IP4366CX8/P,135
IP4366CX8/P,135
    NEXPERIA(安世)
    8-WFBGA,WLCSP
    RC(Pi) EMI 滤波器 2nd 订单 低通 3 通道 R = 47 欧姆,100 欧姆,C = 17pF(总计) 8-WFBGA,WLCSP
IP4366CX8/P,135 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection to IEC 61000-4-2 level 4 Rev. 02 — 11 February 2010 Product data sheet 1. Product profile 1.1 General description The IP4064CX8, IP4364CX8 and IP4366CX8 are 3-channel RC low-pass filter arrays which are designed to provide filtering of undesired RF signals in the 800 MHz to 3 000 MHz frequency band. In addition, the IP4064CX8, IP4364CX8 and IP4366CX8 incorporate diodes to provide protection to downstream components from ElectroStatic Discharge (ESD) voltages as high as ±15 kV contact discharge according the IEC 61000-4-2 model, far exceeding standard level 4. All three devices are fabricated using monolithic silicon technology and integrate three resistors and seven high-level ESD-protection diodes in a single Wafer-Level Chip-Scale Package (WLCSP). These features make the IP4064CX8, IP4364CX8 and IP4366CX8 ideal for use in applications requiring the utmost in miniaturization such as mobile phone handsets, cordless telephones and personal digital devices. 1.2 Features and benefits „ „ „ „ Pb-free, RoHS compliant and free of halogen and antimony (Dark Green compliant) 3-channel SIM card interface integrated RC filter array Integrated 100 Ω/100 Ω/47 Ω series channel resistors Integrated ESD protection withstanding ±15 kV contact discharge, far exceeding IEC 61000-4-2 level 4 „ WLCSP with 0.4 mm pitch (IP4364CX8 and IP4366CX8) and 0.5 mm pitch (IP4064CX8) 1.3 Applications „ SIM interfaces in e.g. cellular and Personal Communication System (PCS) mobile handsets IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection 2. Pinning information 2.1 Pinning bump A1 index area 1 2 3 A B C 008aaa206 transparent top view, solder balls facing down Fig 1. Pin configuration 2.2 Pin description Table 1. Pinning Pin Description A1 not connected (missing ball) A2 external pin 1 A3 internal pin 1 B1 external pin 2 B2 ground B3 internal pin 2 C1 external pin 3 C2 supply ESD protection C3 internal pin 3 3. Ordering information Table 2. Ordering information Type number Package Name Description Version IP4064CX8/LF/P WLCSP8 wafer level chip-size package; 8 bumps; 1.41 × 1.41 × 0.65 mm IP4064CX8/LF/P IP4364CX8/LF/P WLCSP8 wafer level chip-size package; 8 bumps; 1.16 × 1.16 × 0.61 mm IP4364CX8/LF/P IP4366CX8/P WLCSP8 wafer level chip-size package; 8 bumps; 1.16 × 1.16 × 0.61 mm IP4366CX8/P IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 2 of 14 IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection 4. Functional diagram C2 R1 A3 100 Ω A2 R2 B3 47 Ω B1 R3 C3 IEC61000-4-2 level 1 protection pins 100 Ω C1 IEC61000-4-2 level 4 protection pins B2 008aaa210 Fig 2. Schematic diagram 5. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VI input voltage VESD electrostatic discharge voltage Conditions Min Max Unit −0.5 +5.5 V pins A2, B1, C1 and C2 to ground contact discharge [1] −15 +15 kV air discharge [1] −15 +15 kV contact discharge −8 +8 kV air discharge −15 +15 kV contact discharge −2 +2 kV air discharge −2 +2 kV IEC 61000-4-2 level 4; pins A2, B1, C1 and C2 to ground IEC 61000-4-2 level 1; pins A3, B3 and C3 to ground Pch channel power dissipation continuous power; Tamb = 70 °C - 60 mW Ptot total power dissipation continuous power; Tamb = 70 °C - 180 mW Tstg storage temperature −55 +150 °C - 260 °C −35 +85 °C Treflow(peak) peak reflow temperature Tamb [1] IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet 10 s maximum ambient temperature Device is qualified with 1000 pulses of ±15 kV contact discharges each, according to the IEC61000-4-2 model and far exceeds the specified level 4 (8 kV contact discharge). All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 3 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection 6. Characteristics Table 4. Electrical characteristics Tamb = 25 °C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 75 100 125 Ω 35.2 47.0 58.8 Ω IP4064CX8 14 17 20 pF IP4364CX8 14 17 20 pF IP4366CX8 8 10 12 pF Rs(ch) channel series resistance R1 and R3 Cch channel capacitance R2 including diode capacitance; Vbias(DC) = 0 V; f = 1 MHz [1] VBR breakdown voltage Itest = 1 mA 6 - 10 V ILR reverse leakage current VI = 3 V - - 50 nA [1] Guaranteed by design. 