (Inductance in uH), ∆I (Peak to peak ripple current in Amps). Mechanical Diagrams TOP VIEW LEFT VI EW FRONT VI EW BOTTOM VIEW RECOM M ENDED PCB LAYOUT SCHEM ATIC 10.0+/- 0.254 2.3 +/- 0.3 1 HCP1104-X X X 11.5 max. 1 4.0 max. 6.2 wwllyy R 12.0 9.2 2 3.5 +/- 0.5 2 4.5 Dimensions are in millimeters. wwlly = Date Code. R = Revision Level. HCP1104 Series High Current Pressed Power Inductors Packaging Information 1.5 dia min 1.5 dia +0.1/-0.0 2.0 A 4.0 0.35 +/-0.05 1.75 0.3Rad max. 11.5 24.0 Bo HCP1104-XXX wwll yy R Ao=10.3 mm Bo=11.5 mm Ko=4.3 mm Ko 16.0 Ao A SECTION A-A Par ts packaged on a 13" Diameter reel. 950parts per reel. 0.3 rad typ User d irection of feed Core Loss Core Loss vs Bp-p 700kHz 300kHz Core Loss (mW) 10000 1000kHz 500kHz 1000 100 100kHz 10 1 10 100 1000 Bp-p (Gauss) 10000 HCP1104 Series High Current Pressed Power Inductors Performance Graphs 0.16 60 0.12 40 0.08 0.04 20 0.00 0 10 20 30 80 0.30 60 0.20 40 0.10 20 0.00 40 0 0 10 20 DC Bias(Amps) 0.40 80 0.60 0.30 60 0.20 40 0.10 20 0.00 0 30 40 80 0.50 0.40 60 0.30 40 0.20 20 0.10 0 0 10 20 30 40 DC Bias(Amps) HCP1104-R90-R 100 1.00 80 0.80 60 0.60 40 0.40 20 0.20 0.00 Temp.-rise(°C) Inductance(uH) 100 0.00 50 DC Bias(Amps) 1.20 Inductance(uH) 0.70 20 50 HCP1104-R56-R 100 Temp.-rise(°C) Inductance(uH) HCP1104-R45-R 10 40 DC Bias(Amps) 0.50 0 30 Temp.-rise(°C) 0 100 Temp.-rise(°C) 80 HCP1104-R36-R 0.40 Inductance(uH) 100 0.20 Temp.-rise(°C) Inductance(uH) HCP1104-R20-R 0.24 0 0 10 20 30 DC Bias(Amps) PM-4134 3/07 © Cooper Electronic Technologies 2007 Visit us on the Web at www.cooperbussmann.com 1225 Broken Sound Pkwy. Suite F Boca Raton, FL 33487 Tel: +1-561-998-4100 Toll Free: +1-888-414-2645 Fax: +1-561-241-6640 This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. Cooper Electronic Technologies reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Electronic Technologies also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Electronic Technologies does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
HCP1104-R45-R 价格&库存
很抱歉,暂时无法提供与“HCP1104-R45-R”相匹配的价格&库存,您可以联系我们找货