7. Application information 7.1 Application diagram A typical application diagram showing IP4064CX8, IP4364CX8 or IP4366CX8 in a SIM card interface is depicted in Figure 3. The 2 kV ESD compliant pins (A3, B3 and C3) are connected to the baseband interface side while the four 15 kV ESD compliant pins (A2, B1, C1 and C2) are connected to the SIM card. VSIM C2 RST CLK I/O R1 A3 A2 100 Ω R2 B3 B1 47 Ω R3 C3 100 Ω baseband B2 C1 VCC GND RST SPU CLK I/O AUX1 AUX2 SIM card 008aaa211 Fig 3. IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet Typical application diagram All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 4 of 14 IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection 7.2 Insertion loss The IP4064CX8, IP4364CX8 and IP4366CX8 are mainly designed as an EMI/RFI filter for SIM card interfaces. The insertion loss measurement configuration of a typical 50 Ω NetWork Analyzer (NWA) system for evaluation of the IP4064CX8, IP4364CX8 and IP4366CX8 is shown in Figure 4. The insertion loss in a 50 Ω NWA system for all three channels of IP4064CX8 and IP4364CX8 is depicted in Figure 5a while insertion loss of IP4366CX8 is shown in Figure 5b. The insertion loss is measured with a test Printed-Circuit Board (PCB) utilizing laser drilled micro-via holes that connect the PCB ground plane to the ground pins. IN DUT OUT 50 Ω 50 Ω TEST BOARD Vgen 001aai755 Fig 4. Frequency response measurement configuration 001aag219 0 s21 (dB) 008aaa207 0 s21 (dB) −10 (1) −10 (1) −20 −20 (2) (2) (3) (3) −30 −40 10−1 1 10 102 −30 103 104 f (MHz) −40 10−1 1 10 102 103 104 f (MHz) (1) Channel B1 to B3. (2) Channel A2 to A3. (3) Channel C1 to C3. a. IP4064CX8 and IP4364CX8 Fig 5. b. IP4366CX8 Measured insertion loss magnitudes IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 5 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection 7.3 Crosstalk The crosstalk measurement configuration of a typical 50 Ω NWA system for evaluation of the IP4064CX8, IP4364CX8 and IP4366CX8 is shown in Figure 6. Four typical examples of crosstalk measurement results of IP4064CX8 and IP4364CX8 are depicted in Figure 7a. The crosstalk behavior of IP4366CX8 is shown in Figure 7b. Unused channels are terminated with 50 Ω to ground. IN_1 50 Ω DUT IN_2 50 Ω OUT_2 OUT_1 TEST BOARD 50 Ω 50 Ω Vgen 001aai756 Fig 6. Crosstalk measurement configuration 008aaa208 0 αct (dB) αct (dB) −20 −20 (1) (2) (3) (4) −40 −60 −80 −80 1 10 102 (1) (2) (3) (4) (5) (6) −40 −60 −100 008aaa209 0 103 104 −100 1 10 f (MHz) 102 103 104 f (MHz) (1) Pin C1 to pin B3. (1) Pin B1 to pin C3. (2) Pin B1 to pin C3. (2) Pin A2 to pin B3. (3) Pin B1 to pin A3. (3) Pin B1 to pin A3. (4) Pin A2 to pin C3. (4) Pin A2 to pin C3. (5) Pin C2 to pin A3. (6) Pin C2 to pin C3. a. IP4064CX8 and IP4364CX8 Fig 7. b. IP4366CX8 Measured crosstalk between different channels IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 6 of 14 IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection 8. Package outline WLCSP8: wafer level chip-size package; 8 bumps (3 x 3 - A1) D bump A1 index area A2 E A A1 detail X e1 b e C e e1 B A 1 2 3 X European projection wlcsp8_3x3-a1_po Fig 8. Package outline (WLCSP8) IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 7 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection Table 5. Dimensions for Figure 8 Symbol Min Typ Max Unit A 0.60 0.65 0.70 mm A1 0.22 0.24 0.26 mm A2 0.38 0.41 0.44 mm b 0.27 0.32 0.37 mm D 1.36 1.41 1.46 mm E 1.36 1.41 1.46 mm e - 0.5 - mm e1 - 1.0 - mm A 0.56 0.61 0.66 mm A1 0.18 0.20 0.22 mm A2 0.38 0.41 0.44 mm b 0.21 0.26 0.31 mm D 1.11 1.16 1.21 mm E 1.11 1.16 1.21 mm e - 0.4 - mm e1 - 0.8 - mm IP4064CX8 IP4364CX8 and IP4366CX8 IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 8 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection 9. Soldering of WLCSP packages 9.1 Introduction to soldering WLCSP packages This text provides a very brief insight into a complex technology. A more in-depth account of soldering WLCSP (Wafer Level Chip-Size Packages) can be found in application note AN10439 “Wafer Level Chip Scale Package” and in application note AN10365 “Surface mount reflow soldering description”. Wave soldering is not suitable for this package. All NXP WLCSP packages are lead-free. 9.2 Board mounting Board mounting of a WLCSP requires several steps: 1. Solder paste printing on the PCB 2. Component placement with a pick and place machine 3. The reflow soldering itself 9.3 Reflow soldering Key characteristics in reflow soldering are: • Lead-free versus SnPb soldering; note that a lead-free reflow process usually leads to higher minimum peak temperatures (see Figure 9) than a PbSn process, thus reducing the process window • Solder paste printing issues, such as smearing, release, and adjusting the process window for a mix of large and small components on one board • Reflow temperature profile; this profile includes preheat, reflow (in which the board is heated to the peak temperature), and cooling down. It is imperative that the peak temperature is high enough for the solder to make reliable solder joints (a solder paste characteristic) while being low enough that the packages and/or boards are not damaged. The peak temperature of the package depends on package thickness and volume and is classified in accordance with Table 6. Table 6. Lead-free process (from J-STD-020C) Package thickness (mm) Package reflow temperature (°C) Volume (mm3) < 350 350 to 2 000 > 2 000 < 1.6 260 260 260 1.6 to 2.5 260 250 245 > 2.5 250 245 245 Moisture sensitivity precautions, as indicated on the packing, must be respected at all times. Studies have shown that small packages reach higher temperatures during reflow soldering, see Figure 9. IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 9 of 14 IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection maximum peak temperature = MSL limit, damage level temperature minimum peak temperature = minimum soldering temperature peak temperature time 001aac844 MSL: Moisture Sensitivity Level Fig 9. Temperature profiles for large and small components For further information on temperature profiles, refer to application note AN10365 “Surface mount reflow soldering description”. 9.3.1 Stand off The stand off between the substrate and the chip is determined by: • The amount of printed solder on the substrate • The size of the solder land on the substrate • The bump height on the chip The higher the stand off, the better the stresses are released due to TEC (Thermal Expansion Coefficient) differences between substrate and chip. 9.3.2 Quality of solder joint A flip-chip joint is considered to be a good joint when the entire solder land has been wetted by the solder from the bump. The surface of the joint should be smooth and the shape symmetrical. The soldered joints on a chip should be uniform. Voids in the bumps after reflow can occur during the reflow process in bumps with high ratio of bump diameter to bump height, i.e. low bumps with large diameter. No failures have been found to be related to these voids. Solder joint inspection after reflow can be done with X-ray to monitor defects such as bridging, open circuits and voids. 9.3.3 Rework In general, rework is not recommended. By rework we mean the process of removing the chip from the substrate and replacing it with a new chip. If a chip is removed from the substrate, most solder balls of the chip will be damaged. In that case it is recommended not to re-use the chip again. IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 10 of 14 IP4064CX8; IP4364CX8; IP4366CX8 NXP Semiconductors Integrated SIM card passive filter array with ESD protection Device removal can be done when the substrate is heated until it is certain that all solder joints are molten. The chip can then be carefully removed from the substrate without damaging the tracks and solder lands on the substrate. Removing the device must be done using plastic tweezers, because metal tweezers can damage the silicon. The surface of the substrate should be carefully cleaned and all solder and flux residues and/or underfill removed. When a new chip is placed on the substrate, use the flux process instead of solder on the solder lands. Apply flux on the bumps at the chip side as well as on the solder pads on the substrate. Place and align the new chip while viewing with a microscope. To reflow the solder, use the solder profile shown in application note AN10365 “Surface mount reflow soldering description”. 9.3.4 Cleaning Cleaning can be done after reflow soldering. 10. Abbreviations Table 7. Abbreviations Acronym Description DUT Device Under Test EMI ElectroMagnetic Interference ESD ElectroStatic Discharge NWA NetWork Analyzer PCB Printed-Circuit Board PCS Personal Communication System RFI Radio Frequency Interference RoHS Restriction of Hazardous Substances SIM Subscriber Identity Module WLCSP Wafer-Level Chip-Scale Package 11. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes IP4064CX8_IP4364CX8_ IP4366CX8_2 20100211 Product data sheet - Modifications: • • • Type number IP4366CX8 added Figure 3: added General editorial update IP4064CX8LF_IP4364CX8LF_1 20071112 IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet IP4064CX8LF_IP4364CX8LF_1 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 - © NXP B.V. 2010. All rights reserved. 11 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the NXP Semiconductors product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. NXP Semiconductors does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Non-automotive qualified products — Unless the data sheet of an NXP Semiconductors product expressly states that the product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 12 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com IP4064CX8_IP4364CX8_IP4366CX8_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 11 February 2010 © NXP B.V. 2010. All rights reserved. 13 of 14 NXP Semiconductors IP4064CX8; IP4364CX8; IP4366CX8 Integrated SIM card passive filter array with ESD protection 14. Contents 1 1.1 1.2 1.3 2 2.1 2.2 3 4 5 6 7 7.1 7.2 7.3 8 9 9.1 9.2 9.3 9.3.1 9.3.2 9.3.3 9.3.4 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 4 Application diagram . . . . . . . . . . . . . . . . . . . . . 4 Insertion loss . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Crosstalk. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Soldering of WLCSP packages. . . . . . . . . . . . . 9 Introduction to soldering WLCSP packages . . . 9 Board mounting . . . . . . . . . . . . . . . . . . . . . . . . 9 Reflow soldering . . . . . . . . . . . . . . . . . . . . . . . . 9 Stand off . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Quality of solder joint . . . . . . . . . . . . . . . . . . . 10 Rework . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Cleaning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 11 February 2010 Document identifier: IP4064CX8_IP4364CX8_IP4366CX8_2
IP4366CX8/P,135 价格&库存
很抱歉,暂时无法提供与“IP4366CX8/P,135”相匹配的价格&库存,您可以联系我们找货
